Measuring axial and radial surface finish (16 Rz) on a broached internal radius
Proud Liberal
I'm measuring axial and radial surface finish (16 Rz) on a broached internal radius. The internal geometry is somewhat complex (one-way clutch mechanism) and the broach tool can leave grooves in the surface (see picture). Due to the complex geometry, the surface needs to "nibbled" in sections (vs the entire pattern cut with a single tooth in the broach). This means its extremely difficult to get a micron level tooth alignment from one section to another (thus the grooves).
Consequently, it's easy to run up against the tolerance limits if I measure the "worst" sections of the profile. Per ISO4288 Annex A, there exists a 16% rule with a series of inspections that appears to provide a loop-hole for accepting small areas outside the surface finish spec. My understanding of the rule and its application is limited to what is published in the Mitutoyo "QUICK GUIDE TO SURFACE ROUGHNESS MEASUREMENT" as I do not own a copy of ISO4288.
Does the 16% rule assume something about the homogeneity of the surface (turned, ground, etc vs broached)? There isn't anything that addresses the width of a "non-conforming" section permitted. Would that be limited to a sampling length? Or an evaluation length?
I'm in need of some expert advise as I feel unqualified at this level of interpretation of the ISO specification.
J Monitoring devices vs measuring devices IATF 16949 - Automotive Quality Systems Standard 7
Q Measuring employee awareness Benchmarking 12
M Master / Guideline Matrix for measuring equipment Manufacturing and Related Processes 4
M Number of decimal places for measuring General Measurement Device and Calibration Topics 3
F Measuring the amount of cure and predicting shrinkage in automotive weatherstrips Manufacturing and Related Processes 4
T Measuring Corrective Action Effectiveness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Gage R&R for inline measuring machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
eule del ayre Clause 7.1.5 Monitoring and measuring resources IATF 16949 - Automotive Quality Systems Standard 14
armani Monitoring and measuring equipment for occupational health and safety purposes Occupational Health & Safety Management Standards 10
Q Class I Medical Device with measuring function (UK MDR 2002 / MDD) UK Medical Device Regulations 3
G Calc uncertainty of angle; by measuring x,y points Measurement Uncertainty (MU) 0
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A ISO 13485 Calibration Requirements- Assess and Record validity Previous measuring results ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 17025:2017 Clause 6.4 - Measuring Equipment Validity ISO 17025 related Discussions 2
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Dan Pare Density Column setup for Measuring General Purpose ABS General Measurement Device and Calibration Topics 0
S Classification of product (measuring or not?) CE Marking (Conformité Européene) / CB Scheme 5
D Measuring Radii Measurement Uncertainty (MU) 6
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Booker Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 2
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
Cats Clause ISO 9001:2015 Monitoring and measuring resources. Application a service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
