Major nonformance finding was given during a closing meeting of a ISO9001 certification audit
Coury Ferguson
Moderator here to help
#51
One record could be the Management Review Sign in log. That would show evidence that the meeting was held, I would guess. As for the ISO9001 Standard, it requires only 3 to be recorded/documented for output.
Just my opinion.
tony s
Information Seeker
#52
So where is the record that you considered it?
If the auditor would like to verify the evidence that inputs, as listed in 9.3.2, were considered, IMHO, a record is not mandatory for the following bases:
  • Clause 9.3.2 does not require to retain documented information as evidence that inputs were covered;
  • If we rule it against 9.3.3, it's subjective. The required record here is "evidence of the results of management reviews". So, it is about the outputs not the inputs. Output is defined as "result of a process" and management review is a process;
  • ISO 9001 Auditing Practices Group Guidance on Evidence Collection has this statement: "Auditors should be aware that objective evidence does not necessarily depend on the existence of documented information, except where specifically mentioned in ISO 9001";
  • Records are not the only form of evidence (as per ISO 19011 definition).
I've noticed that most auditors ask records to demonstrate whether all the 9.3.2 inputs were covered, but do we really need to obtain documented evidences for that. Do we ask record/s that the items listed in 4.3a to 4.3c were considered in determining the scope of the QMS?
Big Jim
#53
Perhaps you need to read the final line in 9.3.3 again. You take a very narrow view that I don't think is justified. It doesn't say retain documented information of management reviews outputs. It says retain documented information as evidence of the results of management reviews. That would be all of management review.
tony s
Information Seeker
#54
If the interpretation of "results of management review" is "all of management review", then why didn't the standard just say "retain documented information as evidence of management reviews".
Maybe there's a profound reason why ISO 9001:2015 version placed the requirement for retaining records in 9.3.3-Management review outputs instead in 9.3.1-General. A meaningful change from the 2008 version where the statement "Records from management reviews shall be maintained" is located at clause 5.6.1-General. This provided us a better view of the value of conducting and documenting management reviews. This also promotes an "output oriented" way of looking at processes.
#55
Maybe there's a profound reason why ISO 9001:2015 version placed the requirement for retaining records in 9.3.3-Management review outputs...
If the reason is "profound" and knowledgeable people are here arguing about it, the problem is with the standard. I think that characterizing a nonconformity as "major" might qualify as profound, but the auditor in this case did an absolutely horsebleep job of describing what he found, what the standard says he should have found, and why the NC is major rather than minor.
Sidney Vianna
Post Responsibly
#56
People fantasize about the hidden "wisdom" contained in standards. The standard development process is far from perfect and, many times, much more influenced by political issues and posturing than technical soundness.
Big Jim
#57
This is certainly true. The result is often there for all to see after it is published.
Big Jim
#58
And maybe there isn't. I don't believe there is. Perhaps there is a reason that certification body audit workbooks ask if all of the management review inputs were covered, and perhaps there isn't.
Big Jim
#59
How can the outputs be evaluated if not all of the inputs were covered?
tony s
Information Seeker
#60
I'm also on the same side of the fence that the finding is not a major NC. I even oppose it and assert that it's not even a nonconformity. Yes, I agree that the auditor has committed a profound lapse in judgment to slap the OP with a major NC.
Maybe in my attempt to highlight the difference/s in the requirement for retaining record on management review between the 2015 and 2008 versions of the standard, I used the word "profound" before mentioning "reason". Anyway, I hope, with the knowledgeable people here at the Cove, that the statement "Records from management reviews shall be maintained" placed at 5.6.1-General of 2008 is not similar with "The organization shall retain documented information as evidence of the results of management reviews" placed at 9.3.3-Management review outputs of the 2015.
Whatever the reason or lack of it, I believe, most of us here, will not accept the CB workbooks as audit criteria in the context of the OP's predicament.
9.3.2 use the statement "taking into consideration", I believe, there's some flexibility on this. ISO/TS 9002: 2016 has also this statement: "It is not required that all the inputs to management review be addressed at one time, but instead they may be addressed during sequenced management reviews".
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
M Major vs. Minor for Internal Audits? Internal Auditing 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Fact or fiction - Repeat minor becomes a major IATF non-conformance IATF 16949 - Automotive Quality Systems Standard 7
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is this a Major AS9100 QMS change - Quality Concerns AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
Sidney Vianna Interesting Discussion Legal compliance as part of ISO 45001 accredited certification. Major OSHA penalties in the USA. Occupational Health & Safety Management Standards 15
Sidney Vianna Interesting Discussion How major corporations in the West keep failing to uphold their pledges of abolishing child labor in their cocoa supply chains Sustainability, Green Initiatives and Ecology 3
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
P Major Finding Elevation - Do I elevate this minor finding to a major one? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
M New Medical Device Accessory with New Function - Is this a major change? Other Medical Device Regulations World-Wide 3
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A ISO 14001:2015 transition audit - Major NC due to the procedure and audit plan ISO 14001:2015 Specific Discussions 10
C How does a major NC for a support site affect our certificate? IATF 16949 - Automotive Quality Systems Standard 2
AlienraverX How to appeal a major audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
K Outsourced Major Processes - Working for Two Sister Companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Non-addressed Minor Finding elevated to Major Finding Internal Auditing 37
B IATF 16949: Definition Major/Minor Non-conformity IATF 16949 - Automotive Quality Systems Standard 6
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
T Defining Major vs. Minor Changes to Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Is Failure to achieve a Goal a Major Non-Conformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
C Notification to Customers regarding Major Audit Finding IATF 16949 - Automotive Quality Systems Standard 25
J Follow up on Major Audit Finding General Auditing Discussions 15
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D When to complete FAA Form 337 (Major Repair and Alteration) Federal Aviation Administration (FAA) Standards and Requirements 4
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
S What are the implications of a major NC during a TS 16949 surveillance audit? IATF 16949 - Automotive Quality Systems Standard 3
U Major Nonconformance - We had a control in place that was not on the control plan IATF 16949 - Automotive Quality Systems Standard 14
H Internal Audit Major Nonconformity or Not? Quality Manager and Management Related Issues 24
R Classification of Major & Minor Defects AQL - Acceptable Quality Level 10
M What are the major causes of Forklift Accidents? Occupational Health & Safety Management Standards 13
Q Raising a Major Nonconformance during an Internal Audit Internal Auditing 23
N Second Registrar Visit to Confirm Major Nonconformances Fixed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
