Major Finding Elevation - Do I elevate this minor finding to a major one?
phxsun2001
Involved - Posts
Do I elevate this minor finding to a major one ?
There was an NCR written up against 8.5.4 C. in 2017
8.5.4.C
special handling and storage for sensitive products.
There was an ESD control and Nitrogen dry box issues on sensitive material. No expired shelf life material found.
C/A and P/A were effective during a recent certification follow-up audit.
During the certification audit recently in 2018, there was a NCR vs 8.5.4 D
8.5.4.D on Shelf life material labeling used in production on shelf life material used. Shelf life material poured from a gallon bottle was not labeled properly after transferred to a smaller bottle.
This is a different issue from the one in 2017.
Does the AS9100 standard consider this a repeat violation of requirement 8.5.4 and issue an elevated Major NCR? The violations were on different sub-clauses.
The root cause and C/A of the two NCRs are totally different. The new OASIS system does not allow auditor to enter sub-clauses. I can only enter 8.5.4. on both NCRs. I was able to enter sub-clauses before the OASIS system in AS9100C.
The 2017 NCR was closed already. The problem was fixed.
BJ
phxsun2001
Involved - Posts
This is not an internal audit. This a AS9100D recertification audit.
It is under the same 8.5.4 requirement , but different sub-clause, 8.5.4.C and 8.5.4.D.
Do I have to elevated to a major NCR?
phxsun2001
Involved - Posts
Yes, I am a CB Auditor conducting a recertification audit.
I was told that as long as it is within 8.5.4, it doesn't matter if it is sub-clause C or D, it is a repeat violation and a major NCR should be issued.
I also issued a NCR vs 8.5.1.C in 2017 related to sampling inspection procedure not followed. During this 2018 recent audit, I issued 4 NCR within 8.5.1 a to q. They were not related to the one in 2017. I was told to issue four additional Major NCR because they are under 8.5.1. and they are repeats of clause 8.5.1. What are the rules on repeat violation and elevation to major N/C. Does anyone know? Do we go by upper level clauses like 8.5.1?
It is not difficult to find N/C within clauses 8.5.1 a-q, especially with this company of 1000 employees with hundreds of individual assembly operations. If I find a single N/C in 8.5.1 again in 2019, are they going to loose their certification? It is a repeat of a major N/C.
John Broomfield
If you have evidence of a chronic (persistent) problem then it probably should be reported as a major nonconformity to get the attention of senior management.
Carefully cite all of the evidence to support your NCR.
This is an important part of your service to your client and their customers.
You may also cite the failure to take effective corrective action as another separate NCR.
phxsun2001
Involved - Posts
Do your Operations management of the CB you work for not provide guidance?
Our CB guideline is- if one NCR was written in 2017 on 8.5.1 on any sub-clause (a-q), We have to issue a major in 2018 if I issue another NCR within 8.5.1 a to q. It doesn't matter which sub-clause. We don't follow the AS9101f to determine if the NCRs are same or different.
The same with requirement 8.5.4 and other 2nd level requirements.
AS9101f
4.2.2.5 Identifying and Recording of Audit Findings
Recurrence of the same or similar nonconformity found during consecutive audits at a particular site/location shall be considered as a major nonconformity against the corrective action process (see 9100-series standards clause 10.2).
I give up! When that kind of "rule" permeates the certification world - and there's little/no attempt to determine the EFFECT on results, the whole thing becomes stupid, frankly. What's the point?
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
AlienraverX How to appeal a major audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T Non-addressed Minor Finding elevated to Major Finding Internal Auditing 37
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
C Notification to Customers regarding Major Audit Finding IATF 16949 - Automotive Quality Systems Standard 25
J Follow up on Major Audit Finding General Auditing Discussions 15
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
E Nadcap Major Audit Finding Question - Effectiveness of our RCCA AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
E Nadcap - Tooling Control - Major Audit Finding (Question) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Internal Re-audit after Major Finding during ISO 9001 Re-Certification Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Definition Major vs. Minor Finding During external ISO audit - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 25
C How long should you have to close out a major TS 16949 audit finding? IATF 16949 - Automotive Quality Systems Standard 9
A Difference between major, Minor, finding and Observation in relation to a CAR Nonconformance and Corrective Action 7
D Definition Major vs. Minor Nonconformance (Finding) - Difference and Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
J Internal Audit Findings - Major vs. Minor Finding - Defining the differences Internal Auditing 14
A Definition Major vs. Minor Nonconformance (Finding) - Internal Audit - Definition & Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 38
D Major NC from last audit not fixed not sure how to fix General Auditing Discussions 8
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
M Major vs. Minor for Internal Audits? Internal Auditing 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Fact or fiction - Repeat minor becomes a major IATF non-conformance IATF 16949 - Automotive Quality Systems Standard 7
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is this a Major AS9100 QMS change - Quality Concerns AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
Sidney Vianna Interesting Discussion Legal compliance as part of ISO 45001 accredited certification. Major OSHA penalties in the USA. Occupational Health & Safety Management Standards 15
Sidney Vianna Interesting Discussion How major corporations in the West keep failing to uphold their pledges of abolishing child labor in their cocoa supply chains Sustainability, Green Initiatives and Ecology 3
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
M New Medical Device Accessory with New Function - Is this a major change? Other Medical Device Regulations World-Wide 3
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A ISO 14001:2015 transition audit - Major NC due to the procedure and audit plan ISO 14001:2015 Specific Discussions 10
C How does a major NC for a support site affect our certificate? IATF 16949 - Automotive Quality Systems Standard 2
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
K Outsourced Major Processes - Working for Two Sister Companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B IATF 16949: Definition Major/Minor Non-conformity IATF 16949 - Automotive Quality Systems Standard 6
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
T Defining Major vs. Minor Changes to Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Is Failure to achieve a Goal a Major Non-Conformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
