Manager's version of the process contradicts personnel running the process
Q
qualityboi
While auditing a process (sorry I can't be more specific as people from my company may see this), the manager's version of the process flow was different than what was significantly different than two technicians that I interviewed on the floor especially for the mechanism for out of control data points, spc rules. The process is not documented, and since there was conflicting information I am going to write this up. I am just wondering how to word it so as not to make the manager look dumb or not to get the technicians in trouble...:(
MIREGMGR
Just write it up for being undocumented. Then the next time it's audited, either the way it's actually done or the manager's version won't agree with the documentation...unless the process of documenting what they're doing now prompts the manager and the techs to get coordinated.
RoxaneB
Unless there is a requirement for the process to be documented, issuing a nonconformance on the lack of a document wouldn't add much value...in my opinion.
I would suggest writing the nonconformance in such a way to demonstrate that the lack of standardization within the process runs the risk to negatively impact the ability to state that product meets requirements or that the process is under control.
Indeed, the lack of documentation is not the issue. The real kicker would be to discover whose version was more effective! One of the things people do is 'make up' for parts of the managers version, where they find it's not effective.
You did a good job of detecting the difference. To be a great auditor, you have to find out which version gives the best results!
Nice work!
julsbear
The writeup should be for the discrepancy in understandingof how the process work or is practiced. This would highlight the need for this processto be documented. As part of the documentation process it can be decided what is needed to accomplish what is intended. Part of "best results" could be:
1) What meets the requirements
2) What is more stable.
3) If the requirement is one sided, what gives the more desirable result. (Yield, purity etc.)
From experience, the manager may have seen a very short term result meeting criteria 1. The techs may be doing things that deal with all three.
Only when you know under which conditions you are/have run and track the results, can you answer which is better.
This statement, in a nutshell, is what all auditors should be looking for to determine what's effective. This is the value in an audit finding that assists management to identify what actions are necessary in response to the audit finding, much, much more than just telling that 'we didn't follow the process'.
What a great point, Julsbear - thanks for making it!
Wes Bucey
FWIW:
My take on the situation is slightly different:
  1. There is an undocumented process - it gets an NC
  2. There are two versions of the process - it is NOT the auditor's place to determine WHICH is better, merely to point out the obvious: the variance "could" lead to producing nonconforming product. Also obvious, manager did not have a process for affirming the operators agreed with his version of a process and did, in fact, implement the process according to his version.
  3. An Opportunity for Improvement (OFI) could ALSO be generated, describing the opportunity to conduct Design of Experiment exercises to determine the optimal process [not limited to the two known processes]
An interesting set of side issues:
(grist for a management review, NOT an auditor report):
  1. Did operators EVER follow the manager's method?
  2. Did the manager change, NOT the operators?
  3. If yes to either (1) or (2), when and why did they change?
  4. If no, was the training adequate and accurate??
  5. Should the training method be changed?
  6. Is either method the viable one?
  7. If not, what is necessary to determine the most viable and optimal method?
This situation would make for an excellent case study on determining root cause!
RoxaneB
Wes Bucey said:
[*]There is an undocumented process - it gets an NC
Where is the need for a document? I will grant you that the inconsistent approach towards the process leads one to believe that a document would be great, but it could be something as simple as determine the correct method, generating a one-point lesson and getting back to business.
In today's businesses - which are demanding efficiency and effectivess - a documented procedure may not always be the best solution.
Wes Bucey said:
[*]There are two versions of the process - it is NOT the auditor's place to determine WHICH is better, merely to point out the obvious: the variance "could" lead to producing nonconforming product. Also obvious, manager did not have a process for affirming the operators agreed with his version of a process and did, in fact, implement the process according to his version.
Who's to say the manager's version is the correct version? :cool:
That being said, I agree that the lack of consistency in the process should be the focus of the nonconformance as it may increase the risk of final product and/or overall process not meeting requirements.
Wes Bucey said:
[*]An Opportunity for Improvement (OFI) could ALSO be generated, describing the opportunity to conduct Design of Experiment exercises to determine the optimal process
A nice idea and it may get the team thinking about their overall process, however, smaller shops may not have the resources available at this time to implement such exercises.
