Measurement System Artificially Creates a Skewed Distribution
clarked3
#12
I agree that a micrometer, ball-anvil or otherwise (i.e. a curved surface on the inside of the tube), would be a more accurate measurement. As RSEGRIGGY points out though it is the method we agreed with the supplier. In fact, they suggested it, we had reservations but they assured us they could perform the measurement accurately.
I have suspicions they may be using a caliper attachment of some sort or their method is slightly different and this has been lost in translation.
They have begun the Gage R&R so hopefully we will find out soon.
Ninja
Looking for Reality
#13
If you already have the customer-directed equipment in house, you might consider doing your own GRR so that you have your own real data.
The customer passing GRR that you didn't see performed by their operators, and you passing GRR at your site with your operators are two different things.
Having your own data allows you to push back in the negotiation with data in hand.
As a best case, perhaps you find out that their method works perfectly well and that your (and our) concerns are unfounded...
TWA - not the airline
#14
The question is why there is such a difference between your results and those of your vendor though you are doing it the same way. Especially when considering that calipers are not perfectly suited for such tasks (as George and RSEGRIGGY correctly pointed out) you'd expect that due to the higher inaccuracy systematic differences would rather be masked than become pronounced. But if the tube get more oval over time then you'd expect a distortion of your results because the actual curvature of the place where you measure the wall thickness would be different. This effect would be much less if you'd use an anvil micrometer...
bobdoering
Stop X-bar/R Madness!!
#15
First: If you are measuring a circular feature, you should always measure the high and the low for each circular slice - since there are an infinite number of diameters, and one diameter measurement is statistically insignificant to represent the diameter. Oval parts may actually be better represented by the average of the high and the low, if it is a flexible material.
Second: The comments about what happens to the material after it leaves the manufacturer is also important considerations
Third: What is the effect of their die, die life, etc. on the dimensions over time? Extrusion dies wear, causing the dimension (ID) to increase. So, long term the variation would not be expected to be normal or centered.
kuyakut
#16
Did your supplier do a shrinkage study. It may fine during the time your supplier measure the parts,but after it was stored and sent to your plant it may shrink and cause dimenion to skewed.
clarked3
#17
[FONT=&quot]So here are the results of the GRR (and a bit of a rant!*Disclaimer*)[/FONT]
[FONT=&quot]Two-Way ANOVA Table With Interaction [/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]Source DF SS MS F P[/FONT]
[FONT=&quot]Part no 74 0.0226890 0.0003066 2.5508 0.000[/FONT]
[FONT=&quot]Operator 3 0.0059907 0.0019969 16.6131 0.000[/FONT]
[FONT=&quot]Part no * Operator 222 0.0266843 0.0001202 1.1980 0.073[/FONT]
[FONT=&quot]Repeatability 300 0.0301000 0.0001003[/FONT]
[FONT=&quot]Total 599 0.0854640[/FONT]
[FONT=&quot]Alpha to remove interaction term = 0.25[/FONT]
[FONT=&quot]Gage R&R [/FONT]
[FONT=&quot] %Contribution[/FONT]
[FONT=&quot]Source VarComp (of VarComp)[/FONT]
[FONT=&quot]Total Gage R&R 0.0001228 84.05[/FONT]
[FONT=&quot] Repeatability 0.0001003 68.68[/FONT]
[FONT=&quot] Reproducibility 0.0000224 15.36[/FONT]
[FONT=&quot] Operator 0.0000125 8.56[/FONT]
[FONT=&quot] Operator*Part no 0.0000099 6.80[/FONT]
[FONT=&quot]Part-To-Part 0.0000233 15.95[/FONT]
[FONT=&quot]Total Variation 0.0001461 100.00[/FONT]
[FONT=&quot] Study Var %Study Var[/FONT]
[FONT=&quot]Source StdDev (SD) (6 * SD) (%SV)[/FONT]
[FONT=&quot]Total Gage R&R 0.0110805 0.0664831 91.68[/FONT]
[FONT=&quot] Repeatability 0.0100167 0.0600999 82.88[/FONT]
[FONT=&quot] Reproducibility 0.0047376 0.0284253 39.20[/FONT]
[FONT=&quot] Operator 0.0035371 0.0212228 29.27[/FONT]
[FONT=&quot] Operator*Part no 0.0031517 0.0189102 26.08[/FONT]
[FONT=&quot]Part-To-Part 0.0048271 0.0289627 39.94[/FONT]
[FONT=&quot]Total Variation 0.0120863 0.0725178 100.00[/FONT]
[FONT=&quot]Number of Distinct Categories = 1[/FONT]
[FONT=&quot]Turns out the reason the Results were different in the 1st place is because the operators didn't measure the parts correctly on my side.:mad: These parts are from a new supplier so they were meant to perform the measurements in the same way as they did the parts from the old supplier. I assumed that they had been trained to do this correctly...how wrong was I! I found this out when I sent them the protocol for the GRR.[/FONT]
[FONT=&quot]So once I'd re-trained them we performed the GRR and the results were equivalent. There was a minor discrepancy, however... [/FONT]
[FONT=&quot]As you can see the caliper method is inadequate. The method is as follows: measure the wall thickness at 4 points 2 in the X plane and 2 in the Y plane, i.e. at 12, 3, 6 & 9 on a clock face. Calculate the average and report that. My operators had only been taking 1 value. I was going to see whether, if they took the measurements in the same tube orientation everytime would the variation decrease.[/FONT]
[FONT=&quot]I started to think up a 2nd quick study to see if I could decrease the gage variation when I notice the tubes have 4 points marked on the tip. Knowing full well what they'd done I asked why they'd marked the tubes. "Well we realised that if we both took the 4 measurements in different places it might increase the variation so we marked them all up and then both measured them at the same point" therefore artificially decreasing the variation in the operator reproducibility... :frust:[/FONT]
[FONT=&quot]Moral of the story: Just because people are highly educated does not mean they have an ounce of sense! Watch them at all times! [/FONT]
[FONT=&quot]The supplier maintains that they don't have any issues with any other customers when they use this technique so we should look at widening the tolerances (I think this is a bit of a joke but nevertheless I won't be signing off on it!)[/FONT]
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
H ISO13485:2016 Measurement System - Methods General Measurement Device and Calibration Topics 4
E Measurement System Analysis/validation to new factory Manufacturing and Related Processes 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
T Method to assess Measurement System of a Continuous Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Measurement system analysis "shall be conducted to analyze the variation..." Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
G Where to obtain training to program the Keyence Measurement System IM6120 Training - Internal, External, Online and Distance Learning 3
E Measurement System Analysis (With parts that have variation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
W Gage R&R where Device Under Test (DUT) is part of the Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P Vision Measurement System - Software Program Qualification Qualification and Validation (including 21 CFR Part 11) 6
Y Gage R&R for multiple measurement system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J How do you perform a S3 Stability Study for a Non-Replicable Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Camera Vision Measurement System Gage R and R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
W Anyone using Keyence Image Measurement System Calibration and Metrology Software and Hardware 2
C Measurement System to measure Hole Diameters, True Positions, Surface Profiles, etc General Measurement Device and Calibration Topics 4
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
H Measurement System in Control if the Equipment requires Daily Calibration? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
K Effectiveness of ISMS (Information Security Management System) Controls Measurement IEC 27001 - Information Security Management Systems (ISMS) 3
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C A better Instrument (Measurement Device) Identification System Misc. Quality Assurance and Business Systems Related Topics 7
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
