Maximum internal component and casing temperature? Power supply and control circuitry
Afternoon everyone
We are investigating the possibility of building a power supply and control circuitry into one of our products. I need to make sure there isn't a maximum temperature for the internal components or for the casing specified in a standard somewhere. The product is an electronic device, and may be used in any environment, medical, industrial or research.
Does anyone know of any values we may apply to ensure compliance with the majority of standards?
Paul
:confused:
M Caruso
My company makes capacitors. Based on our catalog specifications, I see that a safe operating temperature is usually 85*C with many of our capacitors able to function up to 125*C.
Al Rosen
sonflowerinwales said:
Afternoon everyone
Paul
:confused:
I like 65 deg C (150 deg F) for the case (this is the maximum temperature you can touch), but you need to know what the max rating of the materials are. Maximum component temperatures are dependent upon the maximum allowed internal operating temp of the component. You also need to know where this is going to be used.
:2cents:The bottom line is that there are no short cuts and the engineers need to do some work. You can find standards on the IEC and UL websites
M Caruso
I should have noted that the operating temperature would be defined as ambient temperature plus any heat given off by the part during use.
L Internal threads - Maximum / Minor accept/reject diameter inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q Maximum minor thread diameter of UNF internal threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
Judy Abbott Increase the maximum allowable dose for E-beam sterilization Reliability Analysis - Predictions, Testing and Standards 2
M Maximum Height for the stored material or stock materials Occupational Health & Safety Management Standards 1
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
V Correlating Maximum 'Range' of Values for a given "RSD" (Control Limits) Statistical Analysis Tools, Techniques and SPC 3
M What is the maximum permissible period of delaying the validation of equipment? Other Medical Device Regulations World-Wide 4
C Q as the Datum Maximum Material Condition then MINUS 0.020 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
R Maximum Reverse Speed Limit for Powered Wheelchairs Other US Medical Device Regulations 2
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
R ISO 14644-1 maximum particulate concentration limits concern Other ISO and International Standards and European Regulations 2
K Maximum Material Condition on Diameter Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L Maximum voltage for IEC 60601? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Step by Step Gauge R&R with 10% maximum allowable Gauge Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Aseptic Processing - Maximum SAL using Aseptic Processing for Sterilization Other ISO and International Standards and European Regulations 4
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
optomist1 Maximum Shift Tolerance Restrained Part - Calculation of Datum Shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Is there a "maximum time limit" for nonconformity to fix? Internal Auditing 11
S What's the maximum post limit in a day? Elsmar Cove Forum ToS and Forum Policies 6
R Maximum allowed eccentricity for any shaft or hole diameter Misc. Quality Assurance and Business Systems Related Topics 7
R Can maximum ambient operating temperature be specified higher than 40C? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Maximum error of a z value from sample data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
D How to inspect maximum allowable contaminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
2 ISO 9001 should be implemented before CMMI for maximum effectiveness? Quality Manager and Management Related Issues 2
M Ergonomics - Human Hand - Maximum force - Wheel/Flywheel - Help ASAP :) Human Factors and Ergonomics in Engineering 8
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
Chennaiite Process Capability for a specification with Maximum Material Condition (MMC) Statistical Analysis Tools, Techniques and SPC 4
F Maximum walking distance for assembly line worker Human Factors and Ergonomics in Engineering 28
M What is maximum limit for MU (Measurement Uncertainty) or acceptable criteria? Measurement Uncertainty (MU) 5
S GD&T Rule 1: Gage size for form check at MMC (maximum material condition)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D How to Measure a Diameter - Average or Maximum/Minimum? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
M Maximum Permissible Error for Monitoring and Measurement Devices General Measurement Device and Calibration Topics 19
N QMS Scope length limited to 10 to 15 words maximum - How is that possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