I don't think any one here will disagree with that, but I would really hate to see the root cause attributed to the lack of a document. That simply skims the surface of the situation.
Wes Bucey
If the root cause investigation STOPPED at "lack of a document," that would be a tragedy. That would be almost as bad as "operator error." The five Whys comes in handy in cases like this.
There may be lots of reasons to issue (if one were so inclined) an NC:
if I were looking to nitpick, I'd probably start with
7.5.1 Control of production and service provision
The organization shall plan and carry out production and service provision under controlled conditions.
Controlled conditions shall include, as applicable,
a) the availability of information that describes the characteristics of the product,
b) the availability of work instructions, as necessary,
c) the use of suitable equipment,
d) the availability and use of monitoring and measuring equipment,
e) the implementation of monitoring and measurement, and
f) the implementation of product release, delivery and post-delivery activities.
It seems to me an auditor could make a de facto argument that his observation of a discrepancy in understanding the details of a work process indicates a lack of controlled conditions in product realization. Written work instructions may not be necessary, but it is obvious there is a disconnect in communication of some sort when operators perform processes differently from what management has planned. It may or may not matter to the end product whether one process or the other is used or even if one is more efficient than the other, but the lack of a consistent process bears further investigation.
If the auditor is kind and not looking to play "gotcha," he writes an OFI. My question is "Does the OFI hit management review with the same impact as an NC?"
Alternately, one might refer to
7.5.2 Validation of processes for production and service provision
The organization shall validate any processes for production and service provision where the resulting output cannot be verified by subsequent monitoring or measurement and, as a consequence, deficiencies become
apparent only after the product is in use or the service has been delivered.
Validation shall demonstrate the ability of these processes to achieve planned results.
The organization shall establish arrangements for these processes including, as applicable,
a) defined criteria for review and approval of the processes,
b) approval of equipment and qualification of personnel,
c) use of specific methods and procedures,
d) requirements for records (see 4.2.4), and
e) revalidation.
In my opinion, these requirements are not limited to products which may have "hidden" nonconformances.
As I inferred, "rogue operators" are only a symptom, not a root cause. The management of the organization does not have an apparent, auditable process to assure its processes are performed consistently.
Just because I did not act as a "well-trained, well-mannered auditor" by citing the "shalls" in my first post doesn't mean I'm at fault - Deming suggests you blame my manager!:lmao:
RoxaneB
Wes:
With all due respect, I did not expect you to cite the shall's. I am certain, however, that they will be appreciated by the original poster who is questioning the lines along which a nonconformance may be written.
That being said, the availability of work instructions is "as necessary." As auditors, do we have the right to say what is necessary? The answer to this is, in my opinion, we have that right only when the risk posed by the lack of documentation is high. As auditors, our role is not only to assess the organization's level of conformance to requirements and the effectiveness of the system, but we are now to assess the level of risk of the gaps. This allows the organization to prioritize their actions and resources.
Without knowing the details of the original poster's organization and the impact that the provided example has on both the ability to meet requirements and control the overall process, it is impossible for Cove Members to provide a black-and-white answer.
Phrasing a nonconformance such that the potential risks are highlighted (i.e., a solution will add value to the organization's bottom line) will probably generate the most attention from the organization. The nonconformance can not simply be worded as "The process for xxx is not documented." Tying the appropriately worded finding to Clause 7.5.1 would ensure that everything is written up in a suitable manner and initiate - hopefully - a root cause analysis that goes to the right depth.
