MDR article 54(2) "modifying"
In MDR, (b) of the article 54(2) is below.
2. The procedure referred to in paragraph 1 shall not be required for the devices referred to therein:
(b) where the device has been designed by modifying a device already marketed by the same manufacturer for the same intended purpose, provided that the manufacturer has demonstrated to the satisfaction of the notified body that the modifications do not adversely affect the benefit-risk ratio of the device; or
and MDCG 2019-3 said the word “modification” shall be meant as limited only to those modifications needed in order to comply with the new legal requirements introduced by the MDR.
If the intended use is same as the marketed device, but only the dimensions are changed, can it be said that it is a modified device according to the article 54(2b) and MDCG 2019-3?
I wonder if CECP can be exempt if I add a model with only the dimensions modified when applying the MDR.
Thank you.
Raisin picker
Discuss this with your NB:
I think there's still no clear path outlined. The only change satisfying MDCG 2019-3 would, in my opinion, be labelling. If you change the dimensions by adding an intermediate length in your hip stems, your chances are good that the NB accepts this. If you add a shorter or longer size, especially one not covered by similar devices, that's something else.
Be aware that the NB has to justify the decision in the CEAR, and that the CEAR has to be submitted to the commision in any case (Article 54(3)). And, the same question will arise when you introduce the change after initial certification. Will be more costly, but you will have your original device on the market already.
So, discuss with your NB.
R EU MDR Article 22 applicability of medical device with components. EU Medical Device Regulations 4
V MDR – Article 65 – Clinical investigations on minors EU Medical Device Regulations 6
P MDR Article 27 - UDI - Keeping records of UDIs EU Medical Device Regulations 1
F The meaning of MDR Article 61 6(b) EU Medical Device Regulations 1
S Meaning of Article 61 (10) of the MDR 2017/745 EU Medical Device Regulations 3
A MDR Article 16 Certification of Distributors by a Notified Body? EU Medical Device Regulations 8
A Declaring Conformity with MDR Article 120(3) for an MDD Legacy Device EU Medical Device Regulations 1
S Summary of safety and clinical performance and Article 120(3) of the MDR EU Medical Device Regulations 4
E Article 17 MDR - (Re-)Processing EU Medical Device Regulations 0
H Article 22 MDR System EU Medical Device Regulations 16
F MDR – Article 120 – Transitional provisions EU Medical Device Regulations 8
H MDR Article 13(c) EU Medical Device Regulations 6
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
M Examples of Combination Products - MDR Article 1 (8) and MDR Article 1(9) Medical Device and FDA Regulations and Standards News 3
U MDD Article 12/ MDr Article 22 interpretation EU Medical Device Regulations 2
M MDR Article 22 Interpretation EU Medical Device Regulations 3
L EU MDR Article 86 PSUR EU Medical Device Regulations 1
R Requirements for MDR Article 22 Systems EU Medical Device Regulations 1
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
S Class I MDR Article 10 – QMS EU Medical Device Regulations 1
R Clinical evaluation without clinical data - MDR Article 61(10) EU Medical Device Regulations 9
A MDR Article 22 applicability - Legal manufacturer EU Medical Device Regulations 13
S Article 61 - MDR Clinical Investigation Requirement EU Medical Device Regulations 9
C Article 16 MDR - Medicine packaged together with Medical Device EU Medical Device Regulations 0
F MDR system/procedurepack (article 22) with device acc. to MDD and MDR CE Marking (Conformité Européene) / CB Scheme 2
N EUDAMED postponement and compliance with Article 120 (3) MDR for Legacy Devices EU Medical Device Regulations 10
R MDR Article 22: Systems and procedure packs Other Medical Device Regulations World-Wide 12
T EU MDR Article 61- Clinical Evaluation EU Medical Device Regulations 2
M Informational EU – MDCG 2019-7 Guidance on Article 15 of the Medical Device Regulation (MDR) and in vitro Diagnostic Device Regulation (IVDR) regarding a “person re Medical Device and FDA Regulations and Standards News 7
F Interpretation of MDR 2017/745 Article 23 - CE Mark Requirements EU Medical Device Regulations 8
E MDR Article 117 / Impact to New Marketing Authorization Applications Other Medical Device Regulations World-Wide 1
C Access to Technical Documentation - MDR Chapter VI Article 61 EU Medical Device Regulations 4
T MDR article 22 - System of 2 CE products and validation / usability? EU Medical Device Regulations 10
T Clarification on MDR - Article 18(d) - Implant Card EU Medical Device Regulations 14
M Is MDR Article 61(5) Unrealistic? EU Medical Device Regulations 11
D Responsible for regulatory compliance (Article 15 of MDR 2017/745) Quality Manager and Management Related Issues 4
S EU MDR - Liability Clause per article 31 EU Medical Device Regulations 22
M MDR Legal requirements EU Medical Device Regulations 3
Ed Panek MDR Audit Comment EU Medical Device Regulations 9
J Minor / Major findings with MDR EU Medical Device Regulations 4
R MDR Clinical Evaluation Plan EU Medical Device Regulations 4
K Qualified MDR internal auditor? EU Medical Device Regulations 7
J Clinical Evaluation For Instruments - Class I, Class Ir, Class Im, and Class IIa - EU MDR EU Medical Device Regulations 4
G MDR Translation Requirements in Member States EU Medical Device Regulations 8
R General Obligations of Importers under EU MDR EU Medical Device Regulations 2
I MDR Audit: NC per MDR Annex IX Administrative provisions 8. EU Medical Device Regulations 6
R Device with WiFi communication - EU MDR vs. EU RED EU Medical Device Regulations 2
L Clinical Evaluation MDR EU Medical Device Regulations 5
