Maximum Mains Voltage (clause 8.5.3)
phase90
Clause 8.5.3 says that for single-phase or DC supply mains, including internally powered equipment, the maximum mains voltage is to be 250V. If the supply is DC, are they referring to 250 V DC or 250 VAC (353 V DC peak)?
phase90
From the IEC 60601-1 ed. 3.1, Clause 8.5.3:
The MAXIMUM MAINS VOLTAGE shall be determined as follows:
-for single-phase or d.c. SUPPLY MAINS powered ME EQUIPMENT, including INTERNALLY POWERED ME EQUIPMENT that also has a means of connection to a SUPPLY MAINS, the MAXIMUM MAINS VOLTAGE is the highest RATED supply voltage; unless this is less than 100V, in which case the MAXIMUM MAINS VOLTAGE is 250 V;
-for polyphase ME EQUIPMENT, the MAXIMUM MAINS VOLTAGE is the highest RATED phase to neutral supply voltage;
-for other INTERNALLY POWERED ME EQUIPMENT, the MAXIMUM MAINS VOLTAGE is 250 V.
The clause talks about both single phase (AC) and DC type (including battery) sources. Does one interpret the voltage as AC for AC type and DC for DC types? Or for VAC regardless of the the source?
Ninja
Looking for Reality
Seems pretty clear (I am not in medical)...
If it is DC, it is the highest rated voltage unless that is <100 100VDC, in which case it is 250VDC.
If it is polyphase, it is the highest rated voltage.
If neither of these, it is 250V...of either.
Ain't nothing in there that allows cool math to get up to 353...
...but again, I'm not in medical. others here are, and they may chime in.
Peter Selvey
The reference to 250V is really about some of the special tests in IEC 60601-1 which are based on mains voltages is coming from other sources in the room, not the device itself.
There are (I think) only two related tests: mains on applied part (for BF and CF parts only), and mains on a signal part (if there are no controls from Clause 16, ME systems).
Both of these tests are based on hypothetical mains voltage from the environment, as such it's necessary to establish what mains voltage should be used. If the device is mains powered, then use the rated mains voltage. If not, use 250V. But, if you do end up with this 250V, keep in mind it's just for these tests, and only these tests. Careful reading of the standard is needed as to when it uses "maximum mains voltage".
The voltage is clearly ac, since it is intended to represent mains voltage in the environment. Note that the actual test (mains on applied part/signal part) uses rated mains +10% so the actual test is 275Vrms (389Vp). But if it is applicable, it should only be applied in places where there is adequate insulation (e.g. 1.5kV/4mm for F type applied parts, or an isolation barrier in signal I/O part). You would not apply it just to see what happens.
In Amendment 2 this has been dropped to 240V. This makes sense although it does add to the confusion, since a working voltage of 250V clearly identified that it's just for the special tests; a working voltage of 240V could be misinterpreted as indicating the device has mains :)
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
Judy Abbott Increase the maximum allowable dose for E-beam sterilization Reliability Analysis - Predictions, Testing and Standards 2
M Maximum Height for the stored material or stock materials Occupational Health & Safety Management Standards 1
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
V Correlating Maximum 'Range' of Values for a given "RSD" (Control Limits) Statistical Analysis Tools, Techniques and SPC 3
M What is the maximum permissible period of delaying the validation of equipment? Other Medical Device Regulations World-Wide 4
C Q as the Datum Maximum Material Condition then MINUS 0.020 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
R Maximum Reverse Speed Limit for Powered Wheelchairs Other US Medical Device Regulations 2
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
R ISO 14644-1 maximum particulate concentration limits concern Other ISO and International Standards and European Regulations 2
K Maximum Material Condition on Diameter Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L Maximum voltage for IEC 60601? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Step by Step Gauge R&R with 10% maximum allowable Gauge Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Aseptic Processing - Maximum SAL using Aseptic Processing for Sterilization Other ISO and International Standards and European Regulations 4
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
optomist1 Maximum Shift Tolerance Restrained Part - Calculation of Datum Shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Is there a "maximum time limit" for nonconformity to fix? Internal Auditing 11
R Maximum allowed eccentricity for any shaft or hole diameter Misc. Quality Assurance and Business Systems Related Topics 7
R Can maximum ambient operating temperature be specified higher than 40C? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Maximum error of a z value from sample data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
D How to inspect maximum allowable contaminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
2 ISO 9001 should be implemented before CMMI for maximum effectiveness? Quality Manager and Management Related Issues 2
M Ergonomics - Human Hand - Maximum force - Wheel/Flywheel - Help ASAP :) Human Factors and Ergonomics in Engineering 8
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
Chennaiite Process Capability for a specification with Maximum Material Condition (MMC) Statistical Analysis Tools, Techniques and SPC 4
F Maximum walking distance for assembly line worker Human Factors and Ergonomics in Engineering 28
M What is maximum limit for MU (Measurement Uncertainty) or acceptable criteria? Measurement Uncertainty (MU) 5
S GD&T Rule 1: Gage size for form check at MMC (maximum material condition)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D How to Measure a Diameter - Average or Maximum/Minimum? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
M Maximum Permissible Error for Monitoring and Measurement Devices General Measurement Device and Calibration Topics 19
N QMS Scope length limited to 10 to 15 words maximum - How is that possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Internal threads - Maximum / Minor accept/reject diameter inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q Maximum minor thread diameter of UNF internal threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Corrective and Preventive Action - State Maximum time for follow-up required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
