Measuring Equipment on Injection Machine should be Calibrated by 3rd party?
cqt18060180
Measuring equipment on injection machine should be calibrated by 3rd party?
This was a findings during customer audit, he requested us to calibrate those measuring equipments which in the injection
machine. Any experience on this case please reply, customer insist this action.
if it does , Calibrate cost will be more
Marc
Is your customer asking for 3rd party calibration of your injection molding process monitoring gages because you do not have an in-house laboratory capable of calibrating them?
Allasm
if you have capability inside your lab to do this task then this can be sufficient once you convince your customer about the competency of your staff.
cqt18060180
we don't have the capacity cal by our internal lab,
if it is the must, we need to review the machine down time and calibration cost
those meters like pressure meter, temp meter on the injection machine
boring
Golfman25
What is the reason needed for calibrations? Those values, pressure and temp. are relative values, not actual values. In other words, they are not necessarily interchangable between machines. So whether the value is 500 or 600 is meaningless, as long as it is the same on the particular machine. If your process really requires superior control, then you should be looking at cavity pressures and melt temps -- ie; mold sensors as opposed to machine readings. If you are stuck with machine gage calibration, you may want to contact your machine manufacturer. Good luck.
BradM
Hello there!
Were there any critical parameters on the injection molding machine they noted specifically?
If the nozzle temperature is off, aren't you going to catch that in final acceptance of the product? Do you inspect all your products once complete?
What I'm asking is this: I realize they are your customer, but performing a full calibration on an injection molding machine (including process pressure gauges) can be very expensive.
If you can narrow down what are the critical parameters on the machine, maybe you can reduce the scope of calibration.
If you can demonstrate through final testing of the finished product that calibration is not needed, all the better. :)
Ronen E
Problem Solver
Moderator
I agree with the gentlemen above that acceptability and in-lot / lot-to-lot stability of the final moulded parts are more important than an actual specific parameter reading. If you could implement some sort of SPC to show that your final product is acceptable and your process is stable, maybe you could convince that customer that looking at the machine parameters is not that interesting for them.
However, the customer has the right to behave like one...
To me it sounds as if they have less than perfect understanding of injection moulding QA, so I doubt that rational reasoning would help. Good luck anyway!
Cheers,
Ronen.
Big Jim
You need to calibrate "when necessary to ensure valid results". If you can obtain valid results without calibration, then calibration isn't needed. It still may be desirable though.
Hershal
Metrologist-Auditor
If the temperature and pressure monitoring equipment does not need calibration, why not simply remover the items from the machine? If it is not providing an quantitative data used for the product, there will be no negative effect in simply removing it.
If there is an effect and you need to know, then calibrate them, use an accredited lab, and get the uncertainty so you know what it is actually doing.
Ronen E
Problem Solver
Moderator
Is it an "all or nothing" situation?
In my opinion, like almost everything associated with profitability, it's a matter of risk management, i.e. weighing the benefits & costs vs. the risks in the default situation.
A control system may be of use even if it's not formally calibrated. It may still control the machine, and if indirect evidence (e.g. part characteristics) is indicating it's working properly, it may suffice in certain situations. If getting a formal calibration costs a lot more than implementing SPC, and there's no official mandatory requirement to calibrate, then why wouldn't choosing the latter be a legitimate decision?
M Missing measuring equipment General Measurement Device and Calibration Topics 6
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
Claes Gefvenberg Worst measuring equipment ever? Coffee Break and Water Cooler Discussions 6
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
R Auditing Fitness of Purpose for Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
H Tolerance, decimal places, and measuring equipment capability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Scope in procedure and content for 7.6 Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Inspection Equipment Accuracy - Measuring the diameters of small holes Measurement Uncertainty (MU) 5
x-files ISO 9001 Clause 7.6 - Test as Measuring Equipment... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Measuring OEE (Overall Equipment Effectiveness) for each Job, not for Machine Lean in Manufacturing and Service Industries 2
M GRR approach for off line Measuring Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Does 7.6 Control of Monitoring and Measuring Equipment align with ISO 17025 ISO 17025 related Discussions 4
G Control of Monitoring and Measuring Equipment for Servicing Photocopiers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO9001 Exclusion 7.6 Control of Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B Meaningful MSA Study on Viscosity Measuring Equipment IATF 16949 - Automotive Quality Systems Standard 14
P I need to Borrow or Hire a Surface Roughness (Ra) Measuring Equipment Manufacturing and Related Processes 3
W Moving M&TE (Measuring & Test Equipment) to New Facility General Measurement Device and Calibration Topics 3
M 7.6 Control of Monitoring and Measuring Equipment - Monitoring vs. Measuring IATF 16949 - Automotive Quality Systems Standard 2
GStough Human Capital: How to Meet Requirements of 7.6 (Monitoring/Measuring Equipment)? Service Industry Specific Topics 10
R ISO 17025 M&TE (Measuring & Test Equipment) Calibration Requirements ISO 17025 related Discussions 4
Anerol C Uncertainty Excel Spreadsheets for Measuring Equipment wanted Measurement Uncertainty (MU) 5
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
J Measuring and Test Equipment that must undergo MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Roberticus Gage R & R to different Specifications on Departmental Measuring Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
A Non-Contact Measuring Equipment Recommendations wanted General Measurement Device and Calibration Topics 4
G Measuring Equipment - Does Uncertainty = Accuracy ? General Measurement Device and Calibration Topics 23
P Is it compulsory to send new measuring equipment for calibration / verification? Calibration Frequency (Interval) 3
Q Soldering and AS9100 - Are soldering irons "monitoring and measuring equipment"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B Looking for a Standard identifying SME's (Standard Measuring Equipment) General Measurement Device and Calibration Topics 1
M Basis used for Calibration or Verification of Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Control of Measuring and test Equipment - Flowchart wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D How to Protect Measuring Equipment from Damage and Deterioration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
I Clarification of ISO 9001: 2008 Section 7.6 - Monitoring and measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G ANSI/NCSL Z540.3 (Requirements for the Calibration of Measuring and Test Equipment) General Measurement Device and Calibration Topics 1
D Control of monitoring and measuring equipment - infrared thermometer for cross-check ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
W Computer Software - ISO 9001 Clause 7.6 Control of Monitoring and Measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J How can measuring equipment deteriorate? (Re: 7.6) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Configuration Management - ISO 9001 - 7.6 Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Repetition (sample size) for measuring equipment accuracy determination General Measurement Device and Calibration Topics 1
S Health care, social services and measuring equipment Service Industry Specific Topics 6
S Measuring Equipment and Monitoring Equipment - Verification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
hogheavenfarm Extending control of measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Is Calibration Required for Equipment/Devices Used for Measuring Support Services General Measurement Device and Calibration Topics 6
K Measuring equipment different than scope - Accreditation document for our calibration General Measurement Device and Calibration Topics 2
