Management Representative Requirements - ISO 9k2k Clause 5.5.2a interpretation
Helmut Jilling
Auditor / Consultant
#32
Frankly, an MR should be someone that is competent in understading at least what a quality system is and is familiar with a quality systems standard.
5.5.2 states that ("top management shall appoint a member of management who,......etc") Does that mean that by the definition of management stated by ISO 9000 and also according to the dictionary, then under this type of logic top management could appoint the maintenance department manager that without trying to offend anybody would not, have much experience with quality systems implementation, right? 5.5.2 requirement appears to leave much to uncertainty and interpretation, and a more solid description needs to be defined.
NO. He/she must be a member of management, and competent to perform the assigned tasks. Both are requirements. I have written both up on a few occasions.
1. "a member of management." Many of the complaints in this Elsmar forum could be related to this one phrase. The intent of this change clearly was that the MR would have POWER to see that the necessary stuff gets done. The problem is, many companies still pick a junior "manager," or someone with limited true authority. Then the MR is tied at the ankles. When I have seen a truly "empowered Manager" as MR, as the standard intended, it truly is a beautiful thing. If the president won't take your meetings and calls, your system missed the point. It's not about assigned "authority or responsibility," it's about someone who has the power to say "do this," and it gets done.
2. "competent to perform the assigned tasks" is always a requirement for every position, including management. It can be learned, experienced or taught, but the end result has to be that the manager knows the stuff.
If you cheat either of these requirements, and many companies do, the damages run into the millions of dollars. The US auto industry could make BILLIONS more in profit if they stopped focusing on cost SAVING strategies, and began to focus on LEADERSHIP and CUSTOMER SATISFACTION. It's not rocket science, its good old fashoned hard work, mixed with cometence or proficiency (at the top levels).
For example, how many of the posters on this board are at the highest level of corporate management at their companies? Probably very few. Where are those guys on this forum? I expect most of us are working managers at the plant levels.
If the companies don't make LEADERSHIP and the CUSTOMER the top priority, they will lose. It is inevitable over time.
#33
:applause: Well said! Well, except for
And how, pray tell, does someone get "the power" if not as a result of delegated responsibility and authority (assuming we're not talking about the seat of power directly)? It's very simple: No permission, no significant action.
chaosweary
#34
MR - Isn't that the person that gives customers and 3rd party auditors company tours? :lol:
Helmut Jilling
#35
Thanks, my comment was a bit brief, and did not communicate my full intent. This thread seems to be focusing on "delegated responsibility and authority." My point is delegated responsibility and authority does little unless the MR truly has INFLUENCE and recognized AUTHORITY and POWER. As you know, responsibility can be delegated, but power and authority is earned and recofnized.
A title does little. That is why the requirement is that the MR actually be a full member of management, not a notch or two below.
JadeS
#36
Actually I am an MR and I have never given the customer or 3rd Party Auditor tours, not that I would be opposed in any way.
The MR does need to be an individual to guide, direct and work closely with top management. I am responsible for 5.5.2 a,b,c as well as liaise with the registrars and other external bodies.
When the corporation decided to implement Management Systems, ISO/QS (now TS), etc. we outlined the business processes with little thought to any of the standards requirements. Once the corporate processes were defined and documented it was my responsibility to review them and determine what was missing from the standards point of view, which was very little from a process point.
After this I was responsible to meet with senior management at each of the companies where we structured each company process based from the flow down from corporate structure. Many of the processes never differ from company to company as it makes no difference what the product or service produced. What does differ is the documentation for operator work instructions and so on.
Corporate objectives and targets were determined, documented and assigned. From these objectives and targets each Company created objectives and targets in the same manner as corporate, which are reviewed and approved by corporate. These are always a flow down to the company management teams.
The objectives and targets are then assigned to employees and individuals working on behalf of each Company, no individual is excluded. These objectives and targets must be accomplished in order for corporate to achieve their objectives and targets.
This said I could not imagine completing all these activities without having the backing of top management. It could be done but not on the timeframes that are often times required.
Have a great day,
Jade
juliov
#37
Hjilling, your assessement about the role of the MR is right on target about the responsibilities and top management support needed to effectively perform a solid job as an MR. I have seen companies appoint an MR without truly understanding what the MR's role really is, usually this person is a junior Mgr without any power to implement the processess in the QMS, the irony is that the plant personnel pick of on this and simply do not listen or take seriously the MR's requests. I had a case where everytime the MR requested a certain meeting to be held or an issue to be reviewed by a plant process owner, the owner would go to the president and had the MR's request overuled, well pretty soon it all became an exercise in frustation for this MR. I agree, if most companies woud truly and effectively implement this role of MR as it was intended the benefits of continual improvement and ROI would be in the $$$$.
juliov
#38
Chaosweary, you silly you. I have to agree that sometimes this is the case.
