Measurement System Artificially Creates a Skewed Distribution
clarked3
Hi All,
I have a question...
I received in a new component for the 1st time and "Goods In" did their inspection. On a batch of 3500, 75 samples were inspected. A dimension was not out of spec but failed to meet the inspection criteria according to ASQ/ANSI Z1.9 2003. Spec is 0.65-0.75 mm, values were recorded at 0.66-0.75. The reason for the failure was because the distribution was positively skewed and when I ran all the stats it turned out 1.9% of the batch could be above the upper spec limit, and therefore failed.
The thing is the supplier performed his inspection on a smaller sampler number (n=15) but his results were all within 0.68-0.70.
I haven't got their individual values and I imagine our inspection isn't up to scratch but my main question is as follows:
Can a poor measurement system introduce a skewness to the distribution?
I'm getting the supplier to measure a representative n=75 sample and I'm expecting it to be normal distribution as the validation up to now has shown it to be a normally distributed process.
So can this happen and is there anything glaringly obvious which could be the cause?
The inspection is on a tube wall thickness with a digital caliper. I agree it is not the most accurate technique, caliper flats and a curved surface but the supplier uses the same.
Dan
I have not seen a measurement device that yields skewed data, but measurement methods often do so. For example many GDT methods that take the absolute value or use polar coordinates result in skewed distributions.
In your case, I would look toward anomalies with the part itself such as burrs or similar anomaly in the measured area. Is this tubing DOM (drawn over mandrel) or is it rolled and welded? If the latter, wall thickness at the weld may differ from the rest of the part skewing the data.
teh other thing to consider is that the distribution of parts within the lot may simply be skewed. the measurement system is fine but he parts are skewed.
the smaller sample doen by your supplier mightsimply not picked up those 'rarer' parts in the tail...Have you perfomed a methdo comparison MSA bewteen your self and your supplier?
when you say you ran the statistics were you using the Normal distribution or a different distributional model?
If you tell us what hte characteristic is and how you are measuring (and maybe even how it is produced - e.g. turned, millled, drilled, formed, etc.) tha twill help us provide better advice.
also posting your data and your supplier's results are helpful...
clarked3
Hi All,
Its a polypropylene extrusion moulded tube.
AS for the stats...Because ASQ/ANSI Z1.9 is only applicable for normal distributions I first checked that the data was normal. It wasn't.
I checked the skewness and kurtosis, 0.48 and -0.60, respectively.
I ran a goodness of fit test. 3-Parameter Weibull was the only distribution >0.010, (Shape 1.90035, Scale 0.04518, Thresh 0.65697)
I then did a probability plot and worked out the largest wall thickness I could expect would be 0.80 mm
Measuring with digital calipers. Taking an average of 3 points.
Several possibilities that come to mind are:
  • Variation in the alignment of the caliper anvils with the axis of the tubing
  • Anomolies such as burrs left when the tube is cut
  • Variation in thickness around the circumference of the tube due to the tooling
  • Variation down the length of the tubing due to fluctuations in the extrusion
The first has to due with the measurement method, the second with sample prep and the remainder with part variation.
clarked3
The tubes are only 230mm long so bagged in lots of 1000.
I imagine it is a true representation and the number the supplier measured was not sufficient to show the skewness.
I am planning a 75 gauge R&R across the supplier and us and we'll see what that throws up!
I was just concerned that we had inadvertantly skewed the data and didn't know if that was even possible. By the sounds of it, it doesn't sound that easy or common to do!
Thanks for everyone's input!
Ninja
Looking for Reality
Dan
It should be a very revealing GRR...please share what you can of the results.
Wall thickness of < 1mm,
on a round surface (tube)
with calipers...
I will be quite impressed if it holds GRR < 10 on the spec range of 0.1mm with calipers.
Do you have another measurement method to check out at the same time, like a CMM?
clarked3
No we don't have a CMM available. We queried the use of the digital calipers but the supplier was confident.
I imagine the GRR will highlight some re-training on our end and whether the distribution observed in true.
I'll update when I have more results!
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
H ISO13485:2016 Measurement System - Methods General Measurement Device and Calibration Topics 4
E Measurement System Analysis/validation to new factory Manufacturing and Related Processes 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
T Method to assess Measurement System of a Continuous Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Measurement system analysis "shall be conducted to analyze the variation..." Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
G Where to obtain training to program the Keyence Measurement System IM6120 Training - Internal, External, Online and Distance Learning 3
E Measurement System Analysis (With parts that have variation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
W Gage R&R where Device Under Test (DUT) is part of the Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P Vision Measurement System - Software Program Qualification Qualification and Validation (including 21 CFR Part 11) 6
Y Gage R&R for multiple measurement system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J How do you perform a S3 Stability Study for a Non-Replicable Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Camera Vision Measurement System Gage R and R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
W Anyone using Keyence Image Measurement System Calibration and Metrology Software and Hardware 2
C Measurement System to measure Hole Diameters, True Positions, Surface Profiles, etc General Measurement Device and Calibration Topics 4
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
H Measurement System in Control if the Equipment requires Daily Calibration? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
K Effectiveness of ISMS (Information Security Management System) Controls Measurement IEC 27001 - Information Security Management Systems (ISMS) 3
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C A better Instrument (Measurement Device) Identification System Misc. Quality Assurance and Business Systems Related Topics 7
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
