Management Review: Separate Procedure or Description in Quality Manual?
How do you address Management Review?
  • Quality Manual (only)
    Votes: 16 18.8%
  • Management Review Procedure
    Votes: 22 25.9%
  • Both
    Votes: 38 44.7%
  • I use a simple form (agenda)
    Votes: 9 10.6%
  • Total voters
    85
RoxaneB
#51
Coury Ferguson said:
That is where the procedure or policy would define the intervals.
Thank you for the clarification. Your question about an agenda meeting the intent led me to interpret you saying a procedure/policy was not needed.
Helmut Jilling
Auditor / Consultant
#52
As for your question. It is basically up to you to determine how you want to document the Management Review (via procedure or policy). I have documented the Management Review process in a working procedure.
As for the other discussions. Let me throw this question out there:
Would not an Management Review Meeting Agenda that identifies the parties involved and certain discussions, meet the intent of ISO9001:2000?
Coury Ferguson
Program/Contracts Manager
Any document that identifies your intentions could meet the intent. A procedure, agenda, paragraph in the manual. In ISO, the "level" of the document is no longer an issue. Records must be kept. I actually use the agenda as a template, and enter the records and info into each relevant section.
Coury Ferguson
Moderator here to help
#53
In my company we use an Agenda and the attached document to report the results of the Management Review. Participants names removed
I have had no issues come about with this document.
Antonio Vieira
Involved - Posts
#54
In my humble opinion the way we perform Management Review should be described only in the Quality Manual. Procedures directly related to the QMS should only be those necessary by the standard (6 subjects for ISO 9001 or 7 for ISO/TS).
The quality manual is the right place for us to write all the function of the system.
Last week I made a Quality audit to an organization with a Quality Manual of 5 pages. Is this really a Manual or a brochure?
Today, if I make a QMS, but had no need of registration, I wouldn’t make any of those 6 or 7 procedures. Procedures are just for technical subjects. :rolleyes:
Helmut Jilling
#55
The standard does not limit you to six or seven procedures (4.2.1.c). The very next sentence (4.2.1.d) says, "and any other documents needed..."
Of course a system needs other documents to run, and they can be procedures, work instructions, videos...anything.
The standard is trying to loosen up this legalism, and we keep trying to put it back. Why?
Antonio Vieira
Involved - Posts
#56
One thing I’ve learned during all the years working in the quality management field is that in any organization, the number of documented procedures is directly proportional to the knowledge of the workers doing the activities.
If you have very trained personnel, you need few papers telling them how to perform their work.
If the standard (ISO 9001) didn’t require 6 areas for documented procedures, in my QMS, I wouldn’t have any. Normally I write in the Quality Manual the “policies” related to all requirements of the standard, but I avoid, as much as possible to have documented procedures or instructions.
We are not supposed to teach a civil engineer how to build a house because he learned that at University, the same way we should have papers written to tell a worker how to do his job. What we must have is highly trained personnel.
This is the reason why documented procedures trend to be shorter or even disappear during the evolution of every company. (In some cases they are there, but they are completely useful).;)
Helmut Jilling
#57
I agree with your comments. Some of my clients embed their procedures into their quality manual. I agree they don't have to be separate documents. Even the six (minimum) required ones can be imbedded if it is clear that is how you handle procedures. The level is not the important point.
G
Greg B
#58
I agree in regards to the Competency level. If we have a highly skilled workforce then we do not require as detailed instructions s greenfield company but we must always allow for the lowest common denominator which will always be the 'New Guy'
Here is my Competency slide used to illustrate where Work Instructions etc fit in the scheme of things within our company
Crusader
#59
I voted for the Procedure but somewhat we do both. The Quality Manual only references that we do a Mgmt Review and nothing more. The procedure identifies everything that is ISO 9001 required plus extras that we want to add into the meeting.
Our Agenda follows the exact structure of the procedure and then the meeting minutes are an exact structure of the agenda itemizing everything discussed.
