Management Review in QS-9000
Marc
#11
What metrics do you have? Scrap? What else? Your management should be setting some type of metric based goals. The question is, how are you doing against your metrics?
So - a quality goal may be a 2% reduction of scrap or a reduction in nonconformances by 10% might be a goal.
What can you quantify with data?
On another level, you might consider process improvements (you set certain goals with an FMEA, for example).
#12
Thanks for the info! Pre-assessment was this week and we came out with no majors! - Thanks to alot of help from this forum.
Gota problem though... Can someone help me out on what some standard quality goals would be?
Kevin Mader
One of THE Original Covers!
#13
Dawn,
What I like to keep in mind when creating, what I refer to as the key business statistics, I try to pick processes with easily measured output (meaningful to the organization). Mark mentioned scrap. While this is captured as dollars in your Cost of Quality reporting, how about the output? How many parts per million defective, what processes feed into the "scrap" process, how much from each, what are the top x reasons contributing to scrap, what are the top x products accounting for a majority of the scrap? The list can be as big as you want it to be. Start small, keep it manageable.
The idea is to determine where you are today (measured output). Each organization is different, so ask your senior managers what they would like to see.
Determine your inputs (contributors to scrap). I would suggest statistical tools here; SPC, Pareto, and the like.
Determine your quality goals (reduce scrap). If you are using SPC, you may be able to determine if the process is capable and predictable. In this case, you will be able to set practical goals. If you do not, then it becomes a more difficult task, and goals are set arbitrarily. This does not mean that your organization shouldn't use arbitrarily set goals. It is important to keep in mind that their is danger in setting arbitrary goals (you don't meet your goal, the group becomes disinterested, or a reverse goal is achieved).
I like to pick a measure or two from key business processes. This way you can determine system effectiveness beyond the scope of internal quality audits and corrective action programs. I hope this helps.
Back to the group...
[This message has been edited by Kevin Mader (edited 03-09-99).]
Marc
#14
Qualification - all have to be done once a year, but not all of them at every meeting if you meet more than once a year.
Marc
#15
Has anyone seen any changes in interpretations by registrars?
Q
Qualiman
#18
If you use a basic form as an agenda and you annotate that form during the meeting you have your evidence. The file Mgmt_rev.pdf in the http://Elsmar.com/pdf_files/ directory is an example of a very simple management review form (agenda). It is for a very small company and is from several years - so you would have to update it and adjust it for your company, but that's not a big deal.
In so far as specifically addressing each element once a year, ask yourself how you do it. Some companies do this by way of dicsussion of presentation of audit findings (internal and external). If at 1 meeting you discuss audits (which should touch on every element - even if no findings were found in an element, that should be stated) you annotate that you did so.
If your auditor then says something like "Well, I see you wrote that you discussed audit findings and you say you touched on every element but how do I know you actually discussed every element..." I would suggest you get ready to request a different auditor. There is a point where things become 'stupid'. To go to the extreme a company would have to record every meeting on audio tape (at least) to catch every detail and to provide proof (evidence) of every detail discussed.
Marc
#19
> > A recent ISO9001 continuous assessment highlighted that our management
> > review was lacking in the suitability (are the systems you have the
> > "right" systems) portion. The problem is the objective evidence. We were
> > told that usually the problem part of the management review is the
> > effectiveness (are your systems operating as they are documented)
> > portion and not the suitability portion.
> > I am looking for how others are fulfilling the suitability portion of
> > the management review and how you provide the objective evidence.
> > Thanks,
> > Ryan Fleser
> > FLESERR -- VTC.COM
Subject: Re: Q:Management Review/O'Leary
Date: Mon, 21 Apr 1997 20:02:35 -0600
In management reviews we address the problem with a statement in the minutes. We believe that suitability is a conclusion that you draw based on the information presented. We may say the system is suitable or we may say it is suitable after some changes have been made.
Our minutes, the quality record, have these defined requirements.
