Making a change to an approved Medical Device
mghaleb
Hey Every one,
i have a question regarding a approved medical device (class 1) in US which we will change the Hardware and Software?
what must we bear in mind? must apply for a new Registration? or Report the FDA about the Modification? which documents must we give later?
Thanks in Advance,
Ghaleb
melissa237
On the FDA's website they have a guidance document/decision tree to use specifically for determining if you need to submit a brand new device application, submit a change notification or just document the change to file. I'm sorry but I don't remember the name of the document. But I'm sure you can type in to their search bar something that will get you there.
Hope this helps!
Ronen E
Problem Solver
Moderator
The advice given above is relevant to devices classified such that they require a 510k submission. Most class I devices don't require that.
If the device post-modification falls under a procode that doesn't require a 510k (again, most procodes under class I don't), then you don't have to worry about whether or not a 510k is required (or a note to file). All devices (including class I) are subject to the General Controls. Based on the original device already being cleared (adequately, I presume, since FDA is not involved in pre-market clearance of most class I devices), the General Controls have already been applied and are continuously being maintained. As such, all that is required is continuation of practice as already established, including all provisions pertaining to device changes.
Some class I procodes are also GMP exempt, which means that the quality management system requirements are very limited. Even those that are not GMP exempt, are likely to be exempt from Design Control (21 CFR 820.30). The processes (and documentation) required by the regulations for device changes depend on the required level of quality system (GMP exempt / GMP without Design Control / GMP including Design Control). This would be defined by the applicable procode. It's essential to understand upfront what procode the device would fall under after the change.
Cheers,
Ronen.
Mark Meer
Thanks for catching that Ronen! Essential to check the procode.
...easy to forget the different regulatory universe that is Class I. :lol:
Julie O
I've seen people work through this process this starting with, "This is a Class I device," which leads them to "We are making changes to a Class I device," which leads them to "We now have a modified Class I device." Not exactly.
Yes, they did modify a Class I device, but whether the modified device is a Class I device is a different question. If the modified device fits the description associated with regulatory classification number* for the original device, then yes. If it fits the description associated with some other regulatory classification number that is also Class I, then yes. Otherwise, not, and you start looking for a Class 2 predicate or consider going De novo.
When you modify a Class I, I think it is always wise to re-read the regulatory description associated with that device, to make sure the modified device still fits.
_______________________
*I think this must be what Ronen refers to as a procode, but I'm not sure because I've never heard this term before.
Ronen E
Problem Solver
Moderator
I was referring to the FDA's 3-letter code, which is more specific than the regulation number. Where the nickname "procode" came from I'm not sure; I picked it somewhere along the way, and have been using it for some years. I always thought it's short for Product Code.
M Change Control - How low do you go before making official changes? Document Control Systems, Procedures, Forms and Templates 8
S Time for a Special 510k? Making a formulation change to an existing 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S PPAP and Interchangeability - Necessity to re-PPAP when making an Engineering Change APQP and PPAP 5
O MDD 93/42 and making documentation available EU Medical Device Regulations 1
A Making changes to IDE device Other US Medical Device Regulations 7
Ed Panek Make sure you hire competent QA RA Folks before making a "Medical Device." Coffee Break and Water Cooler Discussions 1
N Making improvements in supplier relationship last? Supplier Quality Assurance and other Supplier Issues 6
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 7
Steve Prevette Informational I am presenting a webinar Thursday - "Data Driven Decision Making" - 19 November 2020 Statistical Analysis Tools, Techniques and SPC 5
J Masters Degree - Advice about a decision I"m going to be making Career and Occupation Discussions 9
U What is the process for making updates to our Processes? Design and Development of Products and Processes 11
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
K Verifying gas tight glass syringe used for making standards General Measurement Device and Calibration Topics 4
M Informational US FDA – Patient-Reported Outcomes (PROs) in Medical Device Decision Making Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Patient Preference Information (PPI) in Medical Device Decision-Making Medical Device and FDA Regulations and Standards News 0
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
K Turtle diagram or process interaction chart - Making it easier for an auditor Process Maps, Process Mapping and Turtle Diagrams 23
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
O Reinstating a disqualified supplier—questions to ask before making a decision Supplier Quality Assurance and other Supplier Issues 2
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
M IATF 16949 Cl. 8.7.1.4 - Risk analysis for decision making about rework IATF 16949 - Automotive Quality Systems Standard 2
D Help needed for Compliance Road-Map - Startup making their first device (IVD) IEC 62304 - Medical Device Software Life Cycle Processes 1
C IATF 16949 Cl. 8.4.1.2 d) Multidisciplinary Decision Making IATF 16949 - Automotive Quality Systems Standard 2
G Is it compulsory to make DFMEA for proto parts making organisation APQP and PPAP 1
L Making a Medical Devices Registration Database - Help and Suggestions Wanted Other Medical Device and Orthopedic Related Topics 2
B Making a Safety Culture Chart Occupational Health & Safety Management Standards 3
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
4 Customer Making Changes to a 510k Device They Purchased 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Making Amendments to a Quality Manual Quality Management System (QMS) Manuals 2
V Making a choice of Simple vs Comprehensiveness of Procedure/System of any Process Document Control Systems, Procedures, Forms and Templates 4
K Making a Quality Requirements Handbook for Employees Training - Internal, External, Online and Distance Learning 10
D ROHS 2 - Medical Device: Placing vs Making Available on the market EU Medical Device Regulations 3
J Keyboard issue in Word - Making me nuts Coffee Break and Water Cooler Discussions 5
W Chinese Distributor Making Counterfeit Products - Class I sterile products China Medical Device Regulations 2
P Making Quality and Compliance Invisible Imported Legacy Blogs 0
AnaMariaVR2 Structured Approach to Benefit-Risk Assessment in Drug Regulatory Decision-Making Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Proud Liberal Making a simple Sampling Plan by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
N Decision Making... (joke) Funny Stuff - Jokes and Humour 1
G The right approach for making the transition from ISO9001 to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS 9100 4.2.4 Process for making changes to records is not fully effective Quality Manager and Management Related Issues 4
V Making Solar cells, Module, String - Which Cleanroom Level? Various Other Specifications, Standards, and related Requirements 2
P Outsourced Manufacturing - Making Subcontractors comply with TL9000 TL 9000 Telecommunications Standard and QuEST 2
G Free ASTM Standards? Recent Court Ruling making their standards free? Various Other Specifications, Standards, and related Requirements 10
U ISO 13485 mandatory for a factory making Medical Devices for EU? EU Medical Device Regulations 6
B Categorization of Customer Complaint: Making Customers feel they are Top Priority Customer Complaints 4
E Starting Nadcap Accreditation and making an Implementation Timeline AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Making a Box Plot in Excel Excel .xls Spreadsheet Templates and Tools 3
V Ideas, Measures/Metrics for making Quality Proactive? US Food and Drug Administration (FDA) 2
D 3D Printers - Making Replicas Coffee Break and Water Cooler Discussions 11
