Material Specifications using Performance Values on Mechanical Drawings
9
93ramvert
We are an AS9100 Registered Company. We currently have a fairly new V.P. of Engineering. Of course we are already clashing. Go figure. Anyway our manual basically states that engineering will provide a material specification on drawings, basically to provide purchasing with detailed information when sourcing out material for manufacturing pieces. The engineer is using performance values of the material he wants used as an example:
Material: Steel with minimum material characteristics of 16% Elongation, 95ksi Yield Strength, and 115ksi Ultimate Tensile Strength.
His reasoning: In this case, we could have said to use 4340, but that is really overkill. We could not say to use 4150 because there are different heat treats for it, some of which have the necessary properties and some don’t. By giving the material properties, Bill can use available 4150 if he has acceptable certs for it.
At this point the Pres. is backing him, I just want to make sure that come audit time I'm covered, because of course it's going to be my fault when we get written up for it.
Could someone please tell me if this would be an acceptable practice?
Jeff Frost
You will find in the aerospace your customers will call out conformance to material specifications like, ASTM and these specifications will govern the procurement of materials. Your suppliers will likely also require you to specify the specific specification the metal must meet before accepting the order.
9
93ramvert
The President of the company has so far sided with engineering (he is an engineer as well). He believes that engineering should be able to put Aluminum as the material on mechanical drawings, because it doesn't matter what type it is. I'm certainly not a metallrugist, but I'm sure there may be an aluminum you don't want to use in some cases. I don't know, I'm feeling just a bit lost.
Does it matter what type it is?
9
93ramvert
Well what they are saying in some cases no, and in some cases yes. I quess what I'm concerned about is they are saying is in some cases we are going to tell them what we need in the line of performance of the material, and the vendor will tell us what they are going to give us. Such as yield strength, elongation etc... Now, obviously I can't necessarily have our 18 year old receiver sign-off the material as acceptable, it will have to go through engineering for verification against there performance call out.
Where as if the drawing says Material to AMS 5663, my receiver can look at the certs and positively i.d. that the cert states AMS 5663, and can now receive it.
Let me use the aluminum call out for a second. Say the purchaser goes out to the metal vendor and says I need Aluminum doesn't matter what kind, give me a cheap drop that will match this size. The vendor ships a drop of 7075 aluminum (Now it's aluminum right) right, Now the technician has to do his thing and now needs to weld it. Guess what it's very difficult to weld, and the tech can't get it done. I'm sure there is other differences there has to be, corrision, strength etc. differences from the highest costing to the lowest piece of crap aluminum you can get. To me as just as a person in the company, the decision should not be up to another company, or another department to decide what to get, Engineering should detail this up front. Maybe I'm over thinking it, I'm just very concerned that this is going to bite us.
CarolX
I don't mean to simplify this or demean your situation - but ask both the Pres and VP - would they fly on that plane?
I worked for an aircraft parts manufacture about 20 years ago. If we had an ouot of tolerance part, and the engineer was unsure of it's usability, I would ask "Would you fly on the plane that had that part?". Always helped him with his decision.
I think your concerns are valid. Relying on suppliers deelop important design requirements after a contract has been agreed to is asking for trouble. Is this a matter of ignorance on the part of your designer(s)? Do they not have the requisite knowledge to specify what's needed, or are they just being lazy? Why not have your designer(s) meet with the suppliers before designs are released, so that the information can be put on the drawings?
Jeff Frost
Ask your engineering how they propose to meet the validation requirements contained in 7.4.3 of the standard. Procured raw materials must be re-tested to assure accuracy of supplier test reports. A reference to a specification states a specific method for testing and the requirements.
Since in your original post you also stated you’re an AS9100 house this means your organization must also look a regulatory, statutory and customer requirements related to design of product. The big boys in the industry have a lot to say about raw materials, control of designs and what they will and not accept on a drawing based on these three requirements.
D Raw Material chemical/Tensile Requirements Specifications (QQ-A-250/4, etc) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Z How to Contractually Agree on Specifications for Raw Material Purchases Supplier Quality Assurance and other Supplier Issues 15
N Subscription Service to Raw Material Specifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W Japanese Steel Specifications - A material called HNCM220M Manufacturing and Related Processes 1
K What is included in Raw Material and Component Specifications for Medical Devices? Other Medical Device Related Standards 3
R ASI 1010 ERW 12 Gage vs. HM HRPO MT 1010 - Material Specifications Supplier Quality Assurance and other Supplier Issues 4
C FM (Foreign Material) Specifications for Plastic Molded Devices & Glass Containers Other Medical Device Related Standards 5
S Design Exclusion - Drawings with Material Specifications from Outside Source AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 38
A Ford Material Specifications - Must pass WSB-M4D638-B vs. WSS-M4D-638-B Customer and Company Specific Requirements 3
V Polymer/Material Specifications - Class 1 Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Raw Material Specifications - Medical Device Company ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Outdated Material or Process Specifications in parts list and drawings. Document Control Systems, Procedures, Forms and Templates 1
S Engineering Material Specifications - Paint (zinc phosphate) and e-coat Manufacturing and Related Processes 11
T TS 16949 PPAP Material Breakdown Analysis - Steel specifications for WSD-MIA333-A2 IATF 16949 - Automotive Quality Systems Standard 4
D PPAP for Electronics - Inclusion of Dimensional Data and Material Specifications APQP and PPAP 2
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 3
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Regrind Material in Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 1
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
D Class 3 Device - Change of supplier of material Canada Medical Device Regulations 6
D List A IVD - Change to material supplier EU Medical Device Regulations 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
DMLqms Material for laboratory use or Medical Device? EU Medical Device Regulations 2
C Material from outside CER evaluation period CE Marking (Conformité Européene) / CB Scheme 8
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
6 Management of SDS and Hazardous Material Occupational Health & Safety Management Standards 2
L ASQ CBA biomedical auditor - CBA primer material is enough to study? ISO 13485:2016 - Medical Device Quality Management Systems 6
DuncanGibbons Are there any aerospace specific requirements for material resource planning? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
P GM TWO (Temporary Work Order) - Is there a specific GM format for the TWO# to be sent with the material? IATF 16949 - Automotive Quality Systems Standard 1
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
Manix Supplied Steel Material Testing Norms and Requirements Supplier Quality Assurance and other Supplier Issues 1
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
K Interpretation of significant change - material change Canada Medical Device Regulations 3
