As stated earlier, the PPAP book specifies DFMEA, if responsible, and PFMEA are submitted as a part of the Level 3 (page 18 4th ed.). I will approach this issue from the prospective of the buying customer (to whom you are delivering the PPAP) and utilizing the entire quality system verses a specific set of unfounded desires such as the D/P-FMEA contains confidential information.
Quality system issues to consider are document control, 2nd party auditing, due-diligence and litigation.
● Document Control: There can only be one original, master document in a controlled system. For purposes between the customer and supplier the original, master document is the official PPAP copy. It is maintained and stored by the customer, and the supplier references the copy supplied via the PPAP.
● In case of litigation, the customer will be under investigation prior to the supplier. The plaintiff will examine the customer’s documentation prior to the supplier’s documentation. The plaintiff will be searching for evidence of due-diligence. During that search, they will examine the customers DFMEA for thoroughness of functions (product specifications) and failure mode analysis. They will then examine the next level down DFMEA’s to ensure requirements were effectively cascaded and the effects of the lower‑level failures modes on the higher-level system are understood. If this lower‑level DFMEA describes the supplier’s component (or sub-system, system, …), I, the customer, will have to show MY DUE-DILIGENCE. Thus, I, the customer must control the original, master DFMEA document.
● Notes on proprietary DFMEA information: The functions listed in a well-performed, proper level DFMEA are the specification requirements (fit, form, function) for the item being analyzed, they CANNOT be proprietary. If the supplier perceives proprietary information is exposed, what information will the supplier not [FONT="]reveal[/FONT]? How it will fit in the application? What all the functions are?
Ridiculous!
However, some of the methods to reduce a cause’s risk may be proprietary (very low priority). But these are contained in a lower-level DFMEA that is NOT submitted in the PPAP. Therefore, if you feel that as a supplier you are revealing proprietary information, you has not defined the scope of your DFMEA’s properly.
● Requirements for the (PPAP) PFMEA come from the special characteristic items identified in the (PPAP) DFMEA whose risk can be mitigated through process control. If the supplier is responsible for the supplied product’s DFMEA, they can use this DFMEA as the document to develop the PFMEA requirements. If the customer is responsible for the supplied product’s DFMEA, they should communicate the special characteristic items identified in their DFMEA via a “Design FMEA Results” document. This eliminates the document control issue identified above.
In either case, these requirements, failure modes, potential effects and causes, therefore, CANNOT be proprietary information. That leaves the control functions as the only points of potential PFMEA proprietary information.
The potentially proprietary control methods (and I have never seen more than four in any PFMEA) can then be identified via process procedures, equipment property tags, or other methods.
● For the same reasons discussed above, this PFMEA is always included in the PPAP.
When I as a customer, 2nd party auditor, audit the supplier, I will use the PPAP FMEA documents to perform the audit. What else can I use? The Supplier’s version which is subject to well meaning, but customer unapproved, changes? These are the questions the 3rd party auditor should ask before using a supplier supplied, proprietary PFMEA.
I have performed several hundred DFMEA’s and PFMEA’s in several industries and sizes of companies, and implemented quality systems in companies whose sizes ranged from $15 million to several $ billion in sales.
Joe Adams
Business and Quality Consultant
Ridiculous!
One alternative to having the cake and eating it too is to make the PFMEA and Control Plan vague enough where you do not divulge any 'proprietary' information. …
For example I can be very vague about my trademarked & patented electro-plating process: I receive the parts, I clean them, I plate them, I cure them then I package them. in the cleaning process I could have variations in temperature, therefore I use PLC controllers to monitor & adjust the temperature. Did I disclose anything proprietary so far ?!? Can anyone take this info and duplicate my process? I highly doubt it.
Joe Adams
