Mapping QMS+business processes in a medical device with class I and IIa+b
Hi
I am in a project where the QMS and all related processes, roles, departments, requirements, and legal together with a mapping of all projects and processes also have to be mapped and visualized. Many of the projects besides are consistence with hardware and software in many projects.
It is a larger company with many projects and SOPs.
My first plan is to due to the analysis of QMS and then on each project with standard GAP +ISO and regulatory?
My first idea is to use Excel and Visio.
What would be the best mapping to use?
My first idea is VSM and SIPOC?
RACI for stakeholders.
Is this a good start or do I have to be aware of issues now?
And would there be a better solution for mapping to use?
Kind Regards
Peter Fraser
What do you have just now in terms of documentation? I guess that you must have a lot of documentation already if you have many projects etc.
And where do your requirements ("...a mapping of all projects and processes also have to be mapped and visualized") come from?
Personally I would avoid Excel and Visio because you really need to have a common source for your roles, documents etc. Yes for RACI for definig your processes - but I have never been a fan of SIPOC(!)
RoxaneB
Change Agent and Data Storyteller
When it comes to selecting the most appropriate tool to use, be it a software program or something from the quality toolbox, I'd offer that answering the following questions might offer some guidance:
  • Why are you doing this exercise?
  • What is the expected outcome of this exercise?
  • How will the results of this exercise be utilized?
  • Who will use the results of this exercise?
  • Is this a one-time exercise or something that will become routine?
Tidge
Without knowing the answers to @RoxaneB questions, it is difficult to offer much in the way of concrete suggestions.
With nothing to go on but the OP, for process mapping... my first tool would be a piece of paper to draw a flow diagram of what I think the process looks like from the established procedure (assuming one exists), and then turn that into something like a Visio drawing. I have found that Visio workflows typically force people to think about the "obvious" flow and draw immediate attention to problematic paths in the flow. (I am assuming that who ever wants this exercise is at least looking for this)
When I've done this sort of exercise, I have found it critical to interview the people using the process after my own mapping of the workflow. I have found the following common outcomes:
  • The users can clarify parts of the process that I didn't understand (typically due to ignorance or preconceptions on my part)
  • Users sometimes don't follow the flow (for ad hoc reasons)
  • Users sometimes can't follow the flow (process has a defect)
Interviewing users first will simply muddy the waters, as individuals will almost certainly be focusing on discrete elements of any given process and not the entire process.
The first bullet point above is something to be VERY cognizant of... I have seen some VERY complicated processed that look as if they could be "streamlined" (by some outside expert) yet teams of trained and qualified individuals have demonstrated that they follow such processes unerringly. This is a reason to know the purpose of the exercise and how it will be used... there may be no return-on-investment for trying to streamline a smooth-running but complicated process.
J Document hierarchy for Process mapping for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
C AS9100D to CMMI Dev 2.0 Mapping & Comparison Matrix Software Quality Assurance 1
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
J Definition Defect Mapping - Here is my definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 13
Z 21 CFR and Annex 11 mapping document Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
R Process Mapping for a BPMS (Business Process Management System) vs ISO Process Maps, Process Mapping and Turtle Diagrams 1
M PDCA cycle - Process mapping - Environmental ISO 14001 ISO 14001:2015 Specific Discussions 1
R Process Mapping a Civil Infrastructure Construction company Process Maps, Process Mapping and Turtle Diagrams 4
Q Guidance Needed For Mapping Career Path Career and Occupation Discussions 5
L Mapping the loan lending bank process Process Maps, Process Mapping and Turtle Diagrams 9
R PPM, Pictorial Process Mapping, Templates Manufacturing and Related Processes 5
M Value Stream Mapping Calculations Process Maps, Process Mapping and Turtle Diagrams 5
S ISO14001:2015 Factory Process Mapping ISO 14001:2015 Specific Discussions 7
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
J Agenda of Value Stream Mapping workshop required Quality Tools, Improvement and Analysis 1
R VSM - Value Stream Mapping (catheter manufacturing unit) Customer Complaints 10
A Mapping of IEC 62304 artefacts (SRS, SAD, etc) to the 820.30 phases IEC 62304 - Medical Device Software Life Cycle Processes 5
M Mapping Processes to 7.3 Development and Design - AS9100 Process Maps, Process Mapping and Turtle Diagrams 3
C Dose Mapping - How to relate back to Routine Monitoring Position ISO 13485:2016 - Medical Device Quality Management Systems 3
S Value Stream Mapping for a Product Family Lean in Manufacturing and Service Industries 5
A Assessing/Mapping Employee Attitude during Competency Mapping (Assessment) IATF 16949 - Automotive Quality Systems Standard 15
M Value Stream Mapping or Deployment Chart in Services Lean in Manufacturing and Service Industries 6
T ISO 20000 Mapping to ITIL and COBIT IT (Information Technology) Service Management 4
BradM What is the minimum size chamber for mapping? ISO 13485:2016 - Medical Device Quality Management Systems 2
B Macro Process Mapping (pre-GAP analysis) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Value Stream Mapping Template Document Control Systems, Procedures, Forms and Templates 2
I Stability Chamber Temperature Mapping General Measurement Device and Calibration Topics 5
V Any examples of Value Stream Mapping (VSM) for Product Development Processes (PDP) ? Six Sigma 3
C Process Mapping Electronic Document Control Software Recommendations Quality Tools, Improvement and Analysis 5
P Value Stream Mapping - Trying to do Value Stream Mapping of our Products Lean in Manufacturing and Service Industries 3
T ISO/IEC 27001 to ISO/IEC 12207 Mapping - Cross Reference Matrix IEC 27001 - Information Security Management Systems (ISMS) 2
D Is Process Mapping an ISO 13485 Requirement? Process Maps, Process Mapping and Turtle Diagrams 4
S Value Stream Mapping (VSM) in After Sales Customer Support Service Department Lean in Manufacturing and Service Industries 4
S Business Case for Process Mapping Process Maps, Process Mapping and Turtle Diagrams 4
V Value Stream Mapping - Loan Processing for Vehicle Asset Financing (VAF) Lean in Manufacturing and Service Industries 4
A Information Technology Process Mapping per ISO 13485 - example wanted Process Maps, Process Mapping and Turtle Diagrams 1
F Updating a Quality Manual from ISO 9001 to ISO TS 16949 - Process Mapping IATF 16949 - Automotive Quality Systems Standard 2
L Qualiware Software & Process Mapping Process Maps, Process Mapping and Turtle Diagrams 7
Q Correlation Matrix and Value Stream Mapping? Quality Assurance and Compliance Software Tools and Solutions 1
F How does Process Mapping help to make a process more Transparent to the Customer? Process Maps, Process Mapping and Turtle Diagrams 2
M SIPOC (Suppliers Inputs Process Outputs Customers) Process Mapping Tool example Process Maps, Process Mapping and Turtle Diagrams 11
N Process Mapping a Private Company that deals with Insurance Process Maps, Process Mapping and Turtle Diagrams 8
J Definition Activity vs. Task - Definitions in Process Mapping and Projects Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
G Using Visio 2010 as a Mapping Program for Circuit Boards Quality Assurance and Compliance Software Tools and Solutions 3
S Value Add Time Calculation in Value Stream Mapping (VSM) Lean in Manufacturing and Service Industries 8
R Process VSM (Value Stream Mapping) help needed Lean in Manufacturing and Service Industries 5
N Does anyone have any experience or feedback using mind mapping software? Quality Tools, Improvement and Analysis 5