The meeting AGENDA
List of attendees
1. Strengths of the Quality System noted during meeting
2. Weakness of the Quality System noted during the meeting
3. Corrective action assignments made during made during the meeting
4. A statement of the suitability and effectiveness of the documented procedures and instructions
5. A statement of the need to redefine management's Quality Policy, Quality Objectives, and commitment to Quality
6. Objective evidence of effectiveness presented during the meeting
The minutes of the meeting are reviewed and approved by the Quality System Management Representative and the Vice President & General Manager.
Dan O'Leary CQA, CQE, CQM, CRE
picker.com
Alex Grguric
#20
Management Review
QS requires that a yearly review of the quality system is conducted. Our approach is to review each of the elements with the element coordinators and the management representative.
Please give me some feedback on what others do at mgt review meetings.
D ISO 9000 Management Review in a Small Company - Everyone knows what's happening Management Review Meetings and related Processes 33
S Risk Management Review ISO 14971 - Medical Device Risk Management 4
G Management Review (integrated system) Management Review Meetings and related Processes 17
M Management review check-list Management Review Meetings and related Processes 3
S Management Review (9.3) - Management Review Minutes/Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
O ISO 13485 - Is management review required before stage 1? ISO 13485:2016 - Medical Device Quality Management Systems 6
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
I Management review in conformity assessment standards - Certification Bodies Management Review Meetings and related Processes 6
S Has anybody done IMS - Management Review Meeting ISO 14001:2015 Specific Discussions 8
T Management review meeting workflow ISO 13485:2016 - Medical Device Quality Management Systems 9
Casana ISO 9001 - 9.3.1 Management Review - Attendees in a flat organization Management Review Meetings and related Processes 6
C Management Review Agenda Management Review Meetings and related Processes 20
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G ISO 9001 - 9.3.1 Management Review - Content and Frequency Management Review Meetings and related Processes 12
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q How to run a Management Review Management Review Meetings and related Processes 10
S List of requirements for Management Review in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D EMS Management review outputs - Strategic direction of the organization Miscellaneous Environmental Standards and EMS Related Discussions 1
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
E Template of a Management Review Agenda or Report in compliance with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
M FDA News USFDA Final Report – MDUFA IV Independent Assessment of FDA’s Device Review Process Management Medical Device and FDA Regulations and Standards News 0
R ISO 9001:2015 9.3 - Required inputs to the management review - Audit Nonconformance Manufacturing and Related Processes 14
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
W Can 2 different sites under different Quality System have a common management review? ISO 13485:2016 - Medical Device Quality Management Systems 4
I Trying to explain some of the Management Review Inputs (AS9100D) Management Review Meetings and related Processes 10
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
H ISO 9001:2015 Cl. 9.3.1 - General Director doesn't participate in Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Tagin Management Review - How elaborate should Management Review be? Management Review Meetings and related Processes 14
R University Research Project - Management Review Management Review Meetings and related Processes 17
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 9.3.2.1 - Management Review Inputs - Process Effectiveness and Efficie IATF 16949 - Automotive Quality Systems Standard 14
A How to satisfy the "Interested Party" Management Review Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Z MRM (Management Review Meeting) Template for ISO 9001:2015 Management Review Meetings and related Processes 3
S What defines Top Management after a Merger? Quality Management Review (9.3.1) Management Review Meetings and related Processes 1
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
S Corporate Quality Manager keeping me out of the Management Review Meeting Management Review Meetings and related Processes 28
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D What should be included in Management Review Meeting for ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
P Trending CAPA's in our Management Review Meetings ISO 13485:2016 - Medical Device Quality Management Systems 1
S Risk Management during Contract Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
P How CAPA's are trended in Management Review Nonconformance and Corrective Action 1
P Management Review - Performance and Product Conformity question General Auditing Discussions 7
Q Management Review - Alternative methods Management Review Meetings and related Processes 20
N Incompleted tasks from previous management review meeting Management Review Meetings and related Processes 1
N Suggestions for Management Review Presentation Management Review Meetings and related Processes 2
