Maximum allowed eccentricity for any shaft or hole diameter
rnsvasan
Is there any thumb rule or standard that specifies maximum allowed eccentricity for any shaft or hole diameter. for an example if my hole diameter tolerance is 21 microns, then how much i can allow eccentricity if there is no any specification given by the customer.
Thanx in advance
F
falconer65
The rule of thumb would be the diameter needs to measure in specification no matter where it is measured. But a tolerance of 21 microns with no roundness or cylindricity call out? The real questions are, what is the application and what does the customer expect?
AlanC
we would normally go for half the tol as thumb, but if roundness is being measured then its not just the tolerance but the shape of the roundness which is also important which can highlight issues, especially if the hole as a keyway in it, in which case the roundness can be looked at locally away from the keyway. We would also apply half the tol rule mainly for bores/shafts that form part of an assembly as a concentricity tolerance since this is typically what comes out from bearing calcs, but if its not called for then stay away
Stijloor
Thanx in advance
Eccentricity is a location error. Are you referring to a possible circularity or cylindricity (form) error? In the USA according the ASME Y14.5 standard, "Rule #1" states that the limits of size control dimensional as well as form deviations. At Maximum Material Condition (MMC), form shall be perfect. ISO standards subscribe to the independency principle and state that form does not have to be perfect at MMC unless the "envelope principle" is invoked by used the "E" modifier.
Stijloor.
N
NANDAKUMAR_A
Hi Srini,
The general understanding is one third of the Tolerance can be taken for the Roundness / Form parameters. However the application is also to studied to use the same.
Mr.Happy
An other question cums up, If roundness is measured (we also use half the tolerance) then how many measuring point do you choose (using CMM) and on what is this based ?
L
Livika
Thanx in advance
The eccentricity (as I know it) is always referred to something (for example eccentricity of hole referred to external diameter in case of bushing, eccentricity of shaft diameter referred to centers or another diameter) and does not depend on the tolerance of the specific diameter. But maybe you should specify what exactly you mean with eccentricity.
Michael_M
Not using a standard to decide this, but when I check roundness (of a hole) using the CMM, I use a minimum of 12 points. This measures the diameter every 30 degrees. If speed is not a factor or I can afford to add a bit of inspection time, I will increase this to 16 (22.5 degrees) or 24 (15.0 degrees). I typically stick with 12 points.
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
Judy Abbott Increase the maximum allowable dose for E-beam sterilization Reliability Analysis - Predictions, Testing and Standards 2
M Maximum Height for the stored material or stock materials Occupational Health & Safety Management Standards 1
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
V Correlating Maximum 'Range' of Values for a given "RSD" (Control Limits) Statistical Analysis Tools, Techniques and SPC 3
M What is the maximum permissible period of delaying the validation of equipment? Other Medical Device Regulations World-Wide 4
C Q as the Datum Maximum Material Condition then MINUS 0.020 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
R Maximum Reverse Speed Limit for Powered Wheelchairs Other US Medical Device Regulations 2
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
R ISO 14644-1 maximum particulate concentration limits concern Other ISO and International Standards and European Regulations 2
K Maximum Material Condition on Diameter Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L Maximum voltage for IEC 60601? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Step by Step Gauge R&R with 10% maximum allowable Gauge Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Aseptic Processing - Maximum SAL using Aseptic Processing for Sterilization Other ISO and International Standards and European Regulations 4
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
optomist1 Maximum Shift Tolerance Restrained Part - Calculation of Datum Shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Is there a "maximum time limit" for nonconformity to fix? Internal Auditing 11
S What's the maximum post limit in a day? Elsmar Cove Forum ToS and Forum Policies 6
R Can maximum ambient operating temperature be specified higher than 40C? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Maximum error of a z value from sample data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
D How to inspect maximum allowable contaminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
2 ISO 9001 should be implemented before CMMI for maximum effectiveness? Quality Manager and Management Related Issues 2
M Ergonomics - Human Hand - Maximum force - Wheel/Flywheel - Help ASAP :) Human Factors and Ergonomics in Engineering 8
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
Chennaiite Process Capability for a specification with Maximum Material Condition (MMC) Statistical Analysis Tools, Techniques and SPC 4
F Maximum walking distance for assembly line worker Human Factors and Ergonomics in Engineering 28
M What is maximum limit for MU (Measurement Uncertainty) or acceptable criteria? Measurement Uncertainty (MU) 5
S GD&T Rule 1: Gage size for form check at MMC (maximum material condition)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D How to Measure a Diameter - Average or Maximum/Minimum? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
M Maximum Permissible Error for Monitoring and Measurement Devices General Measurement Device and Calibration Topics 19
N QMS Scope length limited to 10 to 15 words maximum - How is that possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Internal threads - Maximum / Minor accept/reject diameter inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q Maximum minor thread diameter of UNF internal threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Corrective and Preventive Action - State Maximum time for follow-up required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
