Management of NC after internal system audit
Hello all,
after our internal system audit we have obviously detected some NC.
We have in 3 weeks time the official IATF audit and of course it's not possible at all to solve all of them.
The responsible of the system is forcing the organization to close all them before the audit because this is a IATF requirement but, as per my understanding this is not true.
The IATF (and ISO) gives rules on how to manage NC after their audit but they do not ask anything in term of NC found during internal audit. In this case they focus on the system to manage them, which means root cause analysis, corrective anction and a clear action plan with responsible and due date.
Am I correct ?
Thanks and best regards to all of you!
John Predmore
I don't know anything about the difficulty of the NCs you identified. Some problems simply take longer to correct. In 3 weeks time, it is reasonable you have person(s) assigned to address the NCs, the teams have completed all or most containment activity, some or all of root cause investigation, have solid plans for corrective action including target completion date, and a maybe a proposal of how and how soon after completion you will assess effectiveness of your corrective action.
Jean_B
You are correct that the system should be audited, and not be judged on an absence of open NC's (which to me is even more suspicious).
Things to be able to do when you have the external audit on such a recent internal audit non-conformity:
  • Report(s) correctly administrated?
  • For each non-conformity must have
    • Risk assessment
      • Containment enacted and active if needed, on a solid base for affected items
  • For each non-conformity want to have
    • Cause analysis
    • Action plan
    • Evidence of implementation
    • Evidence of verification of effectiveness
The first two main points are crucial. For each of the sub-points of the third you're in a better position when you can show more final records, or at least drafts and why they're not yet final.
Ripe open non-conformities need a different approach; they are far more often used as an indicator for ineffective follow-up than newly opened non-conformities.
qualprod
Hello all,
Am I correct ?
Could you mention the findings?
Sometimes, some just need a correction, not full analysis.
Also, sometimes several ncs are solved with just one corrective action,
and are solved in few days.
Once you explain the case, you may have a more precise response.
Be well
Golfman25
If memory serves me, IATF rules (or at least the CBs) may like to see NCs from internal audits closed out before third party audits. But as you are experiencing, that isn't realistic. I would say work or NC system and be prepared to show the progress of your corrective actions to the third party auditor. You should be fine. Good luck.
qusys
If the organization does not timely fix the elicited non-conformities concerning with new IATF requirements ( for instance, documented process for temporary process changes, product safety, TPM implementation, risk management, supplier development, control of reworked/repaired product, competence and on the job training, employee motivation, contingency plans etc.), this could carry a breakdown in the quality management system and translate in a potential failure of the processes.
In any case this potential issue should be matter of the organization management review as an input.
Sebastian
I do not see anything about requirement related to closure of all internal system nonconformities before 3rd party audit is carried out.
It is a little bit risky to plan internal audit just before 3rd party audit, but always is better to identify concerns internally than wait for external auditor.
There is some time for implementing corrections and root causes and corrective actions can follow later. If you implement good corrections, there is no chance for external auditor to detect it. Only auditing internal audits will tell, there is something going on.
Mikey324
Our IATF auditor seems to understand the intent of the standard. As long as you can show you are actively working to close the NC, you should be fine. Is the problem contained, 100% sorting or similar? Root cause has been determined, or you can show you are working on it? If so, it would seem to me that you are following the intent of the standard. Your auditor should see it that way too.
We have had open NC's at this time of a 3rd party audit. Its just part of life. I have never had questioned why it was open. Just what our progress toward closure was.
