Hello all,
First time poster, long time reader
I'm a manufacturing/production engineer and my enquiry is more directed towards manufacturing processes and determining if their associated contamination is within acceptable limits. Hope someone can help me out... here it goes...
The company I work for is diversifying into the medical device industry and is currently working together with an Australian University to develop an electro-mechanical device intended for the Orthopedic sector.
The device will be used in a surgical environment and may come into contact to exposed tissue of the patient during use. A recent audit of our facility dictated our cleanroom must meet at least Class 100,000 (this will not be a problem from what we can see).
We intend to clean all moulding plastic components prior to assembly and sterilise the finished assembly using a third party (sub-contractor). The device requires me to screw together (self tap) & ultrasonically weld/stake plastic components within the assembly. I'm very familiar with these processes from prior experience and understand they can generate debris (contamination). I've seen examples online with processes such as these used in cleanrooms. I would like to know how to determine if a particular assembly equipment is suitable to be used to manufacture a device of this caliber?
Are there any guidelines/standards/recommendations out in the field which can help quantify the level of contamination generated by a particular assembly processes and determine if it is acceptable to use or not. If debris is generated are extraction units required..etc?
Much of the litrature I've examined has only focused on methods to maintain/improve air quality in cleanrooms but nothing as specific as this.
Appreciate any help, thanks in advance!