I have found that process flowcharts for Mgmt Review do not "cut it" in our audits - my procedure flies thru audits. In fact, the auditor almost never has any questions to ask. He just sits there takes notes and we're done. It's awesome! All tap-dancing has been eliminated. :applause:
K
kirilll
#60
I use a 1 page process map (detailed flowchart) of the management review process that clearly shows the required and desired inputs/outputs and the link to CAPA and CI. In conjunction with the Management Review record (agenda) that incorporates followup, assignment, metrics, etc., the process has really proven to be consistent at every client and the third party auditors rarely have any questions or comments. Clients love it and it make me look really good.
Take a look at *** link removed *** or send me an e-mail if you want more info or have any questions or comments.
Note: Contact information is available in user profile.
S Risk Management Review ISO 14971 - Medical Device Risk Management 4
G Management Review (integrated system) Management Review Meetings and related Processes 17
M Management review check-list Management Review Meetings and related Processes 3
S Management Review (9.3) - Management Review Minutes/Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
O ISO 13485 - Is management review required before stage 1? ISO 13485:2016 - Medical Device Quality Management Systems 6
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
I Management review in conformity assessment standards - Certification Bodies Management Review Meetings and related Processes 6
S Has anybody done IMS - Management Review Meeting ISO 14001:2015 Specific Discussions 8
T Management review meeting workflow ISO 13485:2016 - Medical Device Quality Management Systems 9
Casana ISO 9001 - 9.3.1 Management Review - Attendees in a flat organization Management Review Meetings and related Processes 6
C Management Review Agenda Management Review Meetings and related Processes 20
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G ISO 9001 - 9.3.1 Management Review - Content and Frequency Management Review Meetings and related Processes 12
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q How to run a Management Review Management Review Meetings and related Processes 10
S List of requirements for Management Review in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D EMS Management review outputs - Strategic direction of the organization Miscellaneous Environmental Standards and EMS Related Discussions 1
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
E Template of a Management Review Agenda or Report in compliance with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
M FDA News USFDA Final Report – MDUFA IV Independent Assessment of FDA’s Device Review Process Management Medical Device and FDA Regulations and Standards News 0
R ISO 9001:2015 9.3 - Required inputs to the management review - Audit Nonconformance Manufacturing and Related Processes 14
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
W Can 2 different sites under different Quality System have a common management review? ISO 13485:2016 - Medical Device Quality Management Systems 4
I Trying to explain some of the Management Review Inputs (AS9100D) Management Review Meetings and related Processes 10
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
H ISO 9001:2015 Cl. 9.3.1 - General Director doesn't participate in Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Tagin Management Review - How elaborate should Management Review be? Management Review Meetings and related Processes 14
R University Research Project - Management Review Management Review Meetings and related Processes 17
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 9.3.2.1 - Management Review Inputs - Process Effectiveness and Efficie IATF 16949 - Automotive Quality Systems Standard 14
A How to satisfy the "Interested Party" Management Review Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Z MRM (Management Review Meeting) Template for ISO 9001:2015 Management Review Meetings and related Processes 3
S What defines Top Management after a Merger? Quality Management Review (9.3.1) Management Review Meetings and related Processes 1
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
S Corporate Quality Manager keeping me out of the Management Review Meeting Management Review Meetings and related Processes 28
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D What should be included in Management Review Meeting for ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
P Trending CAPA's in our Management Review Meetings ISO 13485:2016 - Medical Device Quality Management Systems 1
S Risk Management during Contract Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
P How CAPA's are trended in Management Review Nonconformance and Corrective Action 1
P Management Review - Performance and Product Conformity question General Auditing Discussions 7
Q Management Review - Alternative methods Management Review Meetings and related Processes 20
N Incompleted tasks from previous management review meeting Management Review Meetings and related Processes 1
N Suggestions for Management Review Presentation Management Review Meetings and related Processes 2
S Quality Assurance Manager involvement in Management Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
