Manual Tensile Testing Pull Rate Speed
davidmxli
Hello
I don't know if this is the right place to post this question, but I hope I can get some assistance :)
Here's the thing: I want to order a manual lever-operated tensile tester (you can see picture attached), so we can test our wires with crimped terminals, but from IPC-WHMA-A-620B, I have a requirement that states that the speed for the pull rate shall be ≤1 inch/minute.
Now, my question is... is there any way so I can measure/control that the speed complies to that requirement and that the pull rate is constant (or at least, always under 1 in/min per the IPC requirement).
Any help would be hugely appreciated.
Thanks in advance!
Marc
Since no one else has replied, I can't say for sure but my bet is since it is a hand device there would be no way to control rate of speed of the pull. BUT - I have only used automatic electric powered tensile testers so I am only guessing.
Have you checked the operator manual?
davidmxli
Hi Marc,
Yes, i've read the manual and the specifications, and what they mention is that the travel rate is 3" [76.2 mm]/lever revolution, but honestly, i can't figure it out how to measure that, and also if there is any way so I can lower that travel rate to ≤1 in.
I
isoalchemist
:2cents:I don't think you can get there with that equipment. The revolution will give you three inches of travel, hence you would need to turn it at a rate of 1/3 a revolution/min. Not something you could do consistently manually which is what you need.
davidmxli
Yeah... that what I was thinking :(
Just wanted to know if, by any chance, someone had figured it out how to do it
I'm already looking for quotations on motorized testers, those have the capacity to select the speed/pull rate, only problem is that they are way more expensive than the manual ones.
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
A How to prepare QMS manual for purchasing department Quality Management System (QMS) Manuals 5
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
F Quality manual for trading company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
M User manual / instructions for use for class II device always required? Medical Device and FDA Regulations and Standards News 3
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
S Maintaining Equipment Records - We use a manual system ISO 17025 related Discussions 1
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
T Something between a manual and a procedure? Document Control Systems, Procedures, Forms and Templates 9
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
K EU MDR Art. 22 - Device + insertion pack - User manual and Labeling EU Medical Device Regulations 4
M Quality Manual for 2nd site Quality Management System (QMS) Manuals 3
M Informational EU – MANUAL ON BORDERLINE AND CLASSIFICATION IN THE COMMUNITY REGULATORY FRAMEWORK FOR MEDICAL DEVICES Version 1.22 (05-2019) Medical Device and FDA Regulations and Standards News 2
dgrainger Informational Updated Borderlines manual - Version 1.22 (05-2019) EU Medical Device Regulations 0
Ashland78 IATF 16949 9.2.2.1 - How often do we have to audit entire IATF Manual IATF 16949 - Automotive Quality Systems Standard 4
M Medical Device News Manual On Borderline And Classification In The Community Regulatory Framework For Medical Devices Medical Device and FDA Regulations and Standards News 0
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
eule del ayre Manual Inventory System - Problem is discipline of the employees Lean in Manufacturing and Service Industries 7
J Manual Vision CMM Calibration General Measurement Device and Calibration Topics 7
M Medical Device News Medical Device Borderline and Classification Manual 1.20 - October 2018 EU Medical Device Regulations 0
S "Process Verification" of manual process Design and Development of Products and Processes 2
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
D Laboratory Manual ISO/IEC 17025 Example wanted ISO 17025 related Discussions 2
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
A Supporting Site Quality Manual and References Requirements IATF 16949 - Automotive Quality Systems Standard 14
shrutisancheti EU User manual / operator manual / service manual guidance document(s) CE Marking (Conformité Européene) / CB Scheme 2
K EMS Manual - External auditor expectations Miscellaneous Environmental Standards and EMS Related Discussions 5
M ISO13485 Documentation packs (manual, procedures, forms etc) ISO 13485:2016 - Medical Device Quality Management Systems 3
L ISO 9001 - 2015, is the Quality Manual needed? Please advise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
R ISO 9001:2015 Transition Quality Manual Update - Redundant Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P AS9100 rev D Quality Manual wanted - 2017 Quality Management System (QMS) Manuals 4
B Integrated Quality Manual ISO 13485:2003 ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 6
J TOPCON PP-70 Optical Comparator - User Manual Needed General Measurement Device and Calibration Topics 0
I Concerning procedures within Quality Manual ISO 17025 related Discussions 10
