Management Review - How elaborate should Management Review be?
Tagin
We recently had our 9001:2008 audit and the auditor commented that the management review document was "thin" - that it didn't have much content.
Our mgmt review form is based on the sub-clauses of 5.6.2 & 5.6.3. What we do is have a meeting of the leadership group and discuss each of the areas is sequence and then summarize the results of that discussion on the form in the appropriate section. This ends up being just a couple of sentences per sub-clause. So the auditor is seeing the final results of the discussion, but not the back-and-forth. I'm not quite sure what he expects, though.
I haven't found examples of completed mgmt review documents online, so I'm wondering how detailed or involved some of your mgmt review docs are, or how we could improve this, especially as we move to 9001:2015.
Also, keep in mind that we are a very small company, so its not like there is a vast management structure. :)
Q
QAMTY
First You have to consider all the inputs the standard require.
Second have a check list (a format) mentioning inputs to audience, into the inputs, include
what is needed.
e.g.
a) results of audits,here you have to show the results of past audits
b) customer feedback, to have the client perception
c) process performance and product conformity, having the KPis
d) status of preventive and corrective actions, a table showing CA status, by processes
e) follow-up actions from previous management reviews, showing compromises of last sessions. and so on, and the output/decisions of these, have to be included in the management review meeting, e.g., Suppose CA are not attended, well in the MRM, it is needed a compromise to attend such CA's, and this point will followed-up in the next session.
That is all what you have to do.
Hope this helps
Randy
As long as the minimum requirements are met you've fulfilled your obligations as has management. The management review has to suit your organization/management needs and not those of the auditor. In the end, you're the process owner, not the auditor.
Golfman25
That's basically what we do and never really had an issue.
somashekar
That auditor perhaps is unsure of his role and is driven by some past observations.
If the Management review records touched upon all the elements that the management needs to review., that the inputs and outputs of all specific reviews are in., that the decisions and actions to be taken are said and recorded., ... thin or volume of the review records is not what the auditor has to comment upon.
Look back again to see if any element was missing in the record, and if this was what the auditor meant.
PS: I have seen some rubbish 1 page management review report that just says that all aspects were reviewed and management is happy with the results. I am sure that is not your case.
Coury Ferguson
Moderator here to help
The 3rd Party Auditor doesn't determine what is or is not an organization's management review. As said before, as long as the minimum is captured that is all that is required.
Our Organization just performed the Management Review for the second time (we have determined that twice annually would be our mark). This management review addressed the requirements of the 2015 Version, since we will be upgrading May 2018. It lasted about 4 hours. We addressed the requirements of 2015 Version and some other things that were applicable to our Management System. We also have daily meetings with other entities within the organization everyday. Mainly to determine where we are in regards to status on deliveries, production, and any other concerns. This however, is not officially documented other then the Daily Production report.
So as far as the depth of which your organization performs Management Reviews, as long as you meet the required minimum on reporting that is all you need regardless of what the 3rd Party Auditor may say.
Just my view on this.
normzone
All of the above is good counsel - that said, since I specialize in dysfunctional environments, let me add a couple of points :bonk:
The MRM is a useful place to drag stuff on top of the table that people are avoiding, and get it on the record. Once it's there, it can be difficult to get off, so be aware that this will not add to your popularity index.
Also, commitments made in that meeting should be tracked and followed up on - well-intentioned statements will be made that will not be adequately supported by resources and actions later. More fun to follow up on.
Or you can do the check-the-boxes minimalist version that is often a starting point for many organizations.
Sidney Vianna
Post Responsibly
:applause:
So many organizations go through the motion of a management review, pretending there are no fundamental problems to be fixed, serious customer feedback to be addressed, repeated product returns, etc...
As an auditor, in my previous life, there have been cases where I agreed with the registrant organization that, instead of reviewing "thin" management review records, they would conduct an actual management review and I would observe it. That's an approach that very few auditors and organizations do.
Talk about job protection...:lol: there is no shortage of....
Tagin
Thanks for all your responses.
Yes, we do fill out the inputs & outputs for each sub-clause, so we are meeting the requirements. And we did not receive an n/c for it, so in the end the auditor was OK with it.
Maybe he was hoping for more evidence of the discussion during the meeting. And it may not be a bad idea to include "who-said-what" kinds of comments into the reviews for any later follow-up.
J Periodic review of Documents during management review Document Control Systems, Procedures, Forms and Templates 26
S Scope of management review ISO 13485:2016 - Medical Device Quality Management Systems 5
H Management review IATF 16949 - Automotive Quality Systems Standard 9
J How to evaluate the effectiveness of management review? IATF 16949 - Automotive Quality Systems Standard 2
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
F Need help in IMS management review Management Review Meetings and related Processes 3
M Management Review Inputs ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Risk Management Review ISO 14971 - Medical Device Risk Management 4
G Management Review (integrated system) Management Review Meetings and related Processes 21
M Management review check-list Management Review Meetings and related Processes 3
S Management Review (9.3) - Management Review Minutes/Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
O ISO 13485 - Is management review required before stage 1? ISO 13485:2016 - Medical Device Quality Management Systems 6
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 14
I Management review in conformity assessment standards - Certification Bodies Management Review Meetings and related Processes 6
S Has anybody done IMS - Management Review Meeting ISO 14001:2015 Specific Discussions 8
T Management review meeting workflow ISO 13485:2016 - Medical Device Quality Management Systems 9
Casana ISO 9001 - 9.3.1 Management Review - Attendees in a flat organization Management Review Meetings and related Processes 6
C Management Review Agenda Management Review Meetings and related Processes 20
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 32
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G ISO 9001 - 9.3.1 Management Review - Content and Frequency Management Review Meetings and related Processes 12
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q How to run a Management Review Management Review Meetings and related Processes 10
S List of requirements for Management Review in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D EMS Management review outputs - Strategic direction of the organization Miscellaneous Environmental Standards and EMS Related Discussions 1
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
E Template of a Management Review Agenda or Report in compliance with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
M FDA News USFDA Final Report – MDUFA IV Independent Assessment of FDA’s Device Review Process Management Medical Device and FDA Regulations and Standards News 0
R ISO 9001:2015 9.3 - Required inputs to the management review - Audit Nonconformance Manufacturing and Related Processes 14
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
W Can 2 different sites under different Quality System have a common management review? ISO 13485:2016 - Medical Device Quality Management Systems 4
I Trying to explain some of the Management Review Inputs (AS9100D) Management Review Meetings and related Processes 10
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
H ISO 9001:2015 Cl. 9.3.1 - General Director doesn't participate in Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R University Research Project - Management Review Management Review Meetings and related Processes 17
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 9.3.2.1 - Management Review Inputs - Process Effectiveness and Efficie IATF 16949 - Automotive Quality Systems Standard 14
A How to satisfy the "Interested Party" Management Review Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Z MRM (Management Review Meeting) Template for ISO 9001:2015 Management Review Meetings and related Processes 3
S What defines Top Management after a Merger? Quality Management Review (9.3.1) Management Review Meetings and related Processes 1
armani ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
S Corporate Quality Manager keeping me out of the Management Review Meeting Management Review Meetings and related Processes 28
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D What should be included in Management Review Meeting for ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
P Trending CAPA's in our Management Review Meetings ISO 13485:2016 - Medical Device Quality Management Systems 1
S Risk Management during Contract Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
