MDR – Article 120 – Transitional provisions
florijanl
Hi all,
Guidance on significant changes regarding the transitional provision under Article 120 describes if a design change is significant or not.
But what if you decide to introduce for example a Bluetooth or Wi-Fi connection to the otherwise offline product?
Best regards
Raisin picker
Did you check MDCG 2020-3? My gut feeling: If you just enable an already existing but previously blocked option, this might fall under minor change. If you introduce this with new hardware and/or software, then -->MDR.
ADVICE: Discuss with your NB as soon as possible. They will have to approve your reasoning in the end.
shimonv
That is a little tricky because you are introducing new risks for cyber security, new hardware and a new software build that supports wireless communication. If you have a good relationship with the notified body, it's best to ask. Otherwise, you can go through MDCG guidance flowchart and build a good regulatory assessment around it.
Shimon
paris
hi every body
I have question about changes in medical device, as you know under MDD we report any changes to N.B and after approval implement changes whether substantial or not. now according to article 120 of MDR and its guide lines, the significant changes will make MDD certificate invalid. but I dont know shall I report any changes to N.B? or just significant one?
im a non-EU manufacture, so who is my CA? is it CA of Authorized representative?
Ed Panek
QA RA Small Med Dev Company
We made a memo template that goes through the decision tree from MDCG 2020-3 to inform us when we have made a substantial change.
Ed Panek
This is the main portion
Guidance Ref. No.
Question
Answer
Rationale
MAIN SECTION
Design Changes and Changes of the Intended Purpose
Which may be Considered “Significant“ When Interpreting the First Sentence of MDR Art. 120(3)
Change of the Intended Purpose?
Yes -See Section A / No – See Question X
No
X
Design change related to corrective actions?
Yes - Non-significant change per MDR Art. 120(3) / No – See Question B
No
Change of the design or performance specification?
Yes -See Section B / No – See Question C
No
Software change?
Yes – See Section C / No – See Question D
Yes
Change of Material?
Yes – See Section D / No – See Question E
No
E
Change of terminal sterilization method of device or packaging design with impact to the sterilisation?
Yes – See Flow Chart E / No – Non-significant change per MDR Art. 120(3)
N/A
Device is not Sterile
SECTION A – Design Changes and Changes of the Intended Purpose
A1
Limitation of the Intended Purpose?
Yes – Return to main chart question X / No – See Question A2
N/A
A2
Extension or change of the Intended Purpose?
Yes - The change is considered Significant per MDR Art. 120(3)/ No – See Question A3
N/A
A3
New user or patient population?
Yes - The change is considered Significant per MDR Art. 120(3)/ No – See Question A4
N/A
A4
Change of clinical use in anatomical site, access site or deployment metods?
Yes - The change is considered Significant per MDR Art. 120(3)/ No – Return to main chart question X
N/A​
SECTION B – Design Changes and Changes of the Intended Purpose
B1
Does the change require further clinical or usability data to support safety and performance? Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question B2
N/A​
B2
Do new risks require control measures or are existing risks negatively affected? Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question B3
N/A
B3
Change of built-in control mechanism, operating principles, source of energy or alarms?
Yes - The change is considered Significant per MDR Art. 120(3) / No – Return to Main Chart Question C (or move directly to E if Chart D was previously used)
N/A
SECTION C – Design Changes and Changes of the Intended Purpose
C1
New or major change of operating system or any
component?​
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question C2
No
C2
New or modified architecture or database structure, change of an algorithm?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question C3
No
C3
Required user input replaced by closed loop algorithm ?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question C4
No
C4
New diagnostic or therapeutic feature, or new channel of interoperability?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question C5
No
C5
New user interface or presentation of data?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question C6
No
C6
Minor Change?
Yes - Return to Main Chart Question D / No – The change is considered Significant per MDR Art. 120(3)
Yes
SECTION D – Design Changes and Changes of the Intended Purpose
D1
Change to a material of human/animal origin including addition of new materials?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question D2
N/A
D2
Change to a material containing a MS or to th MS itself or, a change which may impact the quality, safety or efficacy of a MS?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question D3
N/A
D3
Changed ingredient or material from existing supplier meets existing specification?
Yes – Return to Main Chart Question E/ No – See Question D4
N/A
D4
Ingredient or material from new supplier meets existing specification?
Yes – Change to be assessed in
Accordance with Chart B/ No – The change is considered Significant per MDR Art. 120(3)
N/A
SECTION E – Design Changes and Changes of the Intended Purpose
E1
Change of terminal sterilization method?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question E2
N/A
E2
Design Change which affects or changes the sterility assurance?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question E3
N/A
E3
Change in packaging design which affect functionality, safety, stability or seal integrity?
