Manufacturing Equipment Pressure Gages Calibration Requirements
bobdoering
Stop X-bar/R Madness!!
#21
Re: Pressure Gages Calibration
I pretty much agree.:agree1: I'm just unclear as to why the auditor just summarily wrote up an instrument. It could be important; it may not.
Injection molding machines have 106 gauges on them:tg:, most all of them are just used for maintenance. So I'm still unclear if the auditor just saw an uncalibrated gauge and started writing, the auditor found a clear nonconformity within their QMS regarding the gauge(s), or if the auditor may have process knowledge, and knows the gauge is relevant to the process.:)
Sometimes it is the answer the auditee gives that can create the issue. "I don't know" can open the infamous can of worms... Even worse if nobody knows!
Marc
#22
As I said, if the person responsible for the machine can not answer every relevant question they have no business working with the machine or trying to answer questions about it. Sometimes a machine operator may not know, but who ever is responsible for the machine should.
bobdoering
#23
I have long advocated against labeling each gage that does not need to be calibrated. Looks don't mean a thing. Gages which have to be calibrated should be on a recall list. If the person responsible for the machine can not explain which gages have to be calibrated, and why, and which do not have to be calibrated (and exactly why they don't have to be calibrated), that person has no business being involved with the machine.
If one uses the type of 'label everything' model, one would have to label every uncontrolled document 'Uncontrolled' in some way (as an example) which is a total waste of time.
I find what is worse is when people put "for reference only" on gages because 1) they don't know what they are for, 2) they haven't figured out how to calibrate or verify them or 3) don't feel like paying to calibrate them-ever.
So, yes, things that can be meaningful can be made meaningless.
The explanation of the gage calibration should be clear from the control plan or PFMEA...if someone remembered to consider them for those documents.
I would agree, if you have a rock solid QMS, gage calibration, APQP and PM system, you may not need to label all of the gages. Big "if".
bobdoering
#24
I agree with that! :cool:
Marc
#25
I find what is worse is when people put "for reference only" on gages because 1) they don't know what they are for, 2) they haven't figured out how to calibrate or verify them or 3) don't feel like paying to calibrate them-ever. <snip>
Labeling gages "for reference only" is something I have seen quite often and it was always because a consultant or book said they should to keep auditors happy. :notme:
Cobblesong
#27
Yes - logically that makes sense and is likley a best practice.
But it's not what the ISO9001 standard requires. It's the first paragraph of 7.6: "...evidence of conformity of product to the determined requirements."
Hydraulic line pressure isn't going to prove that that required dimension A is Xmm. It will tell you if the machine is capable of getting there, but that's not what the standard requires.
A close reading of 7.6 shows the first paragraph to say 'monitoring and measuring devices', but the third paragraph (which invokes calibration) only say 'measuring equipment' shall be calibrated. It does not say monitoring equipment requires calibration. Further, ISO-9000 vocabulary does not define 'monitoring equipment'. I believe saying ISO requires process equipment gauges requires calibration is wrong. Also, process equipment gauges do not 'provide evidence of conformity of product to determined requirements'. A hydraulic pressure gauge on a brake press is not used to confirm the bend radius on sheet metal can be sold, e.g. noone says 'I know this is bent to 90 degrees because my hydraulic pressure is 800psi. Boy, if it read 750psi this part would be scrap.' Instead we measure the bend with a radius gauge, AND IT'S THIS RADIUS GAUGE THAT REQUIRES CALIBRATION/VERIFICATION!
Sidney Vianna
Post Responsibly
#28
The problem starts when anyone makes overly broad statements, based on a single scenario. The different situations have to be evaluated on a case by case. While your brake press example is a good one to support your case, there are many others where process equipment instrumentation is the key to product integrity. Chemical processes, for example, where certain reactions must occur within tight ranges of pressure, temperature, ph, etc...Critical welding processes, which require close attention to amperage, voltage, etc...In such cases, it is paramount to have accurate readings, which can only be achieved if the associated instrumentation is calibrated.
Another typical mistake, when attempting to interpret ISO 9001, is to consider separate paragraphs of the document in isolation. Most of the requirements are interconnected. For example, ISO 9001 7.5.1 e) connects with 7.6.
Cobblesong
#29
After several more audits, including a certification for KGS (Korea Gas Safety), I discovered that the calibration requirements for welding equipment is covered under ISO 17662, which validates the point I was making. And I completely agree the standard should be read on the whole with great respect for the intended interrelationships. Interestingly, the burden under 17662 for calibrating a welding machine is much lower than what one traditionally encountered for measuring tools, and this is explicity disclosed in the standard. It's like the authors of 17662 (who I believe to be credible as its an ISO standard), said "We better write something reasonable for welding machines, or someone is going to overreach and apply the calibration requirements for 9001 to them".
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Equipment Mobility - Transfer of manufacturing lines to a different location Qualification and Validation (including 21 CFR Part 11) 5
D Verification that Manufacturing Equipment has maintained a Validated State Design and Development of Products and Processes 11
T Risk Analysis for moving manufacturing equipment ISO 14971 - Medical Device Risk Management 17
L Medical Device Manufacturing Equipment Design Other Medical Device Related Standards 2
jkuil Calibration before and after relocation of GMP manufacturing equipment Calibration Frequency (Interval) 7
G Prototype Manufacturing Equipment - Validate or not to validate? Quality Manager and Management Related Issues 2
D Moving Manufacturing Equipment from USA to Europe - Is CE certification required?? CE Marking (Conformité Européene) / CB Scheme 12
O Requalification/Revalidation Activities - Dietary Supplement Manufacturing Equipment Design and Development of Products and Processes 3
H Cooling Equipment Qualification for Medical Device Manufacturing EU Medical Device Regulations 3
U Regulations and Standards for Drug Manufacturing Equipment Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
S Lean - Ways to Measure Equipment Flexibility - Flexible Manufacturing System (FMS) Lean in Manufacturing and Service Industries 2
A How to treat large Manufacturing Equipment providers - Opinions and comments wanted Supplier Quality Assurance and other Supplier Issues 5
A Re-Validation criteria and Requirements for Manufacturing equipment on site ISO 13485:2016 - Medical Device Quality Management Systems 8
S Difference between control & audit - Cleaning manufacturing equipment Internal Auditing 5
T Photomask Processing Equipment Manufacturing and SPC Manufacturing and Related Processes 2
E [Ask] Original Equipment Manufacturing/Manufacturer Misc. Quality Assurance and Business Systems Related Topics 1
Ajit Basrur Necessity of Calibration of Manufacturing Process Equipment Gages, Controllers, Etc. General Measurement Device and Calibration Topics 7
S CE and Manufacturing license Manufacturing and Related Processes 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Ed Panek What are the limits on manufacturing changes and substantial changes? EU Medical Device Regulations 6
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
R Manufacturing plants relocation - Medical Device Medical Device and FDA Regulations and Standards News 7
R Medical Device - Change manufacturing plant Design and Development of Products and Processes 6
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
S Manufacturing Execution Systems Software Costs Manufacturing and Related Processes 0
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
H Line Balancing in Backpack Manufacturing Manufacturing and Related Processes 2
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L SAE AS9145 vs. SAE AS6500 (Manufacturing Management Program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
