Measurement System Analysis (MSA) - Bias, Linearity and Stability
G
Gator68
#11
Sorry, I don't have an excel template. These are hard numbers to nail down, as people will measure them different ways. For Linearity you typically do a linear fit on the data, then calculate the max deviation from the fit. Finally, you divide by the full scale to get a percent full scale. Bias is usually pretty simple. Take data for some time (say 100 - 1000 samples). Calculate the average value, that's the bias. Stability is very tricky. In the sensor world, one of the standard ways to measure stability is using an Allan variance calculation. See attached for a short description.
Edit -- after looking around the forums a bit, it looks like you're probably talking about measurment errors? Look through some of the related topics, I think this has been covered before. :eek:
sitapaty
#12
Can some one show excel work sheets to derive BIAS,LINEARITY & Stability please.
Thank you in advance
-Sitapaty
Tseng
#14
Dear All
May I ask a quite low question regarding linearity example in MSA-4?
The example of Chapter III, section B, p.91 stated ta=-12.043, and tb=10.158....can anyone explain how they were calculated/produced?
Thanks a lot!
L
Lala77
#15
hi all..
i've been silently reading all the information in the forum, and still can not get any suitable solution for the problem im facing.
My situation is :
1) Currently we have only 1 inspector to measure the critical part from our product that we decided to do the MSA..from what i know, is it possible to use GR&R for my case since it does not involve more than 1 inspector henc the reproducibility cant be obtained right?
2) But, i tried to add 2 more inspectors just for the GR&R, still its failing.Im guessing that this is because the tool used for measuring is measurement tape and the tolerance is +- 1mm, the readings we get is still between the tolerance and is acceptable, so now im not really sure what should i do get a pass for GR&R.
it would be more helpful if someone from here can enlighten me :(.
Discussed already with the consultant, but he seems to be more blank than me.:frust:
debyang
#16
Bad GRR result could be possible due to the other two inspectors are not so well trained as the only one who is in charge of the measurement. If you post the GRR results for us to review to understand what might be going wrong.
But I would suggest you do stability study with the only one inspector first to see if the MS is stable and the EV(within system variation) is small enough compaired with the spec tolerance.
harry
#17
................ 2) But, i tried to add 2 more inspectors just for the GR&R, still its failing.Im guessing that this is because the tool used for measuring is measurement tape and the tolerance is +- 1mm, the readings we get is still between the tolerance and is acceptable, so now im not really sure what should i do get a pass for GR&R. .............
I think you've got it. The best estimate for a measuring tape graduated in millimeters is half a millimeter. For +/- 1mm, you need a gage capable of reading 0.1mm.
Helmut Jilling
Auditor / Consultant
#18
hi all..
My situation is :
Why are you using a measuring tape for a close tolerance of +/- 1mm? The variance on the tip alone can exceed that. A more stable steel rule or square might be more effective?
#19
I agree with Harry. Also, you mentioned that only one operator performed this measurement. Is this always the case? In special situations where there is only one operator for a measurement such as with a specialized lab test, you can perform a Gage R study instead of the typical Gage R&R study. The Gage R study evaluates the Repeatability of a single operator.
L
Lala77
#20
Thanks debyang, here i've attached the result, i hope anyone could suggest something for me to pass the GRR.:confused:
E Measurement System Analysis/validation to new factory Manufacturing and Related Processes 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
K Measurement system analysis "shall be conducted to analyze the variation..." Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
E Measurement System Analysis (With parts that have variation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M How to Stack for MSA (Measurement System Analysis) in Minitab? Using Minitab Software 1
V Is MSA (Measurement System Analysis) required for Weighing Scale? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Linearity Problem (MSA - Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Weighing Scale MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D Which Measurement System Analysis should I use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Total Tolerance Method vs. Total Variation Method - Measurement System Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
S MSA (Measurement System Analysis) for Medical Device Manufacturers Other US Medical Device Regulations 3
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MSA (Measurement System Analysis) on Multi-Phase Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A Width and location errors in MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Measurement System Analysis (MSA) Procedure template Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R Imported Legacy Blogs 14
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5a: R&R Imported Legacy Blogs 5
