Maintenance of Class 9/8 clean room in a medical devices factory
G
Gert Sorensen
#11
Re: Maintenance of Class 9/8 clean room
The allergies resulting from using the disinfectants too much? that could be a point but for now we have not discovered anything like this. perhaps it would be a good idea to use various and exchange them... In this case risk of allergies should be reduced.
I know China does not have the strictest of environmental laws :notme: , but I feel that we have a responsibility to help the workers to decent HSE conditions.
On a slightly different note, we have experienced that some cleaning products have reduced efficiency after a period of time. So, we use interchangeable products for cleaning.
The filters and over-pressure seams to be OK. The clean-room has been constructed just recently so I trust all should be fine here.
Is your over-pressure sufficient?
Overkill? Hm... is it a problem?
Overkill is always a problem. It is expensive and time consuming, and it reduces the respect for QA....
Wes Bucey
#12
I subscribe to Clean Room magazine as an aid when I consult with clients encountering clean room opportunities for improvement. It is available for free to American subscribers in the trade. The electronic version may also be available for free to Europeans. The publisher's home page is http://www.qmags.com/ scroll down until you find the icon for Clean Room to view a sample issue.
I've found the suppliers of various products to be an excellent source of information for exploiting opportunities for improvement.
G
gereard_kgb
#13
Thanks Wes. I'll try it.
"I've found the suppliers of various products to be an excellent source of information for exploiting opportunities for improvement." - sure they are :) :)
I'll check the data on over-pressure and let know.
How do you measure over-kill? is there any pieces of information on it?
jeffrey_Chang
#14
Although, we are not in the medical devices business but we are doing wafer where we need a class 100 clean room. Basically, the class is determined by the no. of particles count in the clean room.
  1. Do you measure the particles count regularly to ensure the clean room class is maintained to what it is supposed to be?
For a class 100 clean room, all personnel are to wear jumpsuit with gloves and face mask. Before entry to the clean room, we are to wash our hands with plain water and air blow dry. We have the hand washer and air blower at the entrance.
Absolutely NO cosmetics (makeups), no perfume etc are allowed in the clean room; i.e. you cannot put on makeups when you are in the Class 100 clean room. The clean room is with HEPA filters and laminar flow.
That's all I can think for the time being.
thks.
jeffrey.
G
gereard_kgb
#15
Thanks.
In our factory we are running ISO class 8, GMP class D. I am not sure how does it count for the particles count...
In our CR people need to do the same - wash and air blow dry them. Also hands disinfection is required every time people enter the premises and than every 2 hours (what was found an exaggeration by Gert :notme: )
Full suits are obligatory for everyone - gown, cap, feet covers and face covers.
We let people use no cosmetics, chew no gums in the clean room.
It is also necessary to re-wash hands any time they touch their face or blow their nose.
We are buying the particles counter now... :notme:
Right now I am in the position to say that we have found the place of contamination. Generally most of the premises were OK except for one place. Most probably the contamination was brought with some packing materials being cut in the CR and during introducing the products though the windows... I trust this needs some more attention.
Any way all the information gathered in the thread will be very useful (at least for me :) )
:thanks: :thanx: :thanks:
jeffrey_Chang
#16
Thanks.
Hi Gereard,
One more additional point, when you are bringing in any equipments, machinery or instruments etc into the clean room. Wipe downmust be performed in the staging area; i.e. the equipments, machinery etc must be clean with DI water before getting it into the clean room.
No detrashing of boxes in the clean room area since boxes could have fibers. We are also using lint free paper in the clean room. We use room ionization as well but it is very costly to install and maintain room ionization.
thks.
jeffrey. :)
G
gereard_kgb
#17
Yes, you are right at this point of course.
The procedures for introducing the products are prepared and followed.
We tend to use double packing so that the outer one is left outside the cleanroom and the internal one unwipped in the airlock window or unpacking area of the clean room (depending on the product and its manufacturer).
Ajit Basrur
#19
Since you mentioned that there is a particular spot which has contributed to high counts, some more thoughts -
1. You can use smoke test to check the flow of air pattern. This can detect any improper flow and thereby show you deadspots. These areas have high concentration of particles. This will also detect if Return air filters are effectively functioning.
2. Check if the floors and walls are free from crevices
3. You could increase the pressure differential between the decartoning room and the cleanroom.
G
gereard_kgb
#20
Qualityalways, thank you very much for your comments.
Smoke test - what smoke can be used so that no contamination is introduced? are there any ready made products? how is it done?
are there any standards... ;)
:thanks:
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
B Total Productive Maintenance - Company Transport IATF 16949 - Automotive Quality Systems Standard 2
P Minor Non-Conformance - Maintenance Records Not Fully Completed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
L 21CRF820.70(g)(2) Maintenance Inspection Interval 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K IATF16949 8.5.1.5 Total Productive Maintenance IATF 16949 - Automotive Quality Systems Standard 9
J FAA Maintenance Requirements - DER Repair to a PMA Part Federal Aviation Administration (FAA) Standards and Requirements 1
K Maintenance requirements for Production Equipment in AS9100D General Auditing Discussions 8
T Part 145 Maintenance Station S/N ESN Character Requirements EASA and JAA Aviation Standards and Requirements 3
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 19
D Does AS9100 certified OEM need AS9110 if no maintenance is provided? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N Laboratory Audit Nonconformance - Maintenance of Standards ISO 17025 related Discussions 10
A Technical File Maintenance - Old generation product EU Medical Device Regulations 4
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
S Preparing a Turtle Diagram for Maintenance Department Misc. Quality Assurance and Business Systems Related Topics 2
U Relating maintenance to product quality Manufacturing and Related Processes 5
S ISO 9001 Audit requirement for maintenance department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Service and maintenance in an initial importer facility USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
A Electronic Maintenance Records stored in a machine ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A How to create a Maintenance procedure based on TS 16949 Requirements IATF 16949 - Automotive Quality Systems Standard 5
N ISO 9001 Quality Manual for an O&M (Operations and Maintenance) Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Predictive Maintenance Format / Example Misc. Quality Assurance and Business Systems Related Topics 4
T Are Customers required to follow a Manufacturers Maintenance Schedule? ISO 13485:2016 - Medical Device Quality Management Systems 3
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Technical Files/Dossier/STED File Maintenance for Notified Body Audiits Other Medical Device Regulations World-Wide 2
C Document Revision for each new Preventative Maintenance Checklist? Document Control Systems, Procedures, Forms and Templates 5
M Where to start Maintenance Function Kaizen Lean in Manufacturing and Service Industries 4
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
J Maintenance Man Hour Plan which satisfies EASA Part 145.A.30 (example needed) EASA and JAA Aviation Standards and Requirements 4
