Master Document List - Obsolete Documents
Tyler C
Quality Pros,
I did some searching and could not find anything relating to a Master Document List. I know this list is not required by the standard, but it is the method we have chosen for several identifications of our controlled documents.
It is an excel spreadsheet with several tabs. These include the Master Document List, Record Control List, External Documents List, and Obsolete Documents List. I understand listing all except the obsolete list.
Can anyone offer any feedback for me?
Thanks in advance.
Marc
Re: Master Document List
An obsolete list is just what it says. Typically in your document revisions history there is a final "Obsolete" entry. That said, whether a company keeps a revision history, and how far back it goes, is in part dependent upon the company, as well as any regulatory requirements.
If you want to see a simple, "standard" Master Document List", I posted this many years ago: http://elsmar.com/pdf_files/Doc_Matrix.pdf and http://elsmar.com/pdf_files/Doc_map_B.pdf
Does this help?
Ninja
Looking for Reality
<snip> ... These include the Master Document List, Record Control List, External Documents List, and Obsolete Documents List. I understand listing all except the obsolete list.
If the form of "control" you use is summed up as: "It is on this list therefore it is controlled".....
Then the "Obsolete List" is a positive record of do-not-use-it for copies that may be in someone's hands.
A pretty iffy control system, but I've seen it before.
Tyler C
Thank you all for your replies. I apologize for not being very clear. I was trying to determine if I could get away with NOT including the "Obsolete Document List".
What I want to avoid is having a list that looks like:
Document X - rev A
Document X - rev B
Document X - rev C
Document Y - rev A
Document X - rev D
...and so on. I guess I just struggle with what value it adds.
I am not actually using this as a control system, more of just a way to identify location, retention, and retrieval. Any obsoleted documents will actually be unavailable to anyone in the company except myself and the General Manager. In a sense, these obsolete documents are still controlled, but only to the extent that no one can access them. They will only be used for past reference if needed, but only with my knowledge and approval. There will however be a list of the most up-to-date revisions that people can use to cross reference any document they may have to ensure they are working off the latest version.
I hope this clears it up a little. Thank you for the links Marc, I glanced through and my Master list is way smaller than the example you provided. I hope I never have to get that detailed with it.
Kronos147
I relate obsolete documents with the new requirements of ISO 9001:2015 for change management (SEE: clauses 4.4.1 (g) AQMS and its Processes, 5.3 (e) Organizational Roles, Responsibilities and Authorities, 6.3 Planning of Changes, 7.5.3.2 (c) Control of Documented Information, 8.1 Operational Planning and Control, 8.2.4 Changes to the Requirements of Products and Services, 8.3.6 Design and Development Changes, 8.5.6 Control of Changes).
My change management program includes assessing changes and keeping the ability to "roll back" when things do go as planned.
Example:
Work Instruction 123 Rev.D says "wash, rinse, dry." We want to try without wash to save time. Work Instruction 123 Rev. E says "rinse, dry." There are some rejections. The change has initially be perceived as 'bad'.
An organization may choose to "roll back now by saving Work Instruction 123 Rev.D as rev. F, go out and retrain. Now you should be back to the same pre-change condition.
Another reason: you had a customer rejection. You do your root cause analysis and you see that the part was built using Work Instruction 123 Rev. D. Your system only has Rev.E on file. Was the problem already addressed? Is you root cause analysis effective?
I hope this helps!
Cheers,
Kronos
Tyler C
Well, thank you Kronos147. That was the value of the list I was looking for. I think I would still be able to back track because I will still have access to the obsolete version and all of the revision history as well. The only difference is I wouldn't be using a list to determine this, rather the actual documents themselves. But still, this is an excellent point to consider.
I am currently working with the 2008 version, but I enjoy hearing how people are doing with the 2015 version. I'm sure there isn't much difference between the two in this case.
