Mandatory documents vs shall "something" but without mandatory documents
sistoiv
I had a theoretic discussion with the CB’s auditor on a structural issue of system standard. When there is a reference to the documented information this must be interpreted in a general way (for the clause in object) or only specific for the specific sub-requirement?
Example 4.4 b). There is no reference to documented information for a process map or similar, so it seems that I could simply determine and "tell" it. But 4.4.2 speaks about process documentation so, for the auditor, the obligation for documented processes map is there. Not in my opinion.
Another example. 6.2.1 says that the objectives must be documented but the planning (6.2.2) could also be carried out without having documented the plan for implementing the objectives. The auditor says that however there is 6.2.1.
Another isssue.
4.1, 4.2, 6.1. Standard say “shall” but no document is mandatory. The organization can also show them verbally and in fact, without obligation of documents. If a CB's auditor gives to me a NC I could do reservation to CB, ISO 9001 does not claim documented information about these clauses.
Who's right?
bkirch
I am by no means going to claim to be an expert. My interpretation of all of the requirements are that if they state that a documented process or information is required, then you need to have some documentation. If the requirement states a "shall" but does not mention a requirement for a documented process or information, then you have to be able to demonstrate that you meet the requirement, but it doesn't necessarily have to be documented. However, I have found that sometimes it is a little tricky to demonstrate that you meet a requirement if you don't have some type of documentation, even if it isn't required.
sistoiv
Thanks OK, but why does not ISO clarify these ones?, otherwise there will be always discussions and misinterpration.
However, for example, you can ask to me which are my processes, sequence and interactions and I answer to you, where is the matter?
Randy
As long as the standard or something you write down doesn't specifically require documentation, you're right. I'm a CB auditor, that's all I do and I've been doing it 19 years and I'm telling you that it doesn't matter squat what I like or want, it's only about what's required. Now that being said, if I can demonstrate through objective evidence a lack of effectiveness or control without something being documented I might possibly issue a NC but I've only done that on very few occasions.
tony s
Information Seeker
Not really. Clause 4.4.2 begins with "To the extent necessary". So, it's left to the organization to determine necessity of maintaining/retaining documented information - unless specifically stated by ISO 9001 (on other clauses).
I'd agree that verbal explanation of the sequence and interactions of the processes can satisfy 4.4.1b without the need of a document. ISO/TS 9002:2016 has this statement as my reference:
"when determining the sequence and interaction of these processes, the links with the inputs and outputs of the previous and subsequent processes should be considered; the methods for providing details of the sequence and interaction of the processes depends on the nature of the organization; different methods can be used, such as retaining or maintaining documented information (e.g. process maps or flow diagrams), or a more simple approach, such as a verbal explanation of the sequence and interaction of the processes"
Randy is right in telling us it doesn't matter what a CB want, it's only about what is required. CB should be guided by the International Accreditation Forum auditing practices guidance in evidence collection (see this link) as specified below:
"Auditors should be aware that objective evidence does not necessarily depend on the existence of documented information, except where specifically mentioned in ISO 9001".
Big Jim
Imagine trying to document organizational knowledge (7.1.6). It would be an impossible task to try to capture all the collective knowledge pertinent to the organization. The faulty logic of the OPs auditor would have you trying to do that anyway.
sistoiv
Thanks to all, suitable (not only adequate) comments.
I'm sorry but for quite some time when a CB's auditor starts to say " ISO Xxxx requires...." but ISO Xxxx doesn't include explicity that requierement, I threatean to claim formally. The proof that the auditor was trying is that it almost always ends suddenly. It is demeaning
John Broomfield
Auditors should never argue but don’t tell them that rule!
...and by sticking to the facts they don’t need to.
In this case just present your copy of the standard and ask “please show me the requirement”.
