MDR equvalent device - can you use a medicine as an equivalent 'device'
Ben S UK
Wondered whether anyone had thoughts on if it is possible to use a medicine (or other non-medical device) as an equivalent product in terms of CEAR and clinical data under the MDR
Given that Rule 21 allows for substance based devices - some of which are currently regulated as medicines, despite having physical/mechanical modes of action - is it possible for a manufacturer that has access to the data (of a medicine) to use it as an equivalent product - assuming of course the equivalent principles can be met?
I've checked MDR text and section 3 of Annex XIV sets out the criteria for equivalent 'devices': scientific, biological, clinical; the MDCG guidance document on equivalence has a handy template for assessing equivalence. Neither or these seem to explicitly prohibit the use of a medicine as an equivlent product (from my reading) but they do consistently talk about equivalent devices.
It may be a question for the Notified Body but interested if anyone has any thoughts on this.
ben
Ben S UK
I see the reference to devices throughout, but wondered whether this would be taken to prohibit non devices, assuming the criteria for equivalence are met (and the reference product also has a physical mode of action).
It may be a reasonably uncommon occurance generally speaking for devices, and hence why the MDR and guidance talks about device:device equivalence. But in relation to R21 there are number of current medicines which could be positioned as devices under MDR. Curious if data that exists for these products (obtained during medicinal development, and post marketing activities) could be used to support them or similar product as devices.
The CAs and NBs may have a different view, but personally i'd suggest that an equivalent product is an equivalent product (if all the relevant criteria are met), and the current classification is not relevant to the spirit of the regulation i.e. do you have data on a product that is substantially similar and can it be used to give confidence in the safety and performance of the new product.
dgrainger
I would say that a medicine will, by definition, never be equivalent to a device as its mode of action is pharmacologic...
Rule 21 is a classification rule and not a qualification rule.
LukasLosigkeit
In order to claim equivalence under the MDR, you need to compare the following characteristics:
-technical
-clinical
-biological
The devices are not equivalent, because the materials that come into contact with the human body or fluids are not the same in a medical device and in a medicinal product.
How to claim equivalence was already established under MEDDEV 2.7-1 rev. 4 referring to the MDD.
The MDR is more rigorous when it comes to equivalence.
Ben S UK
Thanks both for the response.
Agree that typically medicines and devices have different MoA and are not equivalent.
I'm thinking of quite rare circumstances, whereby the medicine has a physical MoA and does not act PIM, but for historic reasons is a medicine and not a device. (Many markets have been relucatant to allow ingestible devices, especially many decades ago, and registered these products as medicines).
For example there are fibre based products for the treatment of constipation which are medicines in some EU markets - these typically act physically as a bulk forming agents with no PIM MoA. These could conceivably be registered as devices especially with a more prescriptive MDR in terms of ingestible substance based devices. In this instance using data already available from a medicine fibre-based product to demonstrate the clinical and safety performance seems rationale providing the equivalence criteria can be met.
LukasLosigkeit
Technical aspects:
The device is of similar design; is used under similar conditions of use; has similar specifications and properties including physicochemical properties such as intensity of energy, tensile strength, viscosity, surface characteristics, wavelength and software algorithms; uses similar deployment methods, where relevant; has similar principles of operation and critical performance requirements.
Equivalence is possible for technical aspects
Biological aspects:
The device uses the same materials or substances in contact with the same human tissues or body fluids for a similar kind and duration of contact and
similar release characteristics of substances, including degradation products and leachables
The materials really need to be identical in order to be equivalent. The MDR is pretty strict in this part.
Where a manufacturer intends to claim equivalence to a device not manufactured by him, the MDR requires that the two manufacturers
have a contract in place that explicitly allows the manufacturer of the second device full access to the technical documentation on an ongoing basis.
Clinical aspects:
The device is used for the same clinical condition or purpose, including similar severity and stage of disease, at the same site in the body, in a similar population, including as regards age, anatomy and physiology; has the same kind of user; has similar relevant critical performance in view of the
expected clinical effect for a specific intended purpose.