I guess that this would be a lost benefit for the company no? using the MR as a plant tour.
V
vanputten
#39
There a many types of authority.
coercive authority
expert authority
formal authority, also known as legitimate authority
referent authority
reward authority
Expressed authority
Implied authority
Apparent authority
Inherent authority
I think we are mostly discussing Formal Authority. Some have indirectly refered to Referent Authority (people that are respected - viewed as knowledgable/objective/reasonable/supportive).
In any organizational culture, the other types of authority play a factor. Referent authority can have as impact as Formal authority.
Knowledge of systems, sytem thinking, knowledge of the requirements (expert authority), formal authority, and referent authority are all needed to be a truly effective representative of a management system.
Regards,
Dirk
T Changes in ISO9001:2015 to the requirements for a management representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Management Representative Requirements and Responsibilities Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Management Representative Requirements - ISO 9001 - 5.5.2 Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W MR (Management Representative) Requirements and Responsibilites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J What are the Requirements for Management Representative? IATF 16949 - Automotive Quality Systems Standard 3
P Responsibility and Document Management Requirements for Management Representative IATF 16949 - Automotive Quality Systems Standard 2
A Management Representative ensures the promotion of awareness of customer requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Management Representative and PRRC (Person Responsible for Regulatory Compliance) ISO 13485:2016 - Medical Device Quality Management Systems 10
L ISO 13485 5.5.2 - Can a consultant be our Management Representative ISO 13485:2016 - Medical Device Quality Management Systems 5
R Who is the Management Representative in my company? ISO 13485:2016 - Medical Device Quality Management Systems 6
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
S Is management representative a temporary post or a job title Management Review Meetings and related Processes 16
S Management representative transition checklist IEC 27001 - Information Security Management Systems (ISMS) 7
J AS9100D Management Representative AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
P How to identify the Management Representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Audit of Management Representative Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
S Quality Management Representative confusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L Who should be appointed as the Management Representative? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9100 Management Representative - Can it be an outsider? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Is a Management Representative still needed for ISO 13485:2015? ISO 13485:2016 - Medical Device Quality Management Systems 7
K Difference between being a Management Representative and being a Lead Quality ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Management Representative is an Accountant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 Management Representative and other Management Staff ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
x-files Matrix for: Established, implemented, maintained (5.5.2 Management Representative) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Do I need to notify the FDA of Management Representative changes? Other US Medical Device Regulations 3
K Management Representative Responsibilities for Multiple Standards Misc. Quality Assurance and Business Systems Related Topics 11
R Distinction between Management Representative vs. Quality Manager Responsibilities IATF 16949 - Automotive Quality Systems Standard 5
eternal_atlas Audit of Management Representative Functions (ISO 9001 & OHSAS 18001) Occupational Health & Safety Management Standards 9
A Management Representative and Information Security Officer for ISO27001 IEC 27001 - Information Security Management Systems (ISMS) 3
M Is Management Representative a loose cannon or am I unnecessarily concerned? Quality Manager and Management Related Issues 6
G Management Representative as Lead Auditor within a Company Internal Auditing 6
T Management Representative - Member of Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
K Selection Criteria for choosing a Management Representative for QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Can one Management Representative operate between two sister firms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 55
P Level of Management Representative in Organization Chart Quality Management System (QMS) Manuals 5
P Level of Management Representative in an Organization Chart Misc. Quality Assurance and Business Systems Related Topics 4
M New QMR (Quality Management Representative) in need of advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V Is a Quality Representative (Management Representative) Designee Required? Management Review Meetings and related Processes 22
K Management Representative is NOT a member of Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 246
K More than One Management Representative? ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Quality Management Representative - Does the QMR HAVE to be a member of management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Who does the Management Representative Report To? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S Work as a QMR (Quality Management Representative) Quality Management System (QMS) Manuals 5
B Small Companies and the ISO 9001 Management Representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
B Management Representative Responsibilities Misc. Quality Assurance and Business Systems Related Topics 17
E AS9100 - Is the Management Representative a Top Manager? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
N Management Representative - Specific Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 46
A MR (Management Representative) also doing Internal Audits? Internal Auditing 27
C Can an MR (Management Representative) be a Document Controller as well? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Z Involvement of Management representative (ISO 3834) in Quality Department Misc. Quality Assurance and Business Systems Related Topics 7
