Measuring customer parts on a CMM - How many decimals to report to the customer?
Eredhel
Quality Manager
#11
Like Roxanne I'm not intimately familiar with 17025. But I don't believe your CMM is a calibration standard, you even mention that you use an NIST traceable standard for your CMM.
Are you trying to use your CMM as an NIST traceable calibration device as well as an inspection tool? I might also be misunderstanding what your goal is.
Ninja
Looking for Reality
#12
The customer parts in this case, are glass measuring scales, for which they would like calibration data of specific line to line distances.
I think your use of this word is causing the confused responses...data is data...
Being that it seems like there are two languages being spoken here...please allow me to ask this:
"What, specifically, is the customer paying you to do?"
If it is to measure the distance between lines on a piece of glass...your 17025 has no part of the conversation and has confused the issue.
You are doing toll measurement work...period.
If it is instead to issue a calibration certificate...that's another story.
greif
#13
Yes the customer wants a calibration certificate and yes he wants lines measured on a piece of glass.
I seem to recall some confusion between inspection, calibration, and verification by different groups and the US and Europe; maybe there is some of that going on here.
Calibration of an item does not need to be directly to a "standard" (ultimately the only standards are SI unit items), almost all calibrations are done by a chain of traceability. Even the fancy machine NIST used to measure my master scale, was checked against other scales and end standards.
I brought up 17025 because there are specific reporting requirements required by it, and the customer wants a 17025 accredited calibration certificate (in the future for us, not there yet).
But back to my original question, which is more basic metrology and trying to do things in an industry accepted way:
If we measure the part 3 times and get; 50.000, 50.000, 50.002mm, is it ok to report 50.0007mm (along with the associated uncertainty)?
Eredhel
Quality Manager
#14
Keep in mind some standards specifically require traceability to NIST. And I know of one standard that gets even more specific and says that you cannot use a "moving" device as a standard. This is one of the reasons for asking these kinds of questions.
Edit: An example of calibration against standards that gets more specific, "Verification against identified acceptance criteria is performed on nonadjustable equipment."
Eredhel
Quality Manager
#15
I should mention that "nonadjustable equipment" requirement isn't even for a calibration house, it's a QMS requirement for manufacturing of components and assemblies.
Edit: I forgot to mention your original question you put back out there. Another tricky thing here is that technically there is no rounding allowed to be done with decimals. But I didn't want to mention that until we knew more about what you were really trying to do.
greif
#16
I don't follow; how would you measure a glass line scale (not a short one, say 100mm long) on a non-moving device?
I do like the idea of the part remaining stationary (it does on my CMM, the x and y move on air bearings while the part sits on the granite). But still has moving parts.
greif
#18
Sooooo..... a non-adjustable scale is used to calibrate my CMM, then the CMM is used to measure the customers glass scale. No problem, right?
#19
Customer does not state tolerance, only wants measurement reported.
Here is what I've been able to deduce from the information provided so far:
  • If there is no tolerance, it means that for practical purposes the lines can be anywhere, and the customer wants the location of them (relative to what, I don't know) measured. This is not calibration.
  • You wrote, "Calibration does not require adjustment, so calling it calibration seems proper." You are correct that "calibration" doesn't imply that adjustment is necessary. It does, however, require comparison to a standard. Your CMM/microscope is not a standard in this sense, thus you are doing simple measurement, not calibration.
  • Eredhel wrote, " An example of calibration against standards that gets more specific, "Verification against identified acceptance criteria is performed on nonadjustable equipment." I don't know the source of the quote, but it's wrong. All calibration is verification, but not all verification is calibration. Again, calibration is comparison to a standard, period.
  • You wrote, "
  • ...when I sent my standard scale to NIST, they did what I am doing for my customer..." No. They compared your scale to a standard, and presumably a tolerance was involved, or will be involved in the use of your scale. Not calibration
Again, based on the information available here, you are not doing calibration.
Eredhel
Quality Manager
#20
  • You wrote, "
It's a quote from the API Q1 standard. And it is specific to their requirements for what kinds of standards are allowed to be used to calibrate/verify measuring equipment. It's accurate, and quoted verbatim. I used it as one example of an outlier, not that all QMS standards are like that.
B Measuring Customer Service Improvements Misc. Quality Assurance and Business Systems Related Topics 3
Sidney Vianna ISO 10004:2012 - Customer satisfaction - Guidelines for monitoring and measuring Other ISO and International Standards and European Regulations 18
D 8.2.1 Monitoring & Measuring customer satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Measuring Customer Satisfaction - Memo or a survey? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N Measuring Customer Satisfaction without Customer Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Sidney Vianna All the TC 176 documents - ISO 10020 - Customer Satisfaction Monitoring and Measuring ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Best Method and Equipment for Measuring Porosity of Customer Supplied Castings Manufacturing and Related Processes 12
W Measuring Customer Complaints in PPM - How does your company define PPM? Customer Complaints 21
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 1
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
H Measuring Design Process Design and Development of Products and Processes 4
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
S IOQ protocol for a Micro-Vu measuring system - Is a PQ required? Qualification and Validation (including 21 CFR Part 11) 2
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
L Radius Measuring Tools General Measurement Device and Calibration Topics 4
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
Claes Gefvenberg Worst measuring equipment ever? Coffee Break and Water Cooler Discussions 6
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
