Max and Min Load Determination for Steam Sterilization of Liquds
htcoztrk
Hello all.
We're developping a new medical device and it requires to be sterilized by steam. Me or neither my company only have experience on EO and irridation sterilization.
Now we're preparing the protocol for validation and try to determine the load configuration. Iknow that minimum loads of liquids tend to heat faster than maximum load so we'll perform triplicate cycle for both load. I have one question about minimum and maximum load for sterilization liquid loads. Now we're going to sterilize items from 1ml to 5ml in syringe using steam sterilization. I'm really having troubles case how we should determine the min and max load.
a) Select 5ml (biggest size) as worst case (because slowest to heat) and configurate the smallest quantity as min load and biggest quantity for chamber as max load
b) Select 1ml as maximum and load the chamber with the biggest quantity and select 5ml as minimum load and load the chamber with biggest quantity of size. (But in this case do we have to use the biggest quantity for both size in routine processing?)
c) Select the smallest quantity of smallest size (1ml) as minimum and select the biggest quantity of biggest size (5ml) as maximum?
d) Select minimum and maximum load individually for each size. The smallest quantity as minimum and biggest quantity as minimum for the smallest size (1ml) and biggest size (5ml). Total there will be 2 min and 2 max load configuration?
Thank you in advance.
chris1price
Hi, I'm not an expert on steam sterilisation either, however, I would suggest looking through the various parts of ISO17665. In particular, Part 3 covers . "Guidance on the designation of a medical device to a product family and processing category for steam sterilization". This may give you the answer you are looking for.
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
kedarg6500 A380 Aluminium Elongation & Specific Gravity Min OR Max Various Other Specifications, Standards, and related Requirements 2
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
2 MIN/MAX - Oversea Supplier Raw Material Supermarket Pull Systems Lean in Manufacturing and Service Industries 3
R How to assess capability for parameters which has got either Min values or Max values Statistical Analysis Tools, Techniques and SPC 2
S Offline Laboratory Scale Gauges for Min Max Diameter of Round Steel Bars General Measurement Device and Calibration Topics 6
D CP CPk from Min Max Data? Statistical Analysis Tools, Techniques and SPC 5
I Percentage of tolerance reported by supplier using the MIN or MAX dimension values Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J How do I calculate the percentage of errors, when I know min, max, mean, cp and CPK Capability, Accuracy and Stability - Processes, Machines, etc. 3
K Radius with specification only Max limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Marc Fuel tank issue (FOD) hits Boeing’s 737 MAX - Feb 2020 World News 19
M ISO 11137 - Verification dose audit for VD max method Other Medical Device Regulations World-Wide 7
S Non-Normal Data - Measurement for "straightness" with a 0.001" max tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 10
M 30% Max Study Variation Criterion - Where Cited? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R EU Regulations on powered wheelchair max speeds? EU Medical Device Regulations 7
D Setting up of a VD Max regime - VD Max 25 Discussion and Rationalisation ISO 13485:2016 - Medical Device Quality Management Systems 7
D Bioburden and Product Labels - VD Max studies on all the BOMs Other Medical Device and Orthopedic Related Topics 9
Marc US Internet Backbones Could Max Out before 2010, Study Says After Work and Weekend Discussion Topics 3
W Warping / Flatness SPC - X bar-R chart - Control is Max 0.15 Statistical Analysis Tools, Techniques and SPC 5
S Gage bias and limits - Is there a max limit to Bias we can stipulate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P SPC in job shop? CNC machine producing a max of 50 pieces per job Statistical Analysis Tools, Techniques and SPC 4
C Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ?? Capability, Accuracy and Stability - Processes, Machines, etc. 13
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
Rameshwar25 Min working experience for IATF 16949 third party auditor IATF 16949 - Automotive Quality Systems Standard 5
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
R CSA Descriptive Test Reports: PC-B's min 1.6mm thick requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I Which control chart to use for SPC control for torque moment which value is min 15 Nm Statistical Analysis Tools, Techniques and SPC 7
R Effective case depth of .508mm MIN. How do I measure this? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q Gage Supplier - Need a 72" (min) Digital Read Out LLM for the Shop Floor General Measurement Device and Calibration Topics 2
P Rp with a 1.33 min Cpk (Rp?) - Anyone know what Rp represents? Capability, Accuracy and Stability - Processes, Machines, etc. 3
F Plastics cans shelf life determination under static load Manufacturing and Related Processes 1
T GDT Callout - How to call out a note that requires some clamp load Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
N Heavy tare to simulate high load in a routine sensitivity test of a floor scale? General Measurement Device and Calibration Topics 3
H EO Sterilization Validation - Sterility Testing and Load Configuration Other Medical Device Related Standards 1
C AMS2750E - Noble metal as a Load sensor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 2
N Damaged Load Cell After Calibration - Who Should Pay? General Measurement Device and Calibration Topics 3
E IEC 60601-1 Tensile Load Safety Factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Calibration Standard of Load Indicating Device General Measurement Device and Calibration Topics 4
D What is your experience with FDA using "mixed load" i EO sterilization Other Medical Device Related Standards 1
N Load Thermocouple requirement for TUS (Temperature Uniformity Survey) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Work Load Evaluation for Project Management Personnel VDA Standards - Germany's Automotive Standards 4
K Autoclave Log - Do we have to monitor the usage for every load? General Measurement Device and Calibration Topics 3
M MCOSMOS - Monitor your CMM load time Quality Assurance and Compliance Software Tools and Solutions 2
D Gage R&R on a Load Cell fixture that tests the resistance of a Headrest Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Fluorescent Lamp Load Test for Switch in IEC 60669-1 Standard General Measurement Device and Calibration Topics 5
