Measuring an internal groove for a snap ring suggestions
Brad Eickhoff
#11
Re: Suggestions for measuring an internal groove for a snap ring?
Hi Discordian,
If you could get an accurate measurement of the ID (using deltronic pins), then lay the part on it's side.
Use a height gage with with an indicator (graduation .00005") find the low spot on the ID, zero the height gage/indicator, and then lower the indicator tip into the ring groove finding the low spot, multiply the difference by 2 and add to the ID diameter.
I checked our indicator tip and the diameter was aprox .039". Since the width of your groove is a reference dimension of .019" it would not hurt to widen this by .001" or so, for the tip to fit in.
I would then use Ederie suggestion of metrology puddy to verify that that the width of the groove is consistant, so I am not hitting a high or low spot, inside the groove, with the indicator tip.
You also mentioned cutting the part for a first article. If the ID is manufactured with the same tool as the groove. Could you not use the first article dimension on the ID dimension (with deltronic pins again) to determine the exact offsets you need to adjust the groove to stay in tolerance? Then you could base your groove ID off of the ID and adjust accordingly to the ID.
Brad
ScottK
Not out of the crisis
#13
Were the folks at Truarc of any use?
send a message via their web site - no response yet. But we do buy a few parts from them so if I don't get anything back I'll drag our purchasing guy into the action.
I'm going to try the same with our other supplier of these.
gard2372
#14
Just trying to keep this simple....
IMHO Will the customer allow you to (after machining the groove) to peform a type of fit form function verification by just inserting the correct size mating ring into the groove and check for proper seating?
In other words will your customer allow you to write this into your procedures as the verification of the groove dimensions?
ScottK
#15
We could probably do that.
But I'd really like to be able to measure so I can help show to the chief engineer whether or not our process is capable of +/- .001" on that dim.
Wes Bucey
#16
What did you learn so far?
ScottK
#17
...that the customer's statistician is on our side because he convinced the project manager that it is a pointless dimension to measure on anything beyond first article.
Wes Bucey
#18
I'm disappointed. I was really curious about an efficient method or tool to do the job Once you raised the topic, it was like one of those "worm tunes" you just can't get out of your head.
#19
I've faced this situation many times, and I'm pretty sure that trying to measure an internal groove such as the one in question, to the precision specified, isn't practically possible. While Discordian says that the customer is willing to forgo all but first-article inspection of the feature, if you can inspect it once, you can inspect it twice. As we've often said here, the best way to deal with this sort of thing is at the front door, and not when an inspector, probably faced with time constraints, is scratching his head and trying to figure out a way to defy the laws of physics.
ScottK
#20
Our last thought before it was determined not to measure in process was to modify a bore gauge by grinding down the the three "fingers" so they would fit into the groove.
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Measuring Internal Auditor Performance Internal Auditing 25
A Measuring Internal Auditor Performance Internal Auditing 20
P 7.6.3 Internal or External Laboratory? Measuring instruments used in production IATF 16949 - Automotive Quality Systems Standard 9
W Measuring production performance - Defect Detection % vs. Internal Reject Registered Visitor Articles Archive 4
A Internal Audit Tools and Measuring their Effectiveness Internal Auditing 4
T Measuring Effectiveness of Internal Audits - Reporting in Management Review Meeting Management Review Meetings and related Processes 13
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 1
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
H Measuring Design Process Design and Development of Products and Processes 4
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
S IOQ protocol for a Micro-Vu measuring system - Is a PQ required? Qualification and Validation (including 21 CFR Part 11) 2
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
L Radius Measuring Tools General Measurement Device and Calibration Topics 4
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
Claes Gefvenberg Worst measuring equipment ever? Coffee Break and Water Cooler Discussions 6
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