JoShmo
Do you have experience of how engineering drawings are change controlled? They typically use something called a drawing change Note or something like that. They don't list the changes on the actual drawing (well, not in my experience of being in design) but simply record the number of the last note which affected that drawing. The drawing clerk doesn't keep extra logs etc, but they keep the changenotes for theat drg #. Why not do it that way?
Jen Kirley
Quality and Auditing Expert
2015 or 2008 version, makes no difference in how to handle obsolete documents. Control is control.
The means for making such documents unavailable for unintended use can be as simple as renaming the document "obsolete.xxx.xxx.xxx" or moving it to a folder named "obsolete" or "archive" or similar. Of course, specialty software will have specific methods for handling these documents.
It is important to not make this a difficult thing, so we can plainly define the process and effectively maintain it.
somashekar
Quality Pros,
Thanks in advance.
Since you use the excel spreadsheet, you can decide to color the cell with a red or any other color to denote obsolete documents. You need not have a obsolete documents list as a separate column.
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
T Document Control Master List for Obsolete Documents Document Control Systems, Procedures, Forms and Templates 6
A Master Document List Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Master Document List and Unalterable Electronic Forms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Master Document List - Is it necessary? Document Control Systems, Procedures, Forms and Templates 15
H Formats for Master List of Quality Records (MQR) & Document Change Request Form (DCR) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S MDR (Master Document Register) for Planning of Documents in Process Engineering Document Control Systems, Procedures, Forms and Templates 2
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S Need an example of Master Document Control Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Excel .xls Template for Document Control Master Register Document Control Systems, Procedures, Forms and Templates 1
T How much information should I keep in my Master Document Register? Document Control Systems, Procedures, Forms and Templates 8
S Master Document Register Project Procedures help needed Document Control Systems, Procedures, Forms and Templates 2
S Is Master Sample a Document? - ISO 9000:2000, Clause 3.7.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
C Control of Document and Form Master Lists Document Control Systems, Procedures, Forms and Templates 9
J How to determine which is the 'master' "controlled" version of document Document Control Systems, Procedures, Forms and Templates 9
N Do Document Master Lists need a Form Number Document Control Systems, Procedures, Forms and Templates 4
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
Q Forms Master List versus Record Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R No design history file or device master record ISO 13485:2016 - Medical Device Quality Management Systems 5
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
M Master Dot for quality planning/improvement Manufacturing and Related Processes 1
M Medical Device Master File - We are a contract manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 7
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
R Are DMR (device master record) and DHR (device history record) inspected by FDA or audited by an NB ISO 13485:2016 - Medical Device Quality Management Systems 6
S Foreign Manufacturer and DMR - Who keeps the DMR (Device Master Record)? ISO 13485:2016 - Medical Device Quality Management Systems 2
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
D Design Outputs vs DMR (Design Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V Carbon Black (Master Batch) - Basic Requirements Manufacturing and Related Processes 5
H Korea DMF (Drug Master File) Fees Various Other Specifications, Standards, and related Requirements 5
K Computerized system Master Validation Plan, IQ-OQ-PQ Draft or Template Qualification and Validation (including 21 CFR Part 11) 4
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
P DMF (Drug Master File) type V for Sterilization Processes for USFDA Submission Other US Medical Device Regulations 3
Q Master FMEA for "like processes" - Does an FMEA have to match the CP and PM directly? FMEA and Control Plans 7
S Looking for templates of Master Production Record and Master Batch record Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
V Site Master File for multiple business units within same premises/facility Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
rob73 Digital DMF (Device Master File) Records EU Medical Device Regulations 3
I DMR (Device Master Records) and similar for standalone software device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Switching Master Product in EO (Ethylene Oxide) Other Medical Device Related Standards 5
S Device Master Records for a Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S DMR (Device Master Record) Management and Index questions Other US Medical Device Regulations 18
P "Bayer" Black Resin vs. Master Batch Manufacturing and Related Processes 1
