Measurement System Capability with a Continuous Measurement System
E
Elwood
I am trying to set up a SPC scheme on several production lines that extrude electrical conductors and the like. We use a laser measurement system that measures the outer diameter in the x and y direction and then takes that average of these two values for the purpose of process control. How do I conduct a measurement system capability study on this device? The ideal way, I think, would be to run a calibrated cable of sorts through our process, collect data, and then analyze that data. Unfortunately, we do not possess such a cable nor do I know where to find one. Is there any other way I can do this? I do not feel comfortable implementing SPC on these processes without knowing to what degree I can trust my measurement system.
Thanks for the help.
Is this an automated test? That is, does the wire run through the measurement device continuously during the measurement, or does an operator collect a sample and present it to the device?
E
Elwood
Yes, it is an automated test. The product being extruded passes through the device and is measured on two planes and then averaged.
P
prototyper
How is the system calibrated?
This may give an indication as to how you could conduct an MSA study!
Because this is an extrusion, the process is probably strongly autocorrelated for some time period. This means that sections in close physical proximity are virtually identical except for measurement error. Take repeated measures over a short period of time for one "part". Wait beond the period of autocorrelation (you will have to determine this statistically), and take more repeated measurements for the next "part". Repeat. There will be no reproducibility.
I worked with a rubber extrusion process and the period of autocorrelation was 20 minutes. You will need to determine this period, because this will force you into an I-MR type of control chart with a sampling frequency longer than the period of autocorrelation to obtain control limits based on more than just measurement variation.
E
Elwood
Thank you. How do I go about statistically determining the autocorrelation period? I imagine that I would have to determine that for each product type and size, correct? We do have the ability to re-run an extruded product through the measurement equipment. Would that provide the reproducibility component?
If you have statistical software such as Minitab, the autocorrelation analysis is straightforward. Just take measurements at small, equal intervals for a period of time that you know will have actual part variation such as a material change. Perform the analysis. Minitab shows a graph by time interval with the autocorrelation coefficient versus limits. Once the coefficient falls inside the limits, you are seeing actual product variation.
It would, but if that is not a normal practice, it is not part of your normal measurement error, so I would not do it.
E
Elwood
I will have to think about how to collect the data properly on our process. This should get me going in the right direction I think. Thanks again for the help.
E
Elwood
Miner,
What data source do I use to perform the autocorrelation analysis? Do I analyze the raw data from one regular production run and repeat this process for all of the different product types and sizes we run?
Also, just to make sure that I understand how to interpret the graph from Minitab, I first look for the first blue lag line that is below the dashed red line. If that line corresponds to a lag of 10, for example, and my data points are 5 seconds apart then I need to sample at a frequency greater than 50 seconds in order to separate actual process variation from variation due to measurement error. Am I correct in my understanding so far? Say for example I choose 55 seconds as a sampling frequency, do I still collect data every 5 seconds and subgroup the 11 data points into 1?
Once I have done all of that, what is the next step? Do I perform a capability study on the process for different products? What actually provides the repeatability component?
Thanks again.
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA Chicken and Egg - Process Capability and Measurement System Capability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
H ISO13485:2016 Measurement System - Methods General Measurement Device and Calibration Topics 4
E Measurement System Analysis/validation to new factory Manufacturing and Related Processes 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
T Method to assess Measurement System of a Continuous Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Measurement system analysis "shall be conducted to analyze the variation..." Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
G Where to obtain training to program the Keyence Measurement System IM6120 Training - Internal, External, Online and Distance Learning 3
E Measurement System Analysis (With parts that have variation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
W Gage R&R where Device Under Test (DUT) is part of the Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P Vision Measurement System - Software Program Qualification Qualification and Validation (including 21 CFR Part 11) 6
Y Gage R&R for multiple measurement system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Measurement System Artificially Creates a Skewed Distribution Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J How do you perform a S3 Stability Study for a Non-Replicable Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Camera Vision Measurement System Gage R and R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
W Anyone using Keyence Image Measurement System Calibration and Metrology Software and Hardware 2
C Measurement System to measure Hole Diameters, True Positions, Surface Profiles, etc General Measurement Device and Calibration Topics 4
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
H Measurement System in Control if the Equipment requires Daily Calibration? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
K Effectiveness of ISMS (Information Security Management System) Controls Measurement IEC 27001 - Information Security Management Systems (ISMS) 3
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