S Calibration Manager - Version 3 - Field for Calculation of Limits question Calibration and Metrology Software and Hardware 0
S Quality manager considering data science Quality Manager and Management Related Issues 19
K IMDS Chemistry Manager RoHS, REACH, ELV, IMDS and Restricted Substances 0
C Quality Manager vs Warranty (service) Manager - Authorities & Responsibilities Customer Complaints 2
N ... and some have greatness thrust upon them - Training for novice QA manager ? Training - Internal, External, Online and Distance Learning 6
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F Position of Quality Manager - Can the organization's Quality Lead be shown as Quality Manager of the lab as well? ISO 17025 related Discussions 5
T Change in BRH (Brazilian Registration Holder) Technical Manager Other Medical Device Regulations World-Wide 2
T New role Quality Manager IATF 16949, new company, advise how to get started IATF 16949 - Automotive Quality Systems Standard 2
CCaantley Stepping Down from my quality manager position soon After Work and Weekend Discussion Topics 18
M QMS Efficiency KPI as a Manager. IATF 16949 - Automotive Quality Systems Standard 7
Sam Lazzara Notified Body CE Project Manager - Worst job ever? EU Medical Device Regulations 6
A ISO 9001 Help - New Quality Manager - Upper Management Support Issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
Kronos147 Quality Manager's Role in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Certified Manager of Software Testing (CMST) Certification Exam Career and Occupation Discussions 4
S Corporate Quality Manager keeping me out of the Management Review Meeting Management Review Meetings and related Processes 28
J Configuration Manager's Duties - AS9110 or AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q Supplier Accountable Manager Suspended - FAA 8130's while he is suspended? Federal Aviation Administration (FAA) Standards and Requirements 1
I Auto Industry Resume Template for a Quality Manager Career and Occupation Discussions 2
D Can the Plant Manager be our ISO Representative and an Internal Auditor? Internal Auditing 26
F Quality Manager - Conflict of interests in organisational structure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Quality Assurance Manager ? Next Steps? Quality Manager and Management Related Issues 10
S Quality Assurance Manager involvement in Management Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L What are some SOPs that a Quality Manager should have? Document Control Systems, Procedures, Forms and Templates 6
P Leadership Standards - New job as Quality Manager Quality Manager and Management Related Issues 9
K New Quality Manager Role Quality Manager and Management Related Issues 13
C Salary for a CI Manager Career and Occupation Discussions 7
A Shall I apply for this job position (Quality Manager)? Career and Occupation Discussions 5
Q QA Manager Responsibilities Career and Occupation Discussions 9
M Manager IMS (9001, 14001, 18001) Position in Organisation Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
V Manager wont take the lead ....Leadership wont provide clarity....what to do? Quality Manager and Management Related Issues 6
S R&D Documentation Manager Responsibilities Job Description Career and Occupation Discussions 1
J Lead Auditor and Quality Manager - Conflict of Interest? Career and Occupation Discussions 4
T What is the difference between Solid-Line Manager and Dotted Line Manager Career and Occupation Discussions 5
R QA Manager and Disciplining Employees for not following Processes Quality Manager and Management Related Issues 28
M Can a Quality Manager be a Lead ISO 9001 Auditor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
L Quality Manager wants Internal Auditor to softgrade the findings - What shall I do? Internal Auditing 23
K What liability does the QA Manager/Management Rep hold? (US FDA environment) Career and Occupation Discussions 4
R Root Cause Analysis of Audit Findings - New Quality Manager Quality Manager and Management Related Issues 20
J Quality Manager's role in Customer and Supplier Complaints Customer Complaints 10
P Contract up in 1.5 months - How to approach my manager to discuss the future Career and Occupation Discussions 15
D Director vs. Manager - Roles in RA in a Medical Device Company ISO 13485:2016 - Medical Device Quality Management Systems 5
Y New Quality Manager looking for Tips and Quality Methodologies Quality Manager and Management Related Issues 8
P General Manager jumps down to directly contact my staff Quality Manager and Management Related Issues 7
R KRA's (Key Result Area) for a QA Manager Quality Manager and Management Related Issues 8
K What would you do in the first 90 days of a new job as the Quality Manager Quality Manager and Management Related Issues 33
T QMR, EMR, OHSASMR should be manager or management team? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
1 Quality VP/Manager left - Educating his replacement Quality Manager and Management Related Issues 9
F What Training should a Quality Manager have? Training - Internal, External, Online and Distance Learning 32
L Product Manager vs. Quality Manager: Who is right? Misc. Quality Assurance and Business Systems Related Topics 14
