This may sound as though I am being pedantic, but if I was a lawyer, and the wording of Rule 10 were used in a legal contract, I believe the first clause could have (at least) two possible interpretations.
"Active devices intended for diagnosis and monitoring are classified as class IIa
— if they are intended to supply energy which will be absorbed by the human body ..."
What does this mean for a device where energy absorption is not intended (or necessary for operation)?
I see a distinction between
'they are intended to supply energy-which-will be-absorbed'
'they are intended to supply energy, which (as an unfortunate side-effect) will be absorbed (whether this is intended or not)'
From a physics point of view, let's assume that energy supplied to the body can be either reflected, transmitted or absorbed.
Of course, for something like an x-ray machine, the both absorption and transmission are absolutely necessary for its function, but there can be devices where the amount of absorbed energy is of no concern (for the device).
Hypothetical example:
The patient stands in front of a light source and the shadow cast by the patient on a large sheet of paper is used to make an estimate of their volume (and this info is used for some diagnostic/therapeutic purpose). The functioning of this device only requires that the light supplied by the source is not transmitted through the patient (it can be reflected or absorbed, who cares).
The amount of energy that will be absorbed will no doubt depend on the wavelength of the light, but absorption is not required (or 'intended').
Similarly, there are other examples I can think of where reflected energy is necessary for the device operation, and absorption/transmission is of no concern.
Or at the most ridiculous level, if a device is providing info via an illuminated display of some sort, then it is supplying energy, and a fraction of this energy will be absorbed (by the cells in the retina in order for the information on the display to be perceived!)
Does that automatically make such a device Class IIa?
Any thoughts?
Any thoughts?
