Max and Min form diameter inspection
Singh
How often one should check max & min form diameter on parts with splines?
Any input is very much appreciated..
Thanks guys..
More information is needed. First, why are you asking? What does "form diameter" mean? What is the manufacturing process? Please answer all three questions.
Singh
Hello Jim
Following is the answer:
1. Process is stamping
2. Max and min form diameter of splines, Form diameter is that diameter which specifies the transition point between the usable involute profile and the fillet of the tooth.
3. Needed for control plan to add frequency to check form diameters.
We currently check Annually that seems like not right.
Thanks. Is your present method adequate? Have you had quality issues with the features in question? If the answer to the first question is "yes" and the second is "no," there's probably no reason to change anything.
leftoverture
Agreed. This decision should be based on risk. If risk is determined to be high, more frequent inspection is warranted. If risk is determined to be low, less frequent inspection is OK. When evaluating risk, look at such things as tool wear, number of setups per year, number of different machines used, variations in raw material, etc. I would think that if this is an important characteristic, it should be checked at least every time the process is setup.
H Max and Min Load Determination for Steam Sterilization of Liquds EU Medical Device Regulations 1
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
kedarg6500 A380 Aluminium Elongation & Specific Gravity Min OR Max Various Other Specifications, Standards, and related Requirements 2
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
2 MIN/MAX - Oversea Supplier Raw Material Supermarket Pull Systems Lean in Manufacturing and Service Industries 3
R How to assess capability for parameters which has got either Min values or Max values Statistical Analysis Tools, Techniques and SPC 2
S Offline Laboratory Scale Gauges for Min Max Diameter of Round Steel Bars General Measurement Device and Calibration Topics 6
D CP CPk from Min Max Data? Statistical Analysis Tools, Techniques and SPC 5
I Percentage of tolerance reported by supplier using the MIN or MAX dimension values Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J How do I calculate the percentage of errors, when I know min, max, mean, cp and CPK Capability, Accuracy and Stability - Processes, Machines, etc. 3
K Radius with specification only Max limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Marc Fuel tank issue (FOD) hits Boeing’s 737 MAX - Feb 2020 World News 19
M ISO 11137 - Verification dose audit for VD max method Other Medical Device Regulations World-Wide 7
S Non-Normal Data - Measurement for "straightness" with a 0.001" max tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 10
M 30% Max Study Variation Criterion - Where Cited? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R EU Regulations on powered wheelchair max speeds? EU Medical Device Regulations 7
D Setting up of a VD Max regime - VD Max 25 Discussion and Rationalisation ISO 13485:2016 - Medical Device Quality Management Systems 7
D Bioburden and Product Labels - VD Max studies on all the BOMs Other Medical Device and Orthopedic Related Topics 9
Marc US Internet Backbones Could Max Out before 2010, Study Says After Work and Weekend Discussion Topics 3
W Warping / Flatness SPC - X bar-R chart - Control is Max 0.15 Statistical Analysis Tools, Techniques and SPC 5
S Gage bias and limits - Is there a max limit to Bias we can stipulate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P SPC in job shop? CNC machine producing a max of 50 pieces per job Statistical Analysis Tools, Techniques and SPC 4
C Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ?? Capability, Accuracy and Stability - Processes, Machines, etc. 13
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
Rameshwar25 Min working experience for IATF 16949 third party auditor IATF 16949 - Automotive Quality Systems Standard 5
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
R CSA Descriptive Test Reports: PC-B's min 1.6mm thick requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I Which control chart to use for SPC control for torque moment which value is min 15 Nm Statistical Analysis Tools, Techniques and SPC 7
R Effective case depth of .508mm MIN. How do I measure this? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q Gage Supplier - Need a 72" (min) Digital Read Out LLM for the Shop Floor General Measurement Device and Calibration Topics 2
P Rp with a 1.33 min Cpk (Rp?) - Anyone know what Rp represents? Capability, Accuracy and Stability - Processes, Machines, etc. 3
D Faxback form versus amendment License for Class II Canada Medical Device Regulations 1
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 1
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 4
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