K Mandatory Documents for EU authorized Representative under MDR CE Marking (Conformité Européene) / CB Scheme 8
Sidney Vianna Interesting Discussion Hello IAF. Are you listening? Please explain the inconsistency in your IAF Mandatory Documents (2019) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
N IATF 16949 - Mandatory Corporate Documents IATF 16949 - Automotive Quality Systems Standard 10
Marc IAF Mandatory Documents (MD Series) - Required to be used by certification bodies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Marc IAF (international accreditation forum) - Mandatory Documents (MD Series) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
Sidney Vianna IAF Mandatory Documents (MD Series) as of May 2019 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 16
L Is it mandatory to update all controlled documents if a company gone through a merger ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Disposal of obsolete documents - Mandatory in ISO9001:2000 to keep previous versions? Document Control Systems, Procedures, Forms and Templates 7
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
earl62 What is the best way to control special characteristics in Control plan? Is it Mandatory to have SPC for IATF 16949? IATF 16949 - Automotive Quality Systems Standard 7
A Is it mandatory to obtain ISO13485 certificate prior to CE marking? EU Medical Device Regulations 8
K Is UDI (Unique Device Identifier) symbol mandatory under EU MDR? EU Medical Device Regulations 1
K Class III Kit Box - Are translations mandatory under EU MDR? EU Medical Device Regulations 5
M When is EN 62133-1 (new version i.e. IEC 62133:2017) mandatory in EU Other ISO and International Standards and European Regulations 0
O Is it mandatory for Medical Devices to work properly after dielectric strength tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M What is PESTLE Analysis and is it mandatory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
D Is Human Factors testing mandatory for a 510(k) submission? Human Factors and Ergonomics in Engineering 16
M Informational Health Canada – Mandatory reporting requirements for hospitals Medical Device and FDA Regulations and Standards News 0
Sidney Vianna The mystery of an IAF Mandatory Document disappearance ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
R US FDA Mandatory Labelling contents for an OTC medical device US Food and Drug Administration (FDA) 0
K Is Compliance Testing of IEC 60601-2-63 mandatory for Europe - Dental X-Ray machine CE Marking (Conformité Européene) / CB Scheme 3
S Are Defibrillator Protection and Pacemaker pulse detection features mandatory as per IEC 60601-2-25 or 2-27...? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
C ISO 7010 m002 mandatory action - Color requirements on Packaging IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K Is Defib Protection mandatory for wearable ECG? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
A Policies Mandatory or essential for ISO 27001 implementation IEC 27001 - Information Security Management Systems (ISMS) 6
S Is it mandatory for a Calibration Lab to be ISO 17025 accredited? General Measurement Device and Calibration Topics 7
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure Imported Legacy Blogs 0
T EASA P 145: What mandatory information should on the purchase order of the customer ? EASA and JAA Aviation Standards and Requirements 2
F Is IEC 60601-1-11 recommended or mandatory for devices manufactured after June 2013? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Are Product Special Characteristic(s) Mandatory? IATF 16949 - Automotive Quality Systems Standard 4
S Is it mandatory to provide the results of the validation report in handwriting? ISO 13485:2016 - Medical Device Quality Management Systems 5
A Type of evidence for Mandatory procedures 4.4.2 A ad 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Richard Regalado ISO/IEC 27001 Mandatory Documentation Checklist IEC 27001 - Information Security Management Systems (ISMS) 1
K Mandatory Electrical Safety Tests - Regular Production Line IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
R Is there a mandatory medical device warehouse standard for europe? EU Medical Device Regulations 3
J Draft Guidance document compliance mandatory to avoid a RTA? Other US Medical Device Regulations 2
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Is it mandatory to revise MSDS every three years? ISO 14001:2015 Specific Discussions 3
N Is IEC 62353 Mandatory for Medical Devices? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
T ISO 9001:2008 Mandatory Procedures in Quality Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
E Is cGMP Training Mandatory? US Food and Drug Administration (FDA) 12
J Can the mandatory procedures of ISO 9001-2008 be documented within one procedure? Document Control Systems, Procedures, Forms and Templates 5
D FDA required (mandatory) Signed Records Qualification and Validation (including 21 CFR Part 11) 1
T Is the use of Control Charts Mandatory or Optional? ISO 17025 Requirements ISO 17025 related Discussions 6
M Are there any Mandatory Processes required in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