Equivalence is possible for clinical aspects
I think the biological part will be the hardest.
And, of course, having access to the technical documentation.
Both makes it quite hard to claim equivalence under the MDR.
Raisin picker
Where a manufacturer intends to claim equivalence to a device not manufactured by him, the MDR requires that the two manufacturers have a contract in place that explicitly allows the manufacturer of the second device full access to the technical documentation on an ongoing basis.
That is actually only true for implantable devices and class III devices, where the manufacturer wants to introduce a new device on the market without a clinical trial (MDR Art. 61.5). Annex XIV (3) on equivalence only states
It shall be clearly demonstrated that manufacturers have sufficient levels of access to the data relating to devices with which they are claiming equivalence in order to justify their claims of equivalence. This can (to my knowledge) be based on e.g., own lab analysis of the equivalent device.
LukasLosigkeit
Yes, you are right. The contract is only needed for class III. Thanks for clarification!
P Update on NBOG 2014-3 to address MDR/IVDR, or any plan to do that? EU Medical Device Regulations 0
A MDR requirement where unit of use packaging is too small for UDI carrier EU Medical Device Regulations 1
S MDR GSPR Standards EU Medical Device Regulations 1
A MDR - Legacy Device Review Timeframe and Requirements EU Medical Device Regulations 3
J Translation requirements for the statement referred to in ANNEX XIII of MDR EU Medical Device Regulations 0
J EU MDR GSPR 10.4.3 and 10.4.4 EU Medical Device Regulations 2
F Labelling to comply with both FDA and MDR US Food and Drug Administration (FDA) 6
N EU MDR and its impact on existing Registrations EU Medical Device Regulations 1
M Post Market Safety Update Report for devices that will be up-classified under MDR but are currently under MDD EU Medical Device Regulations 3
Y MDR Transition - make "Available on the market" after CE certificate expiration EU Medical Device Regulations 2
C MDR Classification Rule 10 EU Medical Device Regulations 13
C MDR software classification EU Medical Device Regulations 12
Y MDR requirements for Class I accessories EU Medical Device Regulations 2
M MDR legal actions - manufacturers CE Marking (Conformité Européene) / CB Scheme 8
R Products not within the MDR grace period EU Medical Device Regulations 1
shimonv MDR transition checklist EU Medical Device Regulations 0
K Re-packaging under MDR EU Medical Device Regulations 3
Ed Panek Upcoming NB MDD ---> MDR Crunch EU Medical Device Regulations 0
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
C Requirements for distributors under MDR: translation EU Medical Device Regulations 0
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
N Looking for a recommendation for an EU MDR Importer EU Medical Device Regulations 1
JoCam Rental and MDD versus MDR EU Medical Device Regulations 1
A Can anyone share a Distribution Agreement template under MDR 2017/745? EU Medical Device Regulations 0
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
N OBL under the MDR. Which are the obligations of the OEM? EU Medical Device Regulations 0
U Distributor obligations under MDR EU Medical Device Regulations 5
Raisin picker CECP, consultation according to Art 54 MDR EU Medical Device Regulations 1
K Question on MDR classification EU Medical Device Regulations 4
M STED vs MDR EU Medical Device Regulations 0
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
M Extension to shelf life of new product under MDR EU Medical Device Regulations 1
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
K Importer in EU, but not distribute in the EU - MDR obligations EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
M Responsibilities of Importers / Distributors - MDR EU Medical Device Regulations 6
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 2
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
JoCam MDR Gap Analysis - Consultant fees EU Medical Device Regulations 10
M Examples of Combination Products - MDR Article 1 (8) and MDR Article 1(9) Medical Device and FDA Regulations and Standards News 3
P EU MDR Translation of Product Name EU Medical Device Regulations 3
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
K Quality Agreement MDR - The manufacturer is outside of EU Other Medical Device Related Standards 4
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 6
M MDR harmonized standards EU Medical Device Regulations 3
cscalise RAPS/Med Dev EU MDR Guidebook - Reviews or Opinions? EU Medical Device Regulations 4
V New Product Model CE Mark Certification under MDR EU Medical Device Regulations 0
