Measuring Corrective Action Effectiveness
TacitBlue
Hi All,
We are updating our internal Corrective Action procedure; however, we do not have a solid means of measuring corrective action effectiveness. What is the simple best practice for measuring effectiveness that can be applied in production, engineering, design, or in other words across the board applicable to any CA?
For example, is anyone using a template of some kind that can quantitatively measure or graph or some type of log?
Some of the ideas is the measure reoccurance, but how do you do that and present it? or another idea was to look at lost productivity? but, again, how do you do that in concert with the CA effectiveness?
Please note, I would appreciate responses to not include references to other past posts or questioning why I am asking this. I am looking for a fresh perspective.
Mike S.
Happy to be Alive
I primarily consider does the cause(s) addressed by the corrective action(s) reoccur?
jmech
I don't think there is one "simple best practice ... applicable to any CA". The measurement method/tool/template/practice needs to be suitable for what is being measured.
When the corrective action is for a process that occurs frequently, check if the process/outputs now conform.
When the corrective action is for a process/event that occurs less frequently (or you don't know if it will ever occur again, such as producing a specific custom product or enacting a specific contingency plan), you might need to be more creative in measuring effectiveness.
TacitBlue
Mike, we use TipQA Corrective Action module to record and monitor CAs. However, beyond going back or monitoring within a lengthy database, how would we monitor for reoccurrence? Should each CA recipient keep their own log?
Mike S.
Happy to be Alive
TipQA? I pity you. That's awful software.
I usually don't do this review formally on every CA. The assumption is, and the norm is, that the cause(s) addressed by the corrective action(s) do not reoccur. But when a problem crops up we look to see if it is a repeat and if so, is the cause the same.
ChrisM
"All corrective actions are different". You can bet that if there was one way of monitoring their effectiveness, some software developer would have already come up with a program to do the monitoring, from which they would be making a lot of money.
Part of the CA process would be to identify and state what was required from the arising action, e.g. to eliminate the issue or to reduce it (ideally with a qualifying number or percentage). Checking the effectiveness would then determine if this criteria had been met.... For example: no recurrence, then it's been eliminated; recurrence reduced from once a week to once a month, and the target was to reduce to once per month or less - corrective action has been effective
Steve Prevette
Deming Disciple
It really comes down to the word "effectiveness". Have you had any recurrences of this issue? Now that can be a tough issue - such as that was not a recurrence of a knee injury since the first one happened to a left knee, and the second to a right knee.
And waiting for a recurrence can be very lagging, and you likely want some assurance that you won't have a recurrence.
So next is to look at (and I did this as a Contractor Assurance person) - an independent review of the causal analysis and "grading" it for completeness. Grading did the corrective actions planned reasonably address the identified cause(s). And finally, did the corrective actions as documented in the closure meet the specifications of the plan.
Simple "Management by Wandering Around" tours can also spot if the corrective actions took hold, and analyzing "close calls".
Finally, I'd suggest comparing it to taking your car into a repair shop for a repair. How do you "know" if the repair was does properly? Use the same logic as how you answer that question.
Randy
Fresh perspective? How about.........Does the corrective action work the way we wanted it to work? YES or NO
History is full of examples of effective corrective action, just snag one
Q Measuring Effectiveness in Containment Action or in Corrective Action? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Measuring Corrective and Preventive Action System Effectiveness Nonconformance and Corrective Action 32
Q Measuring Monthly Progress in Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Monitoring devices vs measuring devices IATF 16949 - Automotive Quality Systems Standard 7
Q Measuring employee awareness Benchmarking 12
M Master / Guideline Matrix for measuring equipment Manufacturing and Related Processes 4
M Number of decimal places for measuring General Measurement Device and Calibration Topics 3
F Measuring the amount of cure and predicting shrinkage in automotive weatherstrips Manufacturing and Related Processes 4
S Gage R&R for inline measuring machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
eule del ayre Clause 7.1.5 Monitoring and measuring resources IATF 16949 - Automotive Quality Systems Standard 14
armani Monitoring and measuring equipment for occupational health and safety purposes Occupational Health & Safety Management Standards 10
Q Class I Medical Device with measuring function (UK MDR 2002 / MDD) UK Medical Device Regulations 3
G Calc uncertainty of angle; by measuring x,y points Measurement Uncertainty (MU) 0
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A ISO 13485 Calibration Requirements- Assess and Record validity Previous measuring results ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 17025:2017 Clause 6.4 - Measuring Equipment Validity ISO 17025 related Discussions 2
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Dan Pare Density Column setup for Measuring General Purpose ABS General Measurement Device and Calibration Topics 0
S Classification of product (measuring or not?) CE Marking (Conformité Européene) / CB Scheme 5
D Measuring Radii Measurement Uncertainty (MU) 6
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Booker Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 2
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
Cats Clause ISO 9001:2015 Monitoring and measuring resources. Application a service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
