Manufacturing Equipment Pressure Gages Calibration Requirements
MACIEK
Hello everyone.
Durring a recent aoutdit i have been qriten up by an auditor for not calibrated preasure gages on our manufacturing equipment.My question is do the have to be calibrated?
Thank You.
N
noboost4you
Re: Preasure Gages Calibration
Are the pressure gauges instrumental to your product? What type of manufacturing equipment are they on?
Does the equipment only produce acceptable results between a certain pressure range? If so, then the pressure gauge reading will need to be verified.
qusys
What does report your internal procedure related to calibration?
Are these pressure gages necessary to assure valid results?
What are the requirements of the monitoring and measurement process to assure the conformity versus them?
Do you have a Control plan?
pls, tell us and explain more in detail about non conformity.
Hello everyone.
Thank You.
JoCam
Re: Pressure Gages Calibration
If you have procedures documenting the pressure settings required as a result of performing process validation, or you record the pressures during production and utilise the data then yes, you do need to ensure that they are calibrated.
MACIEK
Quote from the Report
"Pressure gages on forming machines are not calibrated or identified as not requiring calibration"
Well gages in question are part of a bending machine. The reading is taken form the gage by the operator as reference only. Is there a standart that would call out thta the gages need to be calibrated. And if yes taking apart the machine each time the gage needs to be calibrated would be insane.
ScottK
Not out of the crisis
Well gages in question are part of a bending machine. The reading is taken form the gage by the operator as reference only. Is there a standart that would call out that the gages need to be calibrated. And if yes taking apart the machine each time the gage needs to be calibrated would be insane.
Many of us have run into this before.
You can go bananas labeling "for reference only" and it's unwarranted.
There was even a Dilbert or two about this.
I would consider putting a line in my calibration procedure that says "all gauges without calibration labels are not calibrated and are for reference only"
And then make sure they do not appear in my calibrated equipment list/database.
What standard are you being audited to?
And more importantly is there anything in your current procedures that requires all gauges to be labeled and that's what the auditor is writing the finding against?
JoCam
Then all that leaves you to do is mark all the pressure gauges up as "FOR INDICATION ONLY".
Marc
OK - Here is the scoop - If something such as pressure is critical to a process the gage that measures it has to be calibrated. For example, in injection molding typically pressure, temperature and hold time are typically critical to the process. Because they are considered critical to the process, gages that measure these have to be calibrated. One way to know what critical parameters are (or should be) on the Control Plan.
In the above example, I would not think pressure would be a critical parameter in the bending process. But, I'm not experienced enough in bending metal to know for sure. Others may be able to add their :2cents: about pressure as a critical parameter in the bending process.
N
noboost4you
How do you bend metal? You apply pressure...I'd say they would need to be calibrated.
Marc
You could very well be correct, but I wouldn't think so unless the rate of bending is a critical characteristic of the process. But as I say, I'm not knowledgable in bending of different metal alloys, not to mention differences such as tubes vs. solid metal.
Like I say, to me whether an aspect of a process is *critical* should be determined during the design of the process, and if it is critical it should be on the control plan. I would depend upon the designer(s) of the process to determine what is critical and what is not.
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Equipment Mobility - Transfer of manufacturing lines to a different location Qualification and Validation (including 21 CFR Part 11) 5
D Verification that Manufacturing Equipment has maintained a Validated State Design and Development of Products and Processes 11
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
L Medical Device Manufacturing Equipment Design Other Medical Device Related Standards 2
jkuil Calibration before and after relocation of GMP manufacturing equipment Calibration Frequency (Interval) 7
G Prototype Manufacturing Equipment - Validate or not to validate? Quality Manager and Management Related Issues 2
D Moving Manufacturing Equipment from USA to Europe - Is CE certification required?? CE Marking (Conformité Européene) / CB Scheme 12
O Requalification/Revalidation Activities - Dietary Supplement Manufacturing Equipment Design and Development of Products and Processes 3
H Cooling Equipment Qualification for Medical Device Manufacturing EU Medical Device Regulations 3
U Regulations and Standards for Drug Manufacturing Equipment Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
S Lean - Ways to Measure Equipment Flexibility - Flexible Manufacturing System (FMS) Lean in Manufacturing and Service Industries 2
A How to treat large Manufacturing Equipment providers - Opinions and comments wanted Supplier Quality Assurance and other Supplier Issues 5
A Re-Validation criteria and Requirements for Manufacturing equipment on site ISO 13485:2016 - Medical Device Quality Management Systems 8
S Difference between control & audit - Cleaning manufacturing equipment Internal Auditing 5
T Photomask Processing Equipment Manufacturing and SPC Manufacturing and Related Processes 2
E [Ask] Original Equipment Manufacturing/Manufacturer Misc. Quality Assurance and Business Systems Related Topics 1
Ajit Basrur Necessity of Calibration of Manufacturing Process Equipment Gages, Controllers, Etc. General Measurement Device and Calibration Topics 7
S CE and Manufacturing license Manufacturing and Related Processes 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Ed Panek What are the limits on manufacturing changes and substantial changes? EU Medical Device Regulations 6
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
R Manufacturing plants relocation - Medical Device Medical Device and FDA Regulations and Standards News 7
R Medical Device - Change manufacturing plant Design and Development of Products and Processes 6
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
S Manufacturing Execution Systems Software Costs Manufacturing and Related Processes 0
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
H Line Balancing in Backpack Manufacturing Manufacturing and Related Processes 2
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L SAE AS9145 vs. SAE AS6500 (Manufacturing Management Program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
