MDR & depth of technical files review by NB's
ralf90
Dear all,
With the MDD there was a (clear) difference in the depth of review NB's did of technical files. A lot less detail for low risk, compared to high risk. E.g. for class Is only the specifics related to sterilisation.
Does someone know if the MDR tells something regarding this?
Regards,
Ralf
Asia78
Hi ralf90,
For class Is, Ir and Im only the specific documents related to those procedures (sterilization, reprocessability...) are requested.
For all TDs of the other classes entire technical documentation has to be submitted.
ralf90
Hi Asia78,
That of class 1 makes sense, also the submission of the full TF. Does that also implicate that they will all be reviewed with the same level of detail? For as far as I know under MDD class IIa TF's were reviewed in less detail compared to high risk files. What do you think?
Asia78
Yes, at the moment we didn't see differences between the IIa and IIb, we send already more than one TD for both classes. The majority of the "more challenging" questions we recived were in the clinical part
Mikilk
Dear all,
Regards,
Ralf
For all classes of medical devices, manufacturers must now provide, as per Annex II, the information in the technical documentation to explain the design stages and procedures that applied to their device (this was significantly changed from MDD that required that design file will be included only in Class III). the main difference between classes is the dept required when dealing with the clinical evaluation report & with the PMS activities (a PMS plan that complies with the obligations of the manufacturers as referred to in Article 84 of the MDR, a Periodic Safety Update Report (PSUR) for devices greater than class I (Article 86 of MDR), or a PMS report for devices of class I (Article 85 of the MDR).
ralf90
I read this that, besides Clinical and PMS, you presume there is no difference in depth of review of the TD between IIa and IIb. True? Or maybe formulated differently, it might be that the real depth of review might depend on which NB reviews documentation.
renenatasha
Dear all,
Regards,
Ralf
Have a look at Annex VII &
MDCG 2019-13 Guidance on sampling of MDR Class IIa / Class IIb and IVDR Class B / Class C devices for the assessment of the technical documentation (December 2019)
ralf90
Think I found the difference in review of product documentation between IIa and IIb in Annex VII $4.5.3. Apparently for IIb a verification is needed, for IIa a confirmation is needed. I read this as for IIb the actual testing documentation will be reviewed, while for IIa the NB-review of a summary of testing is sufficient. What do you think?
  • establish a test plan identifying all relevant and critical parameters which need to be tested by the notified body or under its responsibility in order to:
    • — verify, for class IIb devices, the conformity of the device with the type described in the EU type-examination certificate and with the requirements of this Regulation which apply to those devices,
    • — confirm, for class IIa devices, the conformity with the technical documentation referred to in Annexes II and III and with the requirements of this Regulation which apply to those devices;
renenatasha
I have experience that notified body assessed full technical documentation also for Class Im, Is, Ir , although they should focus only on specific function.
RA_QA Expert, based on your experience, do you mind sharing your thoughts on the followings?
  1. Possible to combine Class I and Class Is in one TF if the MD shares the same intended use?
  2. Should Technical Documentation be separated by Classification and/or Intended Use?
A Can anyone share a Distribution Agreement template under MDR 2017/745? EU Medical Device Regulations 0
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
N OBL under the MDR. Which are the obligations of the OEM? EU Medical Device Regulations 0
U Distributor obligations under MDR EU Medical Device Regulations 1
Raisin picker CECP, consultation according to Art 54 MDR EU Medical Device Regulations 1
K Question on MDR classification EU Medical Device Regulations 4
M STED vs MDR EU Medical Device Regulations 0
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
M Extension to shelf life of new product under MDR EU Medical Device Regulations 1
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
K Importer in EU, but not distribute in the EU - MDR obligations EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
M Responsibilities of Importers / Distributors - MDR EU Medical Device Regulations 3
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 2
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
JoCam MDR Gap Analysis - Consultant fees EU Medical Device Regulations 10
M Examples of Combination Products - MDR Article 1 (8) and MDR Article 1(9) Medical Device and FDA Regulations and Standards News 3
P EU MDR Translation of Product Name EU Medical Device Regulations 0
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
K Quality Agreement MDR - The manufacturer is outside of EU Other Medical Device Related Standards 4
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 5
M MDR harmonized standards EU Medical Device Regulations 3
cscalise RAPS/Med Dev EU MDR Guidebook - Reviews or Opinions? EU Medical Device Regulations 0
V New Product Model CE Mark Certification under MDR EU Medical Device Regulations 0
E MDR PRRC "jointly responsible" EU Medical Device Regulations 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
S EU MDR Annex I Chapter III 23.4 z EU Medical Device Regulations 2
U EU-MDR: Complicated supply chain EU Medical Device Regulations 4
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
A IVD in MDR procedure pack EU Medical Device Regulations 2
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
S Are EC type examinations still being conducted under MDR? EU Medical Device Regulations 5
U MDD Article 12/ MDr Article 22 interpretation EU Medical Device Regulations 2
E MDR internal audit Internal Auditing 1
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
R MDR, Annex I, 23.1 Interpretation - IFU on the website EU Medical Device Regulations 5
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
S EU MDR CAPA - GAP Assessment on CAPA SOPs EU Medical Device Regulations 1
M MDR Article 22 Interpretation EU Medical Device Regulations 3
A User interface Language Requirements - EU MDR EU Medical Device Regulations 1
L EU MDR Article 86 PSUR EU Medical Device Regulations 1
S How is the service life for class I reusable medical devices described in MDR? EU Medical Device Regulations 7
S How is the service life described for class I reusable medical devices in MDR? Elsmar Xenforo Forum Software Instructions and Help 1
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
S Classification of a product according to MDR EU Medical Device Regulations 3
L Classification under MDR EU Medical Device Regulations 1
