Maximum Height for the stored material or stock materials
  • Thread starter Mhd Ghiyath Anas
  • Start date
Mhd Ghiyath Anas
I want to know the acceptable limit of height for any stock materials for examples the blocks or bundles is ( 3 m ) ?
I want to know the source of the information in which standard and where ?
Henria
OSH Officer
Hello !
I do not know of any such standard (but another person may be able to identify one).
I think it is imposible to standardize a stability rule of this kind of storage by stacking similar loads.
The "height limit" stability of such a column can not be absolute: it necessarily depends on the width of the base and the greater or less "flexibility" of the blocks or packets. So this can only be a specific rule to the company, witch needs to be determined locally empirically by appreciating the risky "ballrooming" of a column "too high" for each type of packets ...
Cordially.
PS: and what to say in addition to the risk of "domino effect" if a first column switches ...
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
Judy Abbott Increase the maximum allowable dose for E-beam sterilization Reliability Analysis - Predictions, Testing and Standards 2
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
V Correlating Maximum 'Range' of Values for a given "RSD" (Control Limits) Statistical Analysis Tools, Techniques and SPC 3
M What is the maximum permissible period of delaying the validation of equipment? Other Medical Device Regulations World-Wide 4
C Q as the Datum Maximum Material Condition then MINUS 0.020 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
R Maximum Reverse Speed Limit for Powered Wheelchairs Other US Medical Device Regulations 2
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
R ISO 14644-1 maximum particulate concentration limits concern Other ISO and International Standards and European Regulations 2
K Maximum Material Condition on Diameter Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L Maximum voltage for IEC 60601? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Step by Step Gauge R&R with 10% maximum allowable Gauge Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Aseptic Processing - Maximum SAL using Aseptic Processing for Sterilization Other ISO and International Standards and European Regulations 4
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
optomist1 Maximum Shift Tolerance Restrained Part - Calculation of Datum Shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Is there a "maximum time limit" for nonconformity to fix? Internal Auditing 11
S What's the maximum post limit in a day? Elsmar Cove Forum ToS and Forum Policies 6
R Maximum allowed eccentricity for any shaft or hole diameter Misc. Quality Assurance and Business Systems Related Topics 7
R Can maximum ambient operating temperature be specified higher than 40C? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Maximum error of a z value from sample data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
D How to inspect maximum allowable contaminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
2 ISO 9001 should be implemented before CMMI for maximum effectiveness? Quality Manager and Management Related Issues 2
M Ergonomics - Human Hand - Maximum force - Wheel/Flywheel - Help ASAP :) Human Factors and Ergonomics in Engineering 8
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
Chennaiite Process Capability for a specification with Maximum Material Condition (MMC) Statistical Analysis Tools, Techniques and SPC 4
F Maximum walking distance for assembly line worker Human Factors and Ergonomics in Engineering 28
M What is maximum limit for MU (Measurement Uncertainty) or acceptable criteria? Measurement Uncertainty (MU) 5
S GD&T Rule 1: Gage size for form check at MMC (maximum material condition)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D How to Measure a Diameter - Average or Maximum/Minimum? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
M Maximum Permissible Error for Monitoring and Measurement Devices General Measurement Device and Calibration Topics 19
N QMS Scope length limited to 10 to 15 words maximum - How is that possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Internal threads - Maximum / Minor accept/reject diameter inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q Maximum minor thread diameter of UNF internal threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Corrective and Preventive Action - State Maximum time for follow-up required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
