Material standards for med-tech gloves
johan.stenstrom
I'm wondering if there are any material standards that are applicable on clothes, and more specifically med-tech gloves? Our product uses, among others: elastane, polyurethane, polyamide, polyester, nylon and pig leather. All may come in contact with human skin.
All the best,
Johan
MIREGMGR
Re: Material standards
Have you reviewed the EN 455 series for applicable requirements and references?
We don't have EN 455 on hand since we don't do gloves, but it's mentioned in the Scope section of ISO 13795-1:2002 (E) as having that applicability.
johan.stenstrom
Thanks for the reply,
However, our glove is not a disposable and not for "doctor-patient situations", but instead an aid for everyday people.
temujin
Are you sure that your gloves fall under the scope of the Medical Devices Directive? Could it also be personal protective equipment?
Because medical devices are expensive, there is no need to market your device a a Medical Device unless you really have to(Compare your intended use to the scope.)
If your gloves are Medical Devices, you would definitely take a look at the ISO 10993 series on biocompatibility.
regards
t.
Roland Cooke
Yep, they are definitely medical devices. I'll have a look at ISO 10993, thanks!
So if not for doctor-patient interaction, but for "everyday" use, what is the clinical purpose?
(I'm guessing maybe you mean they would be something like part of a first aid kit, to be worn by a soccer coach when treating an injured player?)
In that case, the coach is the "doctor", and the "player" is the patient. The gloves will be on the borderline of the MDD and PPE since they are protecting both the coach and the player.
johan.stenstrom
It's actually a grip strengthening glove. Have a look at bioservo.com for more information :)
temujin
I assume you classify the clove under the "third bullet" then...
93/42/EEC said:
‘medical device’ means any instrument, apparatus, appliance, software, material or other article, whether used alone or in combination, including the software intended by its manufacturer to be used specifically for diagnostic and/or therapeutic purposes and necessary for its proper application, intended by the manufacturer to be used for human beings for the purpose of:
  • diagnosis, prevention, monitoring, treatment or alleviation of disease,
  • diagnosis, monitoring, treatment, alleviation of or compensation for an injury or handicap,
  • investigation, replacement or modification of the anatomy or of a physiological process,
  • control of conception,
and which does not achieve its principal intended action in or on the human body by pharmacological, immunological or metabolic means, but which may be assisted in its function by such means;
I had a look at the web site you referred to and I still doubt that we are dealing with a medical device, or even with a personal protective equipment.
Even though it is "modifying a body function" (the grip), it is not, as far as I understand, intended for therapautic or diagnostic purposes.
A hammer or a screwdriver is "modifying" a body function the same way, but it is not a medical device.
I might be wrong on this though, my common sense still tells me this is not a medical device... :)
However, the glove will fall under the Low Voltage Directive.
regards
t.
Roland Cooke
It may be argued that the glove is for the alleviation of a handicap or disease.
Johan, those materials all sound fairly well-established, but I would be concerned from a prolonged duration perspective.
Maybe start with the material manufacturers themselves, see if they already have this information?
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V Use of non consensus ISO standards in Marketing Material 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
E General Training Material about the general ISO Standards Development Programme Other ISO and International Standards and European Regulations 4
J Comparative Standards For Material Other than Steel Various Other Specifications, Standards, and related Requirements 1
T Material Standard Confirmation - Mill cert standards for raw material? ie Bar, round ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Nonconforming-Material Process Nonconformance and Corrective Action 1
Stoic Details of Operational Qualification (OQ) test design for plastic extrusion processes, effect of material property noise, and GHTF/SG3/N99-10 US Medical Device Regulations 2
T Control of Nonconforming Material AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
DuncanGibbons Safe-Life, Fail-Safe and Damage Tolerant approaches and their relevant material property requirements Federal Aviation Administration (FAA) Standards and Requirements 0
T Shrinkage Testing for EPDM Material Various Other Specifications, Standards, and related Requirements 5
M Preparing a document for Raw Material of Medical Device EU Medical Device Regulations 1
J ISO 13485- 8.3.1 Non-conforming material high volume ISO 13485:2016 - Medical Device Quality Management Systems 4
Awais Taking Pictures of Outbound Material - In the Manufacturing Shop floor Manufacturing and Related Processes 5
Q G11 material Manufacturing and Related Processes 7
M Medical Device Marketing Material - Control of Social Media 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Origin of Material Review Board AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Raw Material Expirations Manufacturing and Related Processes 2
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 4
J Scrap Material Scale Calibration Required? IATF 16949 - Automotive Quality Systems Standard 21
R Revalidation under VDmax25 following material change ISO 13485:2016 - Medical Device Quality Management Systems 2
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
S Predicate Material 510(k) US Food and Drug Administration (FDA) 1
S Predicate Material 510(k) Medical Device and FDA Regulations and Standards News 3
lanley liao Who can share these material with me ? Training - Internal, External, Online and Distance Learning 1
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 4
rerusk1 MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Regrind Material in Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 1
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
D Class 3 Device - Change of supplier of material Canada Medical Device Regulations 6
D List A IVD - Change to material supplier EU Medical Device Regulations 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
DMLqms Material for laboratory use or Medical Device? EU Medical Device Regulations 2
C Material from outside CER evaluation period CE Marking (Conformité Européene) / CB Scheme 8
6 Management of SDS and Hazardous Material Occupational Health & Safety Management Standards 2
