Measurement Force on Kickdown
K
KnoKsuKaO
Hello all,
please we will produce parts to automotive industry (these parts are saying as KICKDOWN). I would like to make MSA analysis on press, but how to do it?
Because:
1) measurement is done strain gauge and the human factor there isn't ;
2) strength on part is decreases each time you press;
The requirement for Force is (130 +/- 10)N.
Thank you very much for help.
This is a bit more complicated than a typical functional or non-destruct test, but is doable. (I am on my ipad right now and can't attached or point to some documents that will help you, but I will be back to do that; this will keep the post visible for awhile)
First I would recommend only TWO repeated readings of each part.
Secondly, I do recommend a sample size of at least 15 parts, 30 is better.
Then there is a method to deconstruct the systemic change in readings from the first to the second and the measurement error. It is a bit too complicated to type out on an iPad, so I'll do that later as well.
it will be helpful to post your data once you've completed the repeat testing. Then we can demonstrate exactly how to do it with your data...
R Compression Spring Force measurement correlation with Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 7
Y Measurement of Force (Newtons) generated General Measurement Device and Calibration Topics 9
sonflowerinwales Clamping Force measurement between two component faces? General Measurement Device and Calibration Topics 5
J Laser length measurement system General Measurement Device and Calibration Topics 3
K Alternatives to Metal Foil for touch current measurement of enclosures made of insulating material. IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M What should be measurement method in control plan if you are defining Control method as work instruction. Manufacturing and Related Processes 5
K ISO9001 - Measurement Equipment records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
adztesla Specification (Significant digits) - Measurement (Medical device) ISO 13485:2016 - Medical Device Quality Management Systems 3
S How to report a measurement and relate it to calibration certificate General Measurement Device and Calibration Topics 1
B IATF 7.1.5.1.1 Measurement system analysis (Visual Inspection) IATF 16949 - Automotive Quality Systems Standard 3
B Leakage current measurement without isolating transformer IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V Over 60 dimensions CMM measurement in control plan APQP and PPAP 8
C MSA for resistance measurement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F Multi-Sensor CMM Measurement General Measurement Device and Calibration Topics 5
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
CaliperJim Temperature and Humidity Effects on Measurement Devices General Measurement Device and Calibration Topics 6
E Audit Finding - Measurement of Process - Continuous Improvement - Trend Analysis Oil and Gas Industry Standards and Regulations 22
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
R DIGITAL MEASUREMENT DEVICE Manufacturing and Related Processes 2
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
J Not able to repeat measurement at the same location General Measurement Device and Calibration Topics 7
Ron Rompen Convert Linear Measurement to Angular Measurement General Measurement Device and Calibration Topics 3
Q Resolution of Measurement Device for a 50' Coil Reliability Analysis - Predictions, Testing and Standards 1
Ron Rompen Assistance with perpendicularity measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
G QSB+ : capability of measurement equipment IATF 16949 - Automotive Quality Systems Standard 15
B Measurement Calculations vs ASME Y14.5 Various Other Specifications, Standards, and related Requirements 2
S Measurement of threaded holes ISO10578 or ASME standard Measurement Uncertainty (MU) 3
S Comparing measurement results for a part from two ring gage General Measurement Device and Calibration Topics 3
B Building my own measurement equipment General Measurement Device and Calibration Topics 3
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Keyence Measurement Systems General Measurement Device and Calibration Topics 3
Q Measurement Equipment Revocation - Looking for a Disposal Form with Risk Assessment IATF 16949 - Automotive Quality Systems Standard 10
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
E Any template/ form of Monitoring and Measurement of Processes and product to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
A Flexible "Ring" Roundness Measurement General Measurement Device and Calibration Topics 2
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F Physical Part Measurement General Measurement Device and Calibration Topics 6
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
Ron Rompen Measurement of residual magnetism General Measurement Device and Calibration Topics 2
M Surgical angle measurement guide device with an application software Medical Device and FDA Regulations and Standards News 4
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Most versatile measurement device General Measurement Device and Calibration Topics 2
P Surface scratch measurement General Measurement Device and Calibration Topics 1
P Thermo-Hygrometer - Measurement of 10DegC @10%RH ISO 17025 related Discussions 4
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
