Measurement System Analysis (With parts that have variation)
E
ejmoska
I have what i believe a rather uncommon case, where i need to perform Measurement System Analysis on testing bench which is used for testing other measurement devices (Water meters)
In this case i have:
Equipment: Testing bench (Water flow bench, with high accuracy water meter for master sample)
Parts: water flow measurement devices (1-10 parts on bench)
Operator: operators are commonly known to have influence to measurement results (No previous MSA was performed)
By using parts from production it is to my opinion impossible to differentiate variation between test bench and produced water meters. (because it is commonly known that both have variation)
Should we use some high-accuracy meter to replace parts from production or is there any other way to perform MSA correctly?
Thanks for any advice and please note i am new to measurement system analysis.
welcome to the cove! :bigwave:
You are performing a functional MSA. This is different from a 'static' MSA where the parts themselves do not change (at least in the short run) as with most dimensions and geometrical features. Functional MSAs are used when the event or measurement is a function and therefore the characteristic of interest changes from trial to trial.
You will probably find this document on how to perform a Functional MSA helpful...
B IATF 7.1.5.1.1 Measurement system analysis (Visual Inspection) IATF 16949 - Automotive Quality Systems Standard 3
E Measurement System Analysis/validation to new factory Manufacturing and Related Processes 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
K Measurement system analysis "shall be conducted to analyze the variation..." Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M How to Stack for MSA (Measurement System Analysis) in Minitab? Using Minitab Software 1
V Is MSA (Measurement System Analysis) required for Weighing Scale? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Linearity Problem (MSA - Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Weighing Scale MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
D Which Measurement System Analysis should I use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Total Tolerance Method vs. Total Variation Method - Measurement System Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
S MSA (Measurement System Analysis) for Medical Device Manufacturers Other US Medical Device Regulations 3
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MSA (Measurement System Analysis) on Multi-Phase Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A Width and location errors in MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Measurement System Analysis (MSA) Procedure template Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R Imported Legacy Blogs 14
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5a: R&R Imported Legacy Blogs 11