A A Guide to Effective Internal Management System Audits Book, Video, Blog and Web Site Reviews and Recommendations 2
V Internal Audit of Integrated Management System Miscellaneous Environmental Standards and EMS Related Discussions 2
A Internal Audit for an Integrated Management System (IMS)? Internal Auditing 17
B Where do I start when I Internal Audit the Quality Management System? Internal Auditing 8
Raffy ISO22000:2005 Food Safety Management System - Applicable Internal Audit standard? General Auditing Discussions 7
C Integrated Management System Training - Internal and Lead Auditor training Training - Internal, External, Online and Distance Learning 14
P Internal Audit Reports reviewed by management? 21 CFR 820.22 Interpretation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
M Risk Management (ISO 14971:2007) Internal Audit Checklist ISO 14971 - Medical Device Risk Management 7
V Most Common Internal/External Audit Observations on Risk Management ISO 14971 - Medical Device Risk Management 4
C How should I present Internal Audit results to Management in Management Review Internal Auditing 18
K Questioning Top Management on The Quality Policy during Internal Audits Internal Auditing 7
K Sample Questions for Auditing Management Rep , Internal Audit and Reg. Compliance Internal Auditing 7
K Should Internal Audit Plan be Approved by Top Management? Internal Auditing 19
J How to Write the Planned Interval to Conduct Internal Audit, Management Review, etc.. ISO 13485:2016 - Medical Device Quality Management Systems 3
F Benefits of Internal Audits in supporting Safety and Quality Management Systems Internal Auditing 5
E Internal Audit for Project Management Team - Construction Industry Internal Auditing 8
D Management Review Analysis of Internal Audit Findings Quality Manager and Management Related Issues 8
H Quality Management Best Practices for Internal Auditing Internal Auditing 6
L Top Management - Internal Audit Questions to Ask Internal Auditing 17
M Internal Audit for ISO 14001 - Questions for Management Internal Auditing 12
G Questionnaire for Internal Audit of Top Management Internal Auditing 9
A MR (Management Representative) also doing Internal Audits? Internal Auditing 27
A Auditing the Internal Auditors and Management Review Internal Auditing 5
E Internal Audits - Presenting Audit Findings to Upper Management General Auditing Discussions 19
S Auditing the Top Management during the Opening Meeting of Internal Audit Internal Auditing 21
6 Management Review does not highlight Internal Audit Finding - Root Cause Analysis General Auditing Discussions 11
S Executive Management Participation in Internal Audits Internal Auditing 8
K Auditing the Internal Vendor (Supplier) Management Process Supplier Quality Assurance and other Supplier Issues 2
E Management Review - Internal Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Frequency of Management Review Meetings pre- and post- Internal & Surveillance Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
F Internal Audit for Top Management / ISO 9001:2008 General Auditing Discussions 11
H Internal Audit for Management Representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A What gets reported about Internal Audits at Management Review? Management Review Meetings and related Processes 13
D Can The Internal Auditor Also Be The Management Representative? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Antonio Vieira "Planned intervals" for Internal Audits and Management Review Management Review Meetings and related Processes 9
L Internal Auditing of Integrated Management Systems Internal Auditing 12
B Management Commitment and Internal Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Internal Quality Audit Management Software General Auditing Discussions 13
Q Internal Audit Questions - Does anyone have sample questions for Management Internal Auditing 16
H How internal audit benefit the management level? Internal Auditing 1
I What is the Difference between Management Review and Internal Audit? Management Review Meetings and related Processes 4
R Internal Audit and Management Review before Certification: Is it a required? Management Review Meetings and related Processes 3
Antonio Vieira The importance of some processes... Internal Audit, Management Review, Nonconformance Management Review Meetings and related Processes 3
J AS9100 Internal Audit Reporting to Management Internal Auditing 8
X TS 16949 Clause 5.5.3 Internal Communication - Continuous Management Review Meetings? Management Review Meetings and related Processes 6
R Management & Internal Audits (Oil & Water?) Audits as a pass/fail test Internal Auditing 19
P Can the Management Representative Do Internal Audits? Internal Auditing 31
A Management Review and Internal Audits Before Registration Audit Management Review Meetings and related Processes 2
T Measuring Effectiveness of Internal Audits - Reporting in Management Review Meeting Management Review Meetings and related Processes 13
C Any ideas on getting mid to upper management involved in Internal Audits? Quality Manager and Management Related Issues 6
