Manufacturing Instructions and Forms for our Products - Question on Content
shushd
Hi, I am trying to prepare Manufacturing Instructions and forms for our products. The forms are basically a check list for the operator and QC to mark pass/fail for setup and in process parameters. Is it possible or advisable to make the forms per product, meaning each product will have the same forms but with different tolerances? or must it be a generic form that will suit all products? the problem is that my boss wants to have the tolerances on the form itself, and not have the operator referring to a different place for the tolerances. I hope I'm clear enough, what do you think?
G
Gert Sorensen
Re: A question about forms
Could you elaborate a bit about the number of items? There's a difference between producing 10 or a 1000 items, and consequently how to handle the documentation need.
shushd
by number of items you mean products? if so, we have many, a lot of them are the same, some of them are different. I suggested putting the set up tolerances in the manufacturing procedures which are per product and the operator will refer to the MP and then check off the forms. but as I said, my boss is strongly against it, he doesn't believe that the operator should have all these papers running around. He wants the operator to have the tolerances in the form itself.
G
Gert Sorensen
If you have got a lot of different items I would suggest that you keep the documents generic. Try to creat a few master documents that contain specifications per item group. It will be a lot easier for all parts to relate to. If you have product specific documents then the administration of the documents is a lot more difficult, and the chances of operators actually using the forms are diminished.
CarolX
I tend to agree with the boss here. Although this is a lot of extra work - but look at your end user. If they have to refer to another document for tolerancing, the chance of error is increased. I don't know what the other documents are - maybe a drawing? What if the operator doesn't know how to read drawings? Or dosen't understand tolerance blocks.
JMHO
G
Gert Sorensen
JMHO
:2cents: It is easier to train an operator to use a few documents than a lot. "If i produce screws i use this form, if I produce bolts I use that form". Keep it simple.
Operator competence is not the issue, that point is related to training of employees. If the don't understand these things they should receive adequate training.
shushd
Thank you guys for your inputs. Let's say I will use a form per product. As far as the document control, what do you think is the best way to do it? Should it be as an appendix to the MP, meaning it will be counted as one of the pages of MP? Or should it be a separate form with a separate number?
moiraknows
Using a generic form, have the set-up people note the CTQ tolerances, how often these need to be checked and how they are checked. All this information can be taken right off the control plan for the product.
Scott Catron
True Artisan
Just to add my two cents, we make hundreds of products, some we maintain in inventory, some are made-to-order (like a chemical short-order cook).
Anyway, we have a general manufacturing SOP that outlines the process of making a batch, but we leave specific instructions for each product to the individual manufacturing instructions (we call it a Batch Production Record (BPR)). Our products are dissimilar enough to warrent separate documents.
Is MP manufacturing procedure? In our case, the general manufacturing SOP spells out that there will be a BPR for each product and what should be on each one (safety instructions, equipment list, step-by-step instructions), but each document is not a part of the SOP. They're kept by our internal product number and revision number.
C Manufacturing Process Work Instructions - Format Manufacturing and Related Processes 4
V Manufacturing Work Instructions and Work Instruction Content Manufacturing and Related Processes 4
E Manufacturing without Procedures and Work Instructions Document Control Systems, Procedures, Forms and Templates 12
T Work Instructions for manufacturing software Document Control Systems, Procedures, Forms and Templates 2
S Manufacturing Process Work Instructions vs. Work Procedures - Differences? Document Control Systems, Procedures, Forms and Templates 10
M Blank Fields on Manufacturing Work Instructions Document Control Systems, Procedures, Forms and Templates 4
S CE and Manufacturing license Manufacturing and Related Processes 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Ed Panek What are the limits on manufacturing changes and substantial changes? EU Medical Device Regulations 6
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
R Manufacturing plants relocation - Medical Device Medical Device and FDA Regulations and Standards News 7
R Medical Device - Change manufacturing plant Design and Development of Products and Processes 6
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
S Manufacturing Execution Systems Software Costs Manufacturing and Related Processes 0
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
H Line Balancing in Backpack Manufacturing Manufacturing and Related Processes 2
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L SAE AS9145 vs. SAE AS6500 (Manufacturing Management Program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Address of Legal Manufacturing Site in ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
M Operational (free) simulation games for manufacturing and quality Lean in Manufacturing and Service Industries 5
V Manufacturing requirements for respiratory ventilators - clean room required? Medical Device and FDA Regulations and Standards News 6
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
S Contagious Diseases in Medical Device Manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 5
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
Z US Manufacturing Site Closing, device manufactured elsewhere Medical Device and FDA Regulations and Standards News 1
L Manufacturing site expansion - When to notify your NB EU Medical Device Regulations 3
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
