I'm a little bit confused as to whether, under MDR, a post-market clinical follow-up (PMCF) is mandatory, and if not what kind of circumstances justify non-applicability?
The reason for the confusion, is that, on the one hand, the MDR states:
Which seems to indicate PMCF is a requirement, without exception.
...but on the other hand, there is also the following:
Which seems to imply that there are circumstances where no PMCF can be justified.
Can anyone kindly clarify?
Thanks,
MM.
Article 10 General obligations of manufacturers
(3) Manufacturers shall conduct a clinical evaluation in accordance with the requirements set out in Article 61 and Annex XIV, including a PMCF.
Article 86 Periodic safety update report
(1)... Throughout the lifetime of the device concerned, that PSUR shall set out: ...(b) the main findings of the PMCF;
Annex III 1.1(b)
The post-market surveillance plan shall cover at least: ... a PMCF plan as referred to in Part B of Annex XIV, or a justification as to why a PMCF is not applicable.
Thanks,
MM.
