Measurement Method Challenge - Measure feature #91
Ron Rompen
I have an exceptionally difficult measurement task, and am hoping that someone here will have some suggestions as to how to solve my problem.
On the print extract shown below, I need to measure feature #91. As you can see, this is not as easy as it first looks.
My current method is to measure with a contour tracer, however that requires the operator to leave the production area, come to the lab, wait to have the part measured, return to production, make adjustments (if required) and repeat to validate....all in all, not a very suitable method.
I am looking for something that would (relatively) simple for an operator to use on the floor. I have contacted several gauge makers that I have dealt with in the past, and none of them have any useful ideas. 1554832326995.png
Any suggestions?
GRP
In my days as quality engineer in the plastic injection industry I always fancied having a Renishaw Equator. It is sort of a CMM for the shop floor. It would have made my life easier. Do understand that if you go and buy one I'll receive doodly-squat. :topic:
Here is a possibility, if I interpreted the drawing correctly: make a fixture to pass through the center hole, seat the part horizontally and measure on top with an indicator. To seat the part have some sort of pins machined to follow the radius.
Ron Rompen
GRP: Thanks for your response, We have several CMM's with a variety of measuring heads, but the feature is too small to accurately measure in this method. YOur other suggestion (to seat the part on the blend radius and measure 'down' from the top has somewhat the same issue. The blend radius varies in size, and this change has a direct impact on the Feature 91 measurement.
Thank you for your input though, I do appreciate you taking the time to respond.
John Predmore
In addition to the shop floor CMM that @GRP mentioned, I know there have been a lot of advances in non-contact measurement instruments. I was always suspicious of the precision and repeatability of optical devices, in which accurate measurements in the Z dimension is a function of focus and lighting, there are now affordable, very precise instruments which use laser light. If you can see a surface inside a hole, you can measure it. I am no expert, but you may wish to explore these as a solution.
Ron Rompen
Thanks for your response John. I too am suspicious of optical devices for this type of measurement, however I have started exploring the potential of using a laser to measure the location of the feature.
The blend radius between feature 66 and 75 is what makes it so difficult - there is no clearly defined transition zone.
G
Genaro Luevano
my suggestion as this is a difficult to measure use a go no go gauge for the area using the max indicator, because measurement every time will be quite complicated
GRP
Are you suggesting a go / no-go gauge will be apt to control a feature which cannot be accurately measured with CMM?
Ron Rompen
GO/NOGO gauging for this feature is (virtually) impossible, due to the feature configuration. In addition, the dimension is critical enough to part function in the assembly that (although it is not designated as an SC/CC) I want to be able to monitor it for process shifting.
Ninja
Looking for Reality
If a laser profilometer wont work for you (I'm thinking along the lines of the old OGP Flare laser add-on)...does it make sense to make your own go-nogo fitting the internal hole and slope? Then measure protrusion from the other flat side?
If what you are looking for is process shift, this should catch it. Not a direct measurement per se...but should give you data you don't currently have...
Just thinking out loud...
G
Genaro Luevano
another method will be with a height gage from the
thats what i talk about do the go-no go use as a base and then measure, take the practical aporach
M What should be measurement method in control plan if you are defining Control method as work instruction. Manufacturing and Related Processes 5
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Ron Rompen Dual level holes - Measurement method suggestions wanted General Measurement Device and Calibration Topics 9
T Method to assess Measurement System of a Continuous Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C O-Ring Groove Measurement Method in CNC Machined Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Flatness Measurement Errors from a Datum - Test Method General Measurement Device and Calibration Topics 3
T Method Repeatability for MU (Measurement Uncertainty) Measurement Uncertainty (MU) 1
A Calibration Method and Measurement Uncertainty General Measurement Device and Calibration Topics 5
C Accurate Measurement Method for Flash and Mismatch @0.002" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
T Thread Wire Measurement - 3 Wire Method for BSPP Threads General Measurement Device and Calibration Topics 1
R Total Tolerance Method vs. Total Variation Method - Measurement System Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T How to define the measurement technique and control method for manual soldering FMEA and Control Plans 10
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
A Gauging method comparison - Air Gage vs. CMM Measurement General Measurement Device and Calibration Topics 9
V Can anyone advise a method to research 'Measurement System' for testing a tire? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Monitoring and Measurement of Finished Goods with a Better Method IATF 16949 - Automotive Quality Systems Standard 2
B Sharp Edge Measurement - Method of measuring how sharp the edge of a machined part is Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Test Method Qualification - Measurement Capability - What else is involved? Reliability Analysis - Predictions, Testing and Standards 1
A The meaning of "Evaluation/Measurement Technique" & "Control Method" in Control Plan FMEA and Control Plans 19
P Symmetry Measurement - Method of evaluation General Measurement Device and Calibration Topics 21
Ron Rompen GD&T Advice Requested - Measurement method for a part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Y Attribute Measurement Systems Study---Risk Analysis Methods & Analytic Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C I need a measurement method QS-9000 - American Automotive Manufacturers Standard 6
J Balanced Score Card - Using this method for performance measurement Quality Tools, Improvement and Analysis 2
K Alternatives to Metal Foil for touch current measurement of enclosures made of insulating material. IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K ISO9001 - Measurement Equipment records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Specification (Significant digits) - Measurement (Medical device) ISO 13485:2016 - Medical Device Quality Management Systems 3
S How to report a measurement and relate it to calibration certificate General Measurement Device and Calibration Topics 1
B IATF 7.1.5.1.1 Measurement system analysis (Visual Inspection) IATF 16949 - Automotive Quality Systems Standard 3
B Leakage current measurement without isolating transformer IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V Over 60 dimensions CMM measurement in control plan APQP and PPAP 7
C MSA for resistance measurement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F Multi-Sensor CMM Measurement General Measurement Device and Calibration Topics 5
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
CaliperJim Temperature and Humidity Effects on Measurement Devices General Measurement Device and Calibration Topics 6
E Audit Finding - Measurement of Process - Continuous Improvement - Trend Analysis Oil and Gas Industry Standards and Regulations 22
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
R DIGITAL MEASUREMENT DEVICE Manufacturing and Related Processes 2
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
J Not able to repeat measurement at the same location General Measurement Device and Calibration Topics 7
Ron Rompen Convert Linear Measurement to Angular Measurement General Measurement Device and Calibration Topics 3
Q Resolution of Measurement Device for a 50' Coil Reliability Analysis - Predictions, Testing and Standards 1
Ron Rompen Assistance with perpendicularity measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
G QSB+ : capability of measurement equipment IATF 16949 - Automotive Quality Systems Standard 15
B Measurement Calculations vs ASME Y14.5 Various Other Specifications, Standards, and related Requirements 2
S Measurement of threaded holes ISO10578 or ASME standard Measurement Uncertainty (MU) 3
S Comparing measurement results for a part from two ring gage General Measurement Device and Calibration Topics 3
B Building my own measurement equipment General Measurement Device and Calibration Topics 3
J Keyence Measurement Systems General Measurement Device and Calibration Topics 3
Q Measurement Equipment Revocation - Looking for a Disposal Form with Risk Assessment IATF 16949 - Automotive Quality Systems Standard 10
