Master Samples - What should we be keeping?
I'm building a PPAP for a customer and Section 15 of the PPAP 4th addition talks about Master samples. I need help understanding exactly what we should be keeping as a Master sample to comply to the standard. If we take dimensional readings of our part from the production line if we keep one of the samples that we took dimensional reading from will this comply with the standard, or do we need to keep an actual sample from one of the pieces that we take performance readings from?
It has been awhile since I have worked in automotive, so I cannot guarantee that this is still current. The master sample is taken from the same significant production run as the PPAP samples at a minimum. If possible, take the master sample from one of the actual PPAP parts. Take care in the storage of these master samples as well to prevent damage or degradation over time.
Thank you. Follow up if we are doing a family PPAP would you need a Master sample for each part that is being supplied? The dimensional reading does not change per the value of the part but the part number does change so I didn't know if we just kept one Master sample is would comply for all.
If there are different part numbers, the parts must be different somehow, no? It's best to consult with your customer about this, but there should be a PPAP sample for each part number. As an aside, it's usually not a good idea to bundle multiple part numbers on a single PSW. The reason for this is that if you have one PSW for multiple parts, if one part is rejected, they all get rejected.
I am thinking of a situation where you have a single base part that has 5 different color paints applied creating 5 different part numbers. In that situation, you would need 5 master parts in order to show the different coatings. What is your scenario?
optomist1
A Sea of Statistics
Jim is spot on above..."It's best to consult with your customer about this, but there should be a PPAP sample for each part number."...and a bit more complex if you are dealing with injection molded parts, multiple cavities...esp. if there a re Class A surfaces, etc...AARs...
The part numbers is the electrical value of the part so that is how they are different. But the dimension of the part is the same in most cases. So would you suggest keeping a master sample for each electrical value even though the part has the exact same dimensions?
If the parts are different in any significant way, separate samples should normally be kept. It's not just about dimensional differences or lack thereof.
Look at it this way. Suppose one of the part number's electrical values ran near the spec maximum, still capable but not centered. Two years from now, your customer has a problem and questions the high values. Wouldn't you like to have a master sample to show that was how it was originally approved?
O Should we store Master Samples pending final approval by Customers? APQP and PPAP 9
V Do I need to have Supplier Master PPAP Samples? I see in AIAG 4.1 APQP and PPAP 4
J Requirements for Retaining PPAP Master Samples APQP and PPAP 2
S Master Document Register Document Control Systems, Procedures, Forms and Templates 3
B Acquired Medical Device Product Line - Documentation Requirements for Device Master Record ISO 13485:2016 - Medical Device Quality Management Systems 7
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Device Master Record (DMR) checklist ISO 13485:2016 - Medical Device Quality Management Systems 1
lanley liao How to understand and master the requirements of each section in API monogram product. Oil and Gas Industry Standards and Regulations 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 1
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
Q Forms Master List versus Record Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R No design history file or device master record ISO 13485:2016 - Medical Device Quality Management Systems 5
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
M Master Dot for quality planning/improvement Manufacturing and Related Processes 1
M Medical Device Master File - We are a contract manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 10
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
R Are DMR (device master record) and DHR (device history record) inspected by FDA or audited by an NB ISO 13485:2016 - Medical Device Quality Management Systems 9
S Foreign Manufacturer and DMR - Who keeps the DMR (Device Master Record)? ISO 13485:2016 - Medical Device Quality Management Systems 2
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
D Design Outputs vs DMR (Design Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V Carbon Black (Master Batch) - Basic Requirements Manufacturing and Related Processes 5
H Korea DMF (Drug Master File) Fees Various Other Specifications, Standards, and related Requirements 5
K Computerized system Master Validation Plan, IQ-OQ-PQ Draft or Template Qualification and Validation (including 21 CFR Part 11) 4
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
P DMF (Drug Master File) type V for Sterilization Processes for USFDA Submission Other US Medical Device Regulations 3
Q Master FMEA for "like processes" - Does an FMEA have to match the CP and PM directly? FMEA and Control Plans 7
S Looking for templates of Master Production Record and Master Batch record Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
T Master Document List - Obsolete Documents Document Control Systems, Procedures, Forms and Templates 23
V Site Master File for multiple business units within same premises/facility Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
rob73 Digital DMF (Device Master File) Records EU Medical Device Regulations 3
I DMR (Device Master Records) and similar for standalone software device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Switching Master Product in EO (Ethylene Oxide) Other Medical Device Related Standards 5
S Device Master Records for a Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S DMR (Device Master Record) Management and Index questions Other US Medical Device Regulations 18
P "Bayer" Black Resin vs. Master Batch Manufacturing and Related Processes 1
R Master Level - I would appreciate any input on a Master Level Calibration and Metrology Software and Hardware 1
J Referencing the DMR (Design Master Record) in the PO Document Control Systems, Procedures, Forms and Templates 2
C Lowest Acceptable Grade for Master Gage Set Calibration and Metrology Software and Hardware 1
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
P DMR (Device Master Record) for Class I and Class II Dental Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
G Where to get a NIST Traceable Master Glass Refractive Index Sample General Measurement Device and Calibration Topics 5
M ASQ CMBB Master Black Belt - anyone appearing for Mar 1, 2014 exam ? Professional Certifications and Degrees 6
H Is "Master Documents and Records list" required per ISO 9001 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Error in Master Weighing Stone General Measurement Device and Calibration Topics 2
