Manufacturing procedure / work instruction depth
James
Hello friends
I wondered if anyone could give an example of the level of detail required for Manufacturing procedures / work instructions? How 'high level' can these be to meet 13485 / MDR requirements?
We manufacture class 1 devices (but mainly accessories for devices), and the components used are quite diverse, based on a clinicians requirements (such as different combinations of foam fillers and coverings). Accessory requirements will be written in a drawing sheet produced by a clinician. These may not necessarily constitute 'custom made' accessories; they may for example be a postural support for a wheelchair that has been designed to meet a particular patients' needs, but could 'technically' be used by someone else.
Does anyone have a good example of a clinical device or accessory manufacturing procedure?
Many thanks
James
yodon
You need to ensure that the product made meets specifications. You need to consider the complexity of the work and the culture of the operators. If you have highly-skilled folks that can do the job perfectly every time with just a drawing, you could arguably not need any work instructions (a bit facetious since there may be test points / QA checks along the way that probably need some instruction but hopefully you get the point).
(Your production / post-production monitoring activities should give you a clue as to whether the procedures / instructions are sufficient and effective.)
John C. Abnet
Teacher, sensei, kennari
Good day @Jamesv ;
Be careful not to build documentation based on what you might think the auditor "needs". (i.e. "...to meet 13485...") .
Ask/work with your teams to see what level of detail your organization needs to ensure...
1- Conforming work
2- Repeatable/standardized work.
3- Sustainability if/when key members of your team leave the organization.
If the system/documentation constructed is only done so to "meet 13485/MDR requirements", then the system and documents will likely be a burden for someone to simply maintain instead of a tool that will benefit your organization.
Hope this helps.
Be well.
James
Thanks, thats a helpful perspective. I've not documented manufacturing-based procedures before, only service based. I'm struggling to apply the principles in a meaningful way. Based on the objective of ensuring
1- Conforming work
we could arguably have a very high-level manufacturing procedure that specifies that the item will be manufactured in accordance with the design specifications and technical file, by a competent technician.
We could then have 'good practice' work instructions that are maintained by the workshop that are not mandatory, but give guidance on the general manufacturing principles and approach for different groups of products. These help to ensure sustainability through having documented 'instructions'for how groups of products can be manufactured. Different technicians might take a different approach to manufacturing an item, but crucially, as long as what is manufactured meets the problem / intended aim of the product, the way in which this is achieved can vary?
We also have occasions where the person making the product also designs it. In this instance, they dont do an actual drawing of what they are going to build, its a mental image / conceptualisation that they make. They take photos of the product at the end, and it is signed off as meeting clinician and patient approval at the end. This is a pragmatic approach in my view, but does it meet requirements?
John C. Abnet
Good day @Jamesv ;
Obviously only you and your organization know what is best for your situation. I, however, generally council companies to consider (similar to what you described), ....
1- Procedures (which are limited on text) and simply identify WHO does WHAT and WHEN. These can be extremely helpful to ensure that the corporate intent is SUSTAINED if/when there is turnover in the organization.
2- Work Instructions (which, WHEN required are filled with the detail necessary) to ensure standardized work specific to HOW a job is to be done.
Example:
If the corporate intent is that the ADMINISTRATOR (who) will MAKE COFFEE (what) every MORNING (when), then a procedure can help sustain that intent and a work instruction is likely not needed. However, if instead of "make coffee" the procedure says "start the reactor", then a significant work instruction/training curriculum is likely needed !
Hope this helps.
Be well.
James
Thanks @John C. Abnet
Can work instructions be semi-vague in relation to HOW we get there, as long as we get there consistently? Eg, a step like - 'engineer considers job requirements and selects cutting tools necessary for cutting out specified materials'?
John C. Abnet
Good evening @Jamesv
They can be as detailed or "semi-vague" as you and your organization wishes. They should serve your organization and its people and only your organization and its people can determine how much detail that requires. I would council that IF a work instruction is required, then that would prompt me to lean towards more detail instead of less.
The standard only mentions certain required procedures (the terms "procedure", "work instruction", etc... are not necessarily common from organization to organization) and is very specific on which "procedures" are required and which "procedures" are required if/then.
Hope this helps.
Be well
ScottK
Not out of the crisis
I see nothing wrong with that statement... but as an auditor I might then ask "how does the engineer know what tool is appropriate?" At which point you would produce training records or other qualification of the engineer.
So, as has been stated, write the work instructions to suit your business - not to suit what an auditor might ask for.
I've always taken these on a case by case basis for each work instruction... sometimes you can leave things open, sometimes you need to be exact.
Fit the situation.
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
DuncanGibbons Additive Manufacturing/3D printing for aerospace (certification procedure) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Writing a Manufacturing Recall Procedure Document Control Systems, Procedures, Forms and Templates 3
S Q1 Manufacturing Site Assessment - Managing Post-Job 1 Changes Procedure Manufacturing and Related Processes 1
J Manufacturing Procedure Template Document Control Systems, Procedures, Forms and Templates 6
P Pest Control procedure for a manufacturing facility. ISO 13485:2016 - Medical Device Quality Management Systems 3
S Contract Review Procedure for a Manufacturing Business Contract Review Process 2
D Shutdown Procedure Examples for a chemical manufacturing facility Document Control Systems, Procedures, Forms and Templates 6
N Looking for a Manufacturing Planning Procedure Document Control Systems, Procedures, Forms and Templates 10
S Ramp-Up Procedure for Manufacturing Process - Needed Document Control Systems, Procedures, Forms and Templates 2
S CE and Manufacturing license Manufacturing and Related Processes 1
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Ed Panek What are the limits on manufacturing changes and substantial changes? EU Medical Device Regulations 6
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
R Manufacturing plants relocation - Medical Device Medical Device and FDA Regulations and Standards News 7
R Medical Device - Change manufacturing plant Design and Development of Products and Processes 6
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
S Manufacturing Execution Systems Software Costs Manufacturing and Related Processes 0
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
H Line Balancing in Backpack Manufacturing Manufacturing and Related Processes 2
L SAE AS9145 vs. SAE AS6500 (Manufacturing Management Program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Address of Legal Manufacturing Site in ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
M Operational (free) simulation games for manufacturing and quality Lean in Manufacturing and Service Industries 5
V Manufacturing requirements for respiratory ventilators - clean room required? Medical Device and FDA Regulations and Standards News 6
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
S Contagious Diseases in Medical Device Manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 5
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
