Manufacturing without a Formal Drawing
Good afternoon,
In our production facility, We make some parts without formal drawing because of either time crunch or too old parts. In our ISO procedure, it says that manufacturing collects drawings prior to starting work. Can I tweak the procedure that Computer programmed files like AutoCAD files are also valid for manufacturing? or do we have to have formal drawings for every part we make? I would highly appreciate any suggestions on this topic.
Pancho
wikineer
Hello Vihar,
You get to write or edit your own procedures to whatever it is that allows you to produce quality parts. The standard does not proscribe tweaking your procedures to say whatever allows you to produce quality parts, including saying "Autocad files are valid for manufacturing". You just have to make sure that the design outputs are "adequate for the subsequent processes", per Section 8.3.5 b of the standard. If the files are adequate in this sense, tweak away!
Michael_M
Be careful not to write yourself into a corner. Instead of using 'Auto Cad', you may want to say "Auto Cad or other electronic formats". This allows formats like DFX or solid works to be used (now or in the future) without violating your procedure. If you say 'Auto CAD', and you have a solid works file, some auditors may say you are in violation because you do not say that. I personally disagree with these auditors as the intent is pretty clear and requires procedures to be written with wiggle room and double talk that allows for things that should not be (i.e. in my opinion, procedures should be written clearly with easy to understand processes/instructions and not a bunch of double talk to keep auditors happy).
Put this in your procedure:
Approved engineering drawings in hard copy and/or electronic formats are acceptable for part manufacturing and inspection purposes.
Thank you .
Thank you
Edward Reesor
The issue concerns the space between "A) what you intended to create" and "B) did we actually create what we intended to create". Your quality system should show that A=B with any and all tests/verification that took place to ensure that you reached your goal or tweaked the design along the way.
The auditor will be looking for any documentation to show that you intended to create A to begin with, and any specifications therein including why A needed to be changed. Otherwise, B just showed up and was introduced into the production line mysteriously.
Golfman25
And this is why ISO qms systems fail to get management support. We spend our time on legalese to get us out of an potential audit issue rather than doing the important stuff.
Golfman25
Good afternoon,
I would go broad -- "collects applicable documents, drawings, samples, etc. prior to starting work." Heck there may be times when a guy will make something from his "head" based on a conversation with a customer.
M Product Realisation without manufacturing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Manufacturing without Procedures and Work Instructions Document Control Systems, Procedures, Forms and Templates 12
Y Recommended for Certification - R&D only (without Manufacturing or Marketing)! ISO 13485:2016 - Medical Device Quality Management Systems 13
J Lean Manufacturing without stability - Rate it 1 to 5. Lean in Manufacturing and Service Industries 4
M Implants made by Additive Manufacturing process approved by USFDA Other Medical Device and Orthopedic Related Topics 1
D What evidence to I need to supply as a remote location in relation to manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 10
P Manufacturing site vs manufacturing date symbol Medical Device and FDA Regulations and Standards News 1
D Secondary Manufacturing Site on DoC EU Medical Device Regulations 1
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Instructions for use multiple manufacturing locations ISO 13485:2016 - Medical Device Quality Management Systems 0
F [Line Balancing] Line Efficiency in Fan Manufacturing Lean in Manufacturing and Service Industries 0
S CE and Manufacturing license Manufacturing and Related Processes 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Ed Panek What are the limits on manufacturing changes and substantial changes? EU Medical Device Regulations 6
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
R Manufacturing plants relocation - Medical Device Medical Device and FDA Regulations and Standards News 7
R Medical Device - Change manufacturing plant Design and Development of Products and Processes 6
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
S Manufacturing Execution Systems Software Costs Manufacturing and Related Processes 0
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
H Line Balancing in Backpack Manufacturing Manufacturing and Related Processes 5
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L SAE AS9145 vs. SAE AS6500 (Manufacturing Management Program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Address of Legal Manufacturing Site in ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
M Operational (free) simulation games for manufacturing and quality Lean in Manufacturing and Service Industries 5
V Manufacturing requirements for respiratory ventilators - clean room required? Medical Device and FDA Regulations and Standards News 6
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
