Measurement BIAS Study - No Measurement Variation Unacceptable?
CarlDaniel
I just did a bias study on one of our chip scale package automated vision system. I used an excel template with formula based from MSA manual for bias independent sampling method. I took 15 readings and all were exactly the same with no rounding off. But when I input the readings, it turned out the lower & upper values of the 95% confidence interval of the bias are the same value which would result in a failed bias study.
Please help me understand what happened because based on the condition given for bias study, the bias should be unacceptable eventhough the average of the readings are close to the reference value. I checked the formula and I didn't see any discrepancy, or maybe I missed something.
Jerry Eldred
Re: BIAS study - No measurement variation still unacceptable?
I'm sure one of the MSA / GR&R experts will give the correct answer, but my less-than-expert guess would be your resolution. I seem to recall from my old QS9000 days, a P/T ratio requirement (precision / tolerance ratio) of at least 10:1. Perhaps you need enough resolution to actually show variation.
No, resolution is not the issue here. The gage has a resolution of .001 compared to a tolerance range of .16.
The formula for the Bias study compares the measured bias against the measurement variation. If the measured bias falls within the distribution of measurement error, the gage cannot really see the bias, so it is considered acceptable.
If the measured bias falls outside the distribution of measurement error, the gage can see the bias, so it is considered unacceptable.
In this case, the gage displayed zero measurement variation, so it saw the bias of -.003. If you went to a gage with a resolution of .0001, you may see measurement variation, but the spread would undoubtedly be so tight that the .003 bias would still be outside the measurement error.
Your decision on how to react should consider three things:
1) Is a bias of -.003 outside your acceptance limits for calibration?
If your answer to 1) is NO, do nothing. If the answer is YES, recalibrate the gage and perform a risk assessment as follows:
2) Will a bias of -.003 cause you to ship nonconforming product?
3) Will a bias of -.003 cause you problems with process control?
If your answer to 2) and/or 3) is NO, document the decision process and move forward. If it is YES, follow your procedures for shipment of suspect product.
CarlDaniel
Thanks a lot Miner...the manual just didn't explain this thought process you presented.
The -0.003 variation is a negligible amount and won't affect our product.
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Company-wide MSA - Measurement Equipment Bias, Linearity & Stability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R EMP (Evaluating the Measurement Process) Studies for Bias Effect Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 2: Bias Imported Legacy Blogs 4
S Stability, Bias and Linearity samples - Measurement Systems Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Measurement System Analysis (MSA) - Bias, Linearity and Stability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
Ron Rompen Measurement of residual magnetism General Measurement Device and Calibration Topics 2
M Surgical angle measurement guide device with an application software Medical Device and FDA Regulations and Standards News 1
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Most versatile measurement device General Measurement Device and Calibration Topics 2
P Surface scratch measurement General Measurement Device and Calibration Topics 1
P Thermo-Hygrometer - Measurement of 10DegC @10%RH ISO 17025 related Discussions 4
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
T How to “validate/qualify” a new measurement equipment? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Bev D Verification and Validation of Measurement Systems Misc. Quality Assurance and Business Systems Related Topics 0
F How do you add accuracies for tools with different measurement devices? General Measurement Device and Calibration Topics 1
M Viable count Measurement ISO Standard Other Medical Device Related Standards 1
W Air Quality Measurement Hardware and Software General Measurement Device and Calibration Topics 11
O Dimension Measurement Tool Recommendation General Measurement Device and Calibration Topics 21
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
R Measurement Uncertainties Budget for Thermometer Measurement Uncertainty (MU) 6
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
G What information to put on measurement Dimensional Results APQP and PPAP 7
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
F Electrical Metrology (Source/Generation and Measurement) General Measurement Device and Calibration Topics 1
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
Fernando Drumond Calibration and Control of Plastic Volumetric Measurement Instruments General Measurement Device and Calibration Topics 1