Yes - The change is considered Significant per MDR Art. 120(3) / No – See Question E4
N/A
E4
Shelf-life change validated by protocols approved by the notified body?
Yes - The change is considered a non-Significant change per MDR Art. 120(3) / No – The change is considered Significant per MDR Art. 120(3)
N/A
END OF SIGNIFICANT CHANGE DECISION MATRIX
A Declaring Conformity with MDR Article 120(3) for an MDD Legacy Device EU Medical Device Regulations 1
S Summary of safety and clinical performance and Article 120(3) of the MDR EU Medical Device Regulations 4
N EUDAMED postponement and compliance with Article 120 (3) MDR for Legacy Devices EU Medical Device Regulations 10
F The meaning of MDR Article 61 6(b) EU Medical Device Regulations 1
S Meaning of Article 61 (10) of the MDR 2017/745 EU Medical Device Regulations 3
A MDR Article 16 Certification of Distributors by a Notified Body? EU Medical Device Regulations 8
E Article 17 MDR - (Re-)Processing EU Medical Device Regulations 0
H Article 22 MDR System EU Medical Device Regulations 16
H MDR Article 13(c) EU Medical Device Regulations 6
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
M Examples of Combination Products - MDR Article 1 (8) and MDR Article 1(9) Medical Device and FDA Regulations and Standards News 3
U MDD Article 12/ MDr Article 22 interpretation EU Medical Device Regulations 2
M MDR Article 22 Interpretation EU Medical Device Regulations 3
L EU MDR Article 86 PSUR EU Medical Device Regulations 1
R Requirements for MDR Article 22 Systems EU Medical Device Regulations 1
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
S Class I MDR Article 10 – QMS EU Medical Device Regulations 1
R Clinical evaluation without clinical data - MDR Article 61(10) EU Medical Device Regulations 9
A MDR Article 22 applicability - Legal manufacturer EU Medical Device Regulations 9
S Article 61 - MDR Clinical Investigation Requirement EU Medical Device Regulations 9
C Article 16 MDR - Medicine packaged together with Medical Device EU Medical Device Regulations 0
F MDR system/procedurepack (article 22) with device acc. to MDD and MDR CE Marking (Conformité Européene) / CB Scheme 2
R MDR Article 22: Systems and procedure packs Other Medical Device Regulations World-Wide 12
T EU MDR Article 61- Clinical Evaluation EU Medical Device Regulations 2
M Informational EU – MDCG 2019-7 Guidance on Article 15 of the Medical Device Regulation (MDR) and in vitro Diagnostic Device Regulation (IVDR) regarding a “person re Medical Device and FDA Regulations and Standards News 7
F Interpretation of MDR 2017/745 Article 23 - CE Mark Requirements EU Medical Device Regulations 8
E MDR Article 117 / Impact to New Marketing Authorization Applications Other Medical Device Regulations World-Wide 1
C Access to Technical Documentation - MDR Chapter VI Article 61 EU Medical Device Regulations 4
T MDR article 22 - System of 2 CE products and validation / usability? EU Medical Device Regulations 10
T Clarification on MDR - Article 18(d) - Implant Card EU Medical Device Regulations 14
M Is MDR Article 61(5) Unrealistic? EU Medical Device Regulations 11
D Responsible for regulatory compliance (Article 15 of MDR 2017/745) Quality Manager and Management Related Issues 4
S EU MDR - Liability Clause per article 31 EU Medical Device Regulations 22
K Subcontractors Providing Services Under MDD or MDR need ISO 13485 from EU Notified Body? CE Marking (Conformité Européene) / CB Scheme 3
D MDR: Active medical device or not? Medical Information Technology, Medical Software and Health Informatics 4
T Justification of use of non-harmonized standards for MDR conformity Other Medical Device Related Standards 10
S Repackaging and translation under MDR EU Medical Device Regulations 14
Ed Panek MDR Delays Poll EU Medical Device Regulations 0
T MDR PMS System Vs. Plan Vs. Procedures EU Medical Device Regulations 3
D MDR classification and DoC requirements Medical Device and FDA Regulations and Standards News 1
N Shelf life guidance EU MDR, class 1 and class 2 Medical Devices EU Medical Device Regulations 2
G UKCA and EU MDR marking UK Medical Device Regulations 5
G Updating MDD devices after MDR transitional period EU Medical Device Regulations 0
J Changes to OS - Significant change under MDR EU Medical Device Regulations 8
D Direct-Marking Requirements under MDR 2017/745 EU Medical Device Regulations 3
G Significant changes on MDD devices/Old Devices after MDR transitional period EU Medical Device Regulations 1
P MDR conformity EU Medical Device Regulations 1
P MDR documentation submissions EU Medical Device Regulations 4
