Meaningful MSA Study on Viscosity Measuring Equipment
Boro Col
#12
Thanks - your response makes sense. It is the shear viscosity we are measuring. We will try your method and post how we get on.
Many thanks again.
Ninja
Looking for Reality
#13
Many thanks again.
Hi Boro Col,
By "shear viscosity" I assume you mean the viscosity under a specific shear rate after the thixotropy has 'stabilized out'.
If so, leave a sample (spindle already in) sit stagnant for ~30min. Then put it under shear and take readings every ~30sec and plot the curve of Visc vs. Time. It should plateau. Run your GRR out on the time plateau and see if that doesn't work out for you.
Note: A programmable cone & plate viscometer can remove the operator influence to a large degree and can make the test far more repeatable in a manufacturing setting (lowering the Appraiser Variation part).
Best of luck...keep us posted!
E
eturkan
#14
What is your outcome?
It is hard to get a good % Gage R&R. Your samples MUST represent the entire tolerance interval. If there is no variance within the parts, your Gage R%R suffers.
If I were you, I'd get 15 samples and choose 10 of the data that represents the overall tolerance interval.
If cpk>2.5 , you may also consider using tolerance % result
Are you working on tan_delta/ loss/storage modulus? You can also obtain help from your equipment's manufacture (such as TA etc)
LUV-d-4UM
#15
I gather you are an expert on this field. Can you explain this a little better for the benefit of us folks who are new in the Nested ANOVA? Do you have the right form and constants to use? Thanks
K Are Professional Certifications meaningful? What of Recertification Requirements? Professional Certifications and Degrees 15
K Definition Meaningful and Unfamiliar Measurement Units Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
T The best way to pull some meaningful stats from a really big project? Using Minitab Software 3
K What is Meaningful Difference in Minitab Using Minitab Software 5
Z Isn't 'Improvement Always' a meaningful work? Misc. Quality Assurance and Business Systems Related Topics 3
A Ppk Reporting - Ideas to make it more meaningful for Management Statistical Analysis Tools, Techniques and SPC 3
Sidney Vianna An example of a meaningful preventive action for aero suppliers who use titanium AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Can you suggest meaningful KPI's for our Design and Development process? Design and Development of Products and Processes 5
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
